Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vanquish Products VS4-10 Origin
Thread: VS4 for the 1.9 noob
Old 08-07-2018, 04:01 PM   #61
Default Re: VS4 for the 1.9 noob
She turned out sweet Mike! I too am really digging that paint color! Awesome build!
mewalsh100 is offline   Reply With Quote
Old 08-10-2018, 05:43 PM   #62
Default Re: FLOYD a VS4 for the 1.9 noob
Had a fun filled couple of hours , and am totally impressed at how good this rig is out of the box. Climbed up almost vertical lines of loose sandy rock with a bit of grass. Side hilling was OK, foams let me down, but that was the minor issue, ran for close to 40 minutes on the hills, then switched to the flats filled with crushed and broken pipe and rock, thought I lost steering after a few whoops, so walked over and found this ....
Bead is still well clamped, entire sidewall ripped. I couldn’t find any rebar, so I have no clue on what happened. I’ve reached out to VP and ordered another pair.
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 08-10-2018, 06:09 PM   #63
Go Buckeyes!
B-MOW71's Avatar
Glad to see and hear that it did so well. It’s too bad about the tire. I guess luckily they are in stock now.
Hopefully I can get mine out this weekend for a true test. Hoping not to blow any tires!
B-MOW71 is offline   Reply With Quote
Old 08-10-2018, 06:51 PM   #64
That's an absolutely bizarre incident with the sidewall...
durok is offline   Reply With Quote
Old 08-10-2018, 07:19 PM   #65
I am a bashing guy, yet this broken tires never happened in my life. Could it be manufacturer defect?
Teng is offline   Reply With Quote
Old 08-10-2018, 07:35 PM   #66
I honestly don’t think it was the tire. I’ve bashed at high speeds on limerock, endo ‘d , spun , flipped, crashed , and never had it happen before. That’s why I suspected rebar, but didn’t see any anywhere. I dunno !!! I’m going to switch to CI foams anyway, now is the time for some lil novas.
Hang up and Drive
Old 08-12-2018, 01:19 PM   #67
Default VS4 for the 1.9 noob
Well as I sit and WAIT to run FLOYD , I decided to see what else was on the bench and I found a stock servo that came with my Bullyll it’s a little weaker than the Tower pro coming , but why not ! So I soldered in a HeyOK controller and dropped the servo in, reversed the line to center it, made a mount for a fairlead I had here, and screwed things in. Does look like I’m making an extension lead to work it, but no prob there.
Hang up and Drive
Old 08-12-2018, 04:36 PM   #68
Did it come with interior decals ? The tool boxes in the back dod you paint those outlines to make them pop ? Great truck . Im new and im all scale
Sent from my SM-G965U using Tapatalk
bigjack7440 is offline   Reply With Quote
Old 08-12-2018, 05:02 PM   #69
BOX STOCK
I did add window tint to the rear windows. If I had a few more $$ I would have popped for the 3D dash and interior door panels.
Go back in the thread and j posted all the interior shots, right off the sheet!
Hang up and Drive
Old 08-18-2018, 09:12 AM   #70
Dropped a couple of teeth on the pinion today, no need for speed, has a bit more drive now, will go play with my throttle curve again.....
Also spaced the winch servo up a bit, bobbin was hitting the panhard end
Hang up and Drive
Old 08-18-2018, 07:57 PM   #71
https://splice.gopro.com/v?id=5mzJXP
Hang up and Drive
Old 08-18-2018, 08:01 PM   #72
Saw something that didn’t look right, and I think the simple adjustment looks and works better.....
Before:
After:
The bumper move in forwards give more rear clearance Clarence!
Hang up and Drive
Old 08-19-2018, 07:24 AM   #73
Had a great run today , but did find a weakness, more front wheel weight to keep things planted when uphilling.
My issue is to add weight, I need to install wider hubs, not sure I want .350 wide.
Any ideas ?
Hang up and Drive
Old 08-20-2018, 04:10 PM   #74
Now i have a dilemma, I saw the Ripper front bumper on a VS4 and that is the bomb!! my Issue is hitting the front corners of the stock bumper
https://goo.gl/images/v3Haad
Old 08-20-2018, 07:49 PM   #75
Nice build.
I'm running 350 hubs on VP wheels with lilnovas & stock tires- body rub.
I'm going down to 225...
RayB is offline   Reply With Quote
Old 08-21-2018, 07:54 PM   #76
Had some time during work to play, all sorts of terrain, rocky hill, lots of loose rocks and wet sand.....
Worked well if enough rock, dig trenches in sand.
Trails, dirt, hills , rocks and trees, holes and loose long brush..... Very impressive, perfect match!
My old standby , Riprap it was clean today and dry, had a gas!!
Yes this truck really drives and doesn’t sit on any shelf long .
Even a barrel roll down a hill with brush !!
Hang up and Drive
Old 08-21-2018, 09:19 PM   #77
Great thread Mike. Good work on the truck and the documentation. Like your colour choice.
Tossedman is offline   Reply With Quote
Old 08-22-2018, 04:47 AM   #78
Go Buckeyes!
B-MOW71's Avatar
I see it starting to get some battle scars! Lookin good!
I too like the look of the Ripper front bumper. I'm thinking I better order one before there gone!
Old 08-25-2018, 08:42 AM   #79
I realized most of my crashes and flips were caused by the driver. So I fired mine and a buddy Joe is helping me out.
Hang up and Drive
Old 08-25-2018, 10:16 AM   #80
Driver selection IS critical...no matter the plethora of high end parts installed it all comes down to the nut that holds the wheel lol
Sent from my SM-G930R4 using Tapatalk
2mtech is offline   Reply With Quote
VS4 for the 1.9 noob - Similar Threads
Another NOOB Li-Po ?? dozerboy Electronics 19 10-06-2013 12:16 PM
noob, with noob questions farmerstoy General Scale Talk 12 01-14-2010 06:28 PM
Noob here JOOTZ Newbie General 2 11-08-2008 11:34 PM
Noob here Rhino8123 HPI Wheely King 2 04-30-2007 06:57 PM
