Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vanquish Products VS4-10 Origin
Thread: New Vanquish Chassis Kit
Old 06-29-2019, 01:24 AM   #101
Default Re: New Vanquish Chassis Kit
Are the extended shock towers included in the kit as well by chance
puffntough760 is offline   Reply With Quote
Old 06-30-2019, 07:38 PM   #102
No, just the standard mounts came in my chassis kit for 90mm shocks.
sherbs is offline   Reply With Quote
Old 07-01-2019, 12:20 AM   #103
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Extended towers are only done in aluminum.
Harley is offline   Reply With Quote
Old 07-02-2019, 08:59 AM   #104
Are the VP Portal's going to work with the new Transmission being the lack of offset?
Old 07-02-2019, 09:04 AM   #105
Im Brandon
Brandon's Avatar
They will not. New transmission forces the use of offset axles.
Brandon is offline   Reply With Quote
Old 08-03-2019, 06:09 PM   #106
I finally got around to using one, of the three chassis kits, that I bought. I used it on my 10.2 Honcho. The Honcho was a lightweight setup, at only 5.7lbs. The chassis swap added almost half a pound to the rig. I'm not complaining. Even though is was all unsprung weight, the lower COG of the chassis more than made up for it. The Honcho still pulls some amazingly steep lines, but it feels more stable. I have a few OG SCX10's, that I already converted to AR44's. I'll be ordering more of these chassis and converting them!
mhowzit is offline   Reply With Quote
Old 08-11-2019, 07:02 PM   #107
Can you post up some pictures of honcho body/cage mounted to this chassis?
Did you have to remove fuel cell cover to lower body?
I am interested in swapping to this chassis but want to make sure it will for sure work with honcho body.
northsandiegoRC is offline   Reply With Quote
Old 08-25-2019, 11:07 AM   #108
What would be the best three Gear transmission to use in this chassis for a custom build with portals?
Sent from my LM-G710VM using Tapatalk
MaX-D is offline   Reply With Quote
Old 08-26-2019, 09:14 AM   #109
Im Brandon
Brandon's Avatar
Any standard axial style 3 gear transmission will work. Just gear it up a bit to compensate for the portal reduction with a larger pinion and smaller spur gear.
Old 08-26-2019, 09:30 AM   #110
Is there one better than the other, or are they pretty much all the same?
Old 08-26-2019, 09:34 AM   #111
Im Brandon
Brandon's Avatar
They all have the same function and format. All depends on budget really. Aluminum cases are nice because you wont strip out the screws when bolting it on through the skid plate.
Super Shafty sells complete bombproof transmissions if you want to buy one with everything all at once.
Old 08-26-2019, 10:14 AM   #112
They should look something like this. Just seen these this past weekend. They felt very smooth and finish was great. Only bad thing is which one to pick.
carpetfuzz17 is offline   Reply With Quote
Old 08-26-2019, 10:52 AM   #113
They should look something like what? Your picture didn't go through
Old 08-26-2019, 11:36 AM   #114
I see that now...let's try it again
Old 08-26-2019, 11:45 AM   #115
I read on your website that with the chassis kit the SCX10 II transmission is not compatible. Is this true? The super shafty transmission is not in my budget
https://www.amainhobbies.com/axial-s...39/p661358?r=0
Old 08-26-2019, 12:31 PM   #116
Im Brandon
Brandon's Avatar
That is correct. The high clearance rails do not allow for the scx10 II kit style transmission mounts to line up.
Ive seen it done, just took some work.
You could go with this: https://www.amainhobbies.com/axial-l...xi30487/p18739
And: https://www.amainhobbies.com/incisio...c00190/p710208
That would give you a great starting point.
Old 08-26-2019, 12:45 PM   #117
AWESOME! Thank you for the quick response.
Old 08-26-2019, 01:25 PM   #118
Which scx10 ii transmission are you referring too? One is, the other is not if I'm not mistaken.
Sent from my SM-G975W using Tapatalk
Xx Losungen xX is offline   Reply With Quote
Old 08-26-2019, 02:05 PM   #119
I'm referring to the one in the link I posted. Brandon put links for a different transmission that will work
Old 08-26-2019, 02:51 PM   #120
So the kit transmission, 10-4
New Vanquish Chassis Kit - Similar Threads
Pre-Order Now - New Vanquish VS4-10 Chassis Kit RPP Hobby RPP Hobby 1 05-20-2019 04:31 PM
VP Chassis Mount Servo Kit/ Panhard Kit? Pita Axial Wraith 54 05-23-2014 09:24 AM
