Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vanquish Products VS4-10 Origin
Thread: Vanquish VS4-10 Origin Limited Build/Thoughts Issues
Old 07-19-2018, 10:28 AM   #81
Go Buckeyes!
B-MOW71's Avatar
Default Re: Vanquish VS4-10 Origin Limited Build/Thoughts/Issues
LMAO! Hey, with out giving away too many of my secrets, the GoolRC box is empty. Couldn't find anything else to set my chassis on at that time.
The syringe is for my marine grease. Makes it really easy to squirt grease into gears and tight places. It is a must have!
B-MOW71 is offline   Reply With Quote
Old 07-19-2018, 01:16 PM   #82
Originally Posted by B-MOW71 View Post
I received my kit yesterday and wanted to let everybody know that I did not have any issues with the axles. Everything went together really nice. All of the machined parts and plastic parts seemed to just fall right together. Extremely happy with how it all went together. It is not done yet, but this is how far I got last night.
I see that you are not using metal balls in the top shock mounts, but using the plastic balls off the parts tree. Were the metal balls not included in your kit either? Just curious because the manual specifically calls out the metal balls for the top shock mount by part number, but I think that is an error.
rohrej is offline   Reply With Quote
Old 07-19-2018, 02:01 PM   #83
Moderator
JatoTheRipper's Avatar
Metal balls inside metal shocks are a bad idea IMO. I'd rather the plastic ball wear instead of the aluminum shock.
Old 07-19-2018, 02:26 PM   #84
Go Buckeyes!
B-MOW71's Avatar
I think you are right. The manual must be wrong. It says to use the same metal balls that are used in the links. I only had enough metal balls for the links. I did use the plastic balls off the shock parts tree.
I’m with Jato, would not want metal balls inside the metal shock caps. I may use something else in place of the plastic balls because I don’t like how sloppy the shock cap is on the plastic balls.
Back in the day when I raced off-road with my RC10, I used fuel line. It holds the shock tight and still lets the shock move around without the slop.
Old 07-19-2018, 03:35 PM   #85
I was thinking of slipping some o-rings over the plastic balls on either side of the shock cap to reduce the slop.
Old 07-19-2018, 04:23 PM   #86
Go Buckeyes!
B-MOW71's Avatar
That is a good idea. That should keep it from moving side to side an keep it centered. I’m going try that out. Thanks for the tip!
Old 07-19-2018, 04:50 PM   #87
That works great, I have that on my Bully
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 07-20-2018, 01:35 AM   #88
Default Re: Vanquish VS4-10 Origin Limited Build/Thoughts Issues
Still no interior; waiting on my Shapeways order, but the body, wheels, and tires have all come together. Worked out pretty much as intended, if you ignore my crappy paint job. (Matt, if you're still reading, avert your eyes).
Old 07-20-2018, 02:05 AM   #89
MSH
Vanquish SHR i think.
MSH is offline   Reply With Quote
Old 07-20-2018, 02:14 AM   #90
They're one of my all-time favorite wheels, I was really stoked to see rohrej use them!
Vanquish SHR Vintage wheels... so nice
durok is offline   Reply With Quote
Old 07-20-2018, 02:26 AM   #91
Originally Posted by Teng View Post
Those wheels really beautiful. What brand are there?
What they said. Vanquish Vintage SHR. I think the styling is a perfect match for this truck. They are a 2.2 wheel, so the tires and foams had to be stretched on.
Old 07-20-2018, 04:43 AM   #92
Go Buckeyes!
B-MOW71's Avatar
Nice job! I really like the color. I think it turned out really good.
Hoping to get painted the weekend.
Old 07-20-2018, 05:10 AM   #93
Paint looks awesome, nothing wrong with it...
celt is offline   Reply With Quote
Old 07-20-2018, 05:59 AM   #94
Did you use the kits fasteners, yours look to be SS not black.
Old 07-20-2018, 06:03 AM   #95
Moderator
That looks perfect! Great wheel selection! I, too, love those wheels, but never had a rig to use them on. I really wish VP would offer these in 1.9. They look better on scale rigs than they do typical 2.2 rigs like the Bomber, Wraith, etc.
Are those 1.9 Rock Beast XL tires that you're using?
Old 07-20-2018, 06:16 AM   #96
Go Buckeyes!
B-MOW71's Avatar
I did not use the kit screws. I used Team KNK stainless screws. I use Team KNK in all of my trucks. I am not a big fan of rusty hardware. Plus I like the way the stainless looks.
Old 07-20-2018, 09:56 AM   #97
Yes they are. With CI 1.9 foams.
Old 07-21-2018, 10:54 PM   #98
Truck looks gorgeous! I've come back to ogle the pictures 3 times now after reading this thread initially.
Honestly, most stretched tire combos look sketchy and often silly. This wheel and tire combo hits the mark exactly.
Excellent job sir.
Sent from my SM-J727R4 using Tapatalk
Dan_in_real_life is offline   Reply With Quote
Old 07-21-2018, 11:15 PM   #99
Excellent job sir.
Thanks for the kind words!
Old 07-23-2018, 04:28 PM   #100
Put the first scratches on it today! Was hoping to get some picks of this copper paint in the sun, but no such luck.
Tags
build, vanquish, vs4-10
Vanquish VS4-10 Origin Limited Build/Thoughts Issues - Similar Threads
IN STOCK NOW!! Vanquish Products VS4-10. RPP Hobby RPP Hobby 0 07-12-2018 06:02 PM
Limited Quantity Available for PRE ORDER Vanquish Products Products VS4-10. RPP Hobby RPP Hobby 0 06-08-2018 05:15 PM
Vanquish VS4-10 scale crawler Teng Vanquish Products VS4-10 Origin 5 05-28-2018 06:15 AM
🌑PRE ORDER Vanquish Products VS4-10! RPP Hobby RPP Hobby 2 05-27-2018 03:39 PM
VXL 3s power issues - thoughts? TwistedXT Electronics 12 11-22-2011 09:29 PM
