09-24-2019, 09:35 AM | #181 | ||
| Re: New Vanquish Chassis Kit Quote:
I ordered the VFD Trans Kit to put in my Origin and I do not plan on changing the gears out right away. I did buy the aluminum standoffs and aluminum motor plate though. | ||
09-24-2019, 09:41 AM | #182 | |
We found it to be closer to 97.3492%. | |
09-28-2019, 06:18 PM | #183 | |
Quarry Creeper Join Date: Nov 2018 Location: So Cal
I just purchased the VFD trans kit to go with my VS4-10 chassis, and I'm planniing on running TRX-4 axles. I viewed Harley's videos on this subject, and they were very helpful. Then I recreated his spreadsheet that calculates gear ratios and final drive ratios. I am coming up with all sorts of combinations of spur and pinion that will get me right where I want to be in terms of FDR with my TRX-4 axles. I'm just not sure if all of them will work. So to be safe, right now, I'm looking at running a the 22T pinion with a 50T spur that svt923 suggested: 2.30 (portal) X 3.09 (stock TRX-4 axle) X 2.95 (VFD front trans output) X 2.27 (S&P) = 47.66 FDR Front 2.30 (portal) X 3.09 (stock TRX-4 axle) X 3.15 (VFD rear trans output) X 2.27 (S&P) = 50.89 FDR Rear That combo would yield the expected 6.56% overdrive, since no OD in the axles, only in the trans. I might also try running UD in the rear axle to get to 57.63 FDR with 18.93% OD total. That all looks good to me. I'm ready to give that a try. I found a 22T pinion and 50T Spur at the local hobby shop. I assume they will fit. But I am also thinking about trying some other combos. So I was wondering if there is a gearing chart that shows the viable pinion and spur combos that will work with the VFD Trans? I had someone who owns a VS4-10 Pro look in their manual, and they couldn't find one in their manual. Any help would be appreciated. Last edited by boldfin; 09-30-2019 at 09:12 PM. | |
09-29-2019, 09:34 AM | #184 | |
I would order a 21T pinion just in case as well. | |
09-30-2019, 09:23 PM | #185 | |
21/50 looks like it will work too: 2.30 (portal) X 3.09 (stock TRX-4 axle) X 2.95 (VFD front trans output) X 2.38 (S&P) = 49.93 FDR Front 2.30 (portal) X 3.09 (stock TRX-4 axle) X 3.15 (VFD rear trans output) X 2.38 (S&P) = 53.32 FDR Rear BTW - how do you figure out the center distance? Is there a formula or online calculator? Do you start by measuring a known good Spur and Pinion combo? My googling on that subject so far has not yielded good results. There are some 48T Spur gears on the market, and I already have the 22T pinion. That combo gets me to an almost perfect F/R FDR of 44.43 / 48.86, but I don't know if it will fit. | |
10-05-2019, 08:19 AM | #186 |
Built my VFD Trans with a 50T Spur / 21T Pinion. I'm going to try this first with stock TRX-4 axles. But I also have a 48T Spur that I can go with if I don't like the 50/21 combo. Then I might mess around with OD on the front axle. Any idea when the additional OD gear sets will be made available for the VFD Trans? |
01-06-2020, 10:08 AM | #187 |
Newbie Join Date: Jan 2020 Location: Cleveland
Out of curiosity how much advantage would a vfd trans have over a enduro stealth x transmission. I really like the vfd but with the standard non offset ar44 axles it’s not yet a option for me but I have to buy a trans because I am converting a Cherokee kit scx10.2 to the vs4-10 chassis.
01-06-2020, 10:22 AM | #188 | |
Pros: Lower motor position Forward motor position With the 21% Overdrive gear set now available you have access to more OD than the element trans All metal gears Scale appearance Cons: Requires offset front axle Out of the box the element trans has the option of a higher overdrive VFD will not work with the included VS4-10 battery tray without modification or purchase of VFD specific battery plates. (See modular chassis system thread here in this section for more info) Its really up to you and what you want the final outcome of your SCX10 to be. | |
01-06-2020, 11:29 AM | #189 | |
01-06-2020, 11:41 AM | #190 |
I wanna be Dave Join Date: Sep 2019 Location: US
Like Jarad70stng, I'm also interested in using the VS4-19 Chassis Kit for a build...tho, not for upgrading a kit. I spent a considerable amount of time researching possible chassis kits, as well as just rails. I created a thread, asking for assistance, suggestions, recommendations, etc, from others. I took all this info, to finally narrow down the possibilities to just two...one of which is the VS4-10 Chassis Kit. My plan is to build up from the chassis. Also like Jarad70stng, if I'm to use the VS4-10 chassis, I'm extremely interested in using the VFD transmission. Unfortunately, due to my plans of using portal axles, that appears it might eliminate my ability to use the VFD in this project. I have come up with a possible solution, but I'd first need "confirmation" as to whether, or not, it would work (ie. I wouldn't want to order hundreds of dollars of Vanquish parts, and then have to return the majority of them). As I understand it, any rear axle can be used...it's only the front that has to be the VPS08370/VPS08371 axles...so, here's what I'm thinking. I'm assuming that, in terms of overall width, the VPS08370/VPS08371 axles are based on the standard SCX10/SCX10.2 AR44 axles, with the only differences being the location of the pumpkin, and the lengths of the left/right driveshafts. If my assumption is correct, then I should be able to use the SSD Portal Knuckles (SSD00220) with the VPS08370/VPS08371 axles, removing the axle stubs from the Vanquish driveshafts, and removing them with the SSD portal axle stubs. The problem with this idea...based on looking at photos of the SSD & Vanquish driveshafts is that, while the SSD axle stubs attach to the main driveshaft pieces by means of a typical (ie. universal ball-type joint), the Vanquish parts appears to have an entirely different connection type. I need a viable way of running portals...and, if there's no way of attaching portals to the VPS08370/VPS08371 axles, then I'll have no choice but to eliminate the VFD from the build I'm planning. So, what are my options? Can the SSD axle stubs be attached to the VS4-10 front driveshafts? If not, what other option(s) do I have? ~ More peace, love, laughter & kindness would make the world a MUCH better place Last edited by Panther6834; 01-06-2020 at 11:45 AM. |
01-06-2020, 11:55 AM | #191 | |
The TRX4 axles would be the way to go. I've seen it done multiple times, just take some dremel work and an upper link spacer at the front axle. Boldfin's build didnt work out with the extended shock towers and I could tell he didnt want to take the risk of trimming the skid plate for driveshaft clearance. I understand thats not for everyone. The nature of this hobby at times. | |
01-06-2020, 01:57 PM | #192 | |
Is the front over far enough to not interfere with the VFD skid? Or, if not, approx how much with the Dremel to the skid would clear away enough material for it to work? In regards to the portals, while I knew, from the beginning, that this project would require them, the only reason I was "stuck" on them is because I had already researched them, and will be using them on a 4WS Capra project. Truthfully, for what this project is, I can see the advantages of the diff lockers (the, I have absolutely no clue how to set them up...but, I'd learn quickly). ~ More peace, love, laughter & kindness would make the world a MUCH better place | |
01-06-2020, 02:26 PM | #193 | |
Boldfin's VS4-10 with VFD Trans and TRX-4 Axles As Brandon pointed out, part of my issue was that I wanted to use the extended shock towers. They do a great job of keeping the ride height low when using portals, but the lower ride height also means less clearance for the front links and driveshaft. So if you're OK with a higher COG and ride height, you may be able to get it to work by just using the standard shock towers that come with the VS4-10 chassis kit. | |
01-06-2020, 02:33 PM | #194 | |
01-19-2020, 07:57 AM | #195 |
Rock Stacker Join Date: Feb 2018 Location: Ozarks
Does anyone know the body Harley used on this build? I'm thinking of a VS4-10 build and would love to add this to my short list of body types. Thanks in advance. |
01-19-2020, 08:46 AM | #196 |
Quarry Creeper Join Date: Aug 2014 Location: holland
| Re: New Vanquish Chassis Kit |
01-19-2020, 09:22 AM | #197 | |
| Re: New Vanquish Chassis Kit Quote: | |
02-25-2020, 12:51 AM | #198 |
Newbie Join Date: Jun 2018 Location: Philadelphia
Hello, Wanted to share that I built my Deadbolt II to a VS4-10 chassis and I'm extremely happy with it, it's so stable and predictable to drive now, and the build went super nice. One thing I felt was missing was a radio box, so I made a simple design that uses the stock Axial seals and cap and mounted it at the front next to the servo (in place of the winch servo). This is very similar to how the Wraith 1.9 handles the radio box. I added it to thing verse is someone want to use it. Last edited by Yonic; 02-25-2020 at 12:07 PM. Reason: Add photo |
04-18-2020, 12:17 PM | #199 |
Newbie Join Date: Apr 2020 Location: France
I read everything and now I am confused. I transformed my scx10 2 2017 jeep with this chassis. Can I put the VFD transmission (later on put the dig unit) but still use the stock AR44 Axle or do I need one with an offset? |
04-18-2020, 12:57 PM | #200 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
Ernie Last edited by CODYBOY; 04-18-2020 at 04:06 PM. | |
New Vanquish Chassis Kit - Similar Threads | ||||
Pre-Order Now - New Vanquish VS4-10 Chassis Kit | RPP Hobby | RPP Hobby | 1 | 05-20-2019 04:31 PM |
VP Chassis Mount Servo Kit/ Panhard Kit? | Pita | Axial Wraith | 54 | 05-23-2014 09:24 AM |
