![]() | #41 |
Rock Crawler Join Date: Jul 2015 Location: Butler, Pa
I started working on the SSD shocks yesterday. They are very well built and the aluminum spring perches collars and caps are a nice touch. The body is slightly bigger than the Incision shock bodies which is was what I wanted. The SSD collars can handle bigger diameter springs from other companies which is going to make tuning that much easier. ![]() The orings are of the xring design. The spacers had no extra flashing on them which is a good thing. Interesting to note the top spacer has a slightly longer collar going into the shock body. Nice to see the extra detail like showing that they that they just didn't use shorter ones and called it day. ![]() As for the look I was going for the shining silver wasn't working so I decided to try something. So far so good ![]() Next up is to reassemble add some VPR shock seal to the seals and add oil. Stay tuned Sent from my iPhone using Tapatalk |
![]() | #42 |
I am really happy on how these turned out. Need to put it all back together now. ![]() Close up of the finish and color ![]() Sent from my iPhone using Tapatalk |
![]() | #43 |
Shocks all built up and filled with oil. I am really pleased on how they turned out. They blend right in now. First the VRP shock seal is very thick and tacky. I was afraid of the shafts sticking but haven't noticed any of that. The shocks feel very smooth using it. If you are looking for something different than AE green slime I would recommend giving it a try. I also recommend the Avid shock slop also. Second thing I noticed is with the shocks themselves. At full compression the piston hits the bottom of the cap. Not a big deal a couple orings on the shaft took care of that. Overall the shocks are very good quality. Would highly recommend this to anyone. Next to get them installed. ![]() Sent from my iPhone using Tapatalk |
![]() | #44 |
Im Brandon ![]() Join Date: Feb 2005 Location: Colfax, CA
Can you post a comparison pic next to an Incision shock? Curious how much, if any up-travel you will be losing. The length of the shock body vs. exposed shaft looks significant. We developed the Incision shock and tried to achieve the most travel possible from a 90mm length while still retaining a bladder. |
![]() | #45 | |
| ![]() Quote:
![]() | #46 |
Sketchiness abounds... ![]() Join Date: Jun 2016 Location: Austin
I was a little worried that the coating on the shocks was going to foul and peel/flake off when the adjuster collars were threaded on, but it looks like that wasn't the case - very nice outcome! So... What did you use for a finish? |
![]() | #47 | |
| ![]() Quote:
After I finished spraying them I left them sit outside all day in the shade but was still warm outside. Brought them inside for the night. The next day placed inside of a hot car for half a day and brought them back in the house to sit. I have no issues adjusting the collars. Before I sprayed them I did wipe them electronic parts cleaner to remove any oils that may have been left behind from the manufacturing process. ![]() Sent from my iPhone using Tapatalk | |
![]() | #48 | |
| ![]() Quote:
Here you go Brandon. Not that much of a difference that I would really notice. Nothing really wrong with the Incision shocks they look like they are great quality I just prefer a larger diameter body and spring. SSD left Incision right ![]() ![]() SSD length ![]() Incision length ![]() SSD ![]() Incision ![]() Sent from my iPhone using Tapatalk | |
![]() | #49 |
Did a quick inspection last night after reading a couple issues and appears that I have fallen victim to the dreaded rear axle pin issue also time to send off an email. Is this a problem that is plaguing all the Pro kits? ![]() ![]() Sent from my iPhone using Tapatalk |
![]() | #50 |
Go Buckeyes! ![]() Join Date: Jun 2017 Location: Mid-Ohio
Yep, looks like you have the same problem. I had a lot of side to side play which allowed the hex pin to rub on the bearing cap. I have only seen a few people mention that they had this problem, so not sure if it is an issue with all of them. It's good that VP knows about this and they will get you taken care of quickly. My new axle shafts arrived in a couple days. Oh and nice looking shocks! The paint turned out great! ![]() |
![]() | #51 | |
| ![]() Quote:
![]() Already contacted VP about the issue. | |
![]() | #52 |
So this past weekend was the RC4WD East Coast Scale Challenge here in western PA. The weather was fantastic for the event. The trails and obstacles looked great. The lines were long but I didn't hear any complaints as everyone was enjoying themselves. A couple of vendors were there and was able to score a couple good deals but more on those later. There was a decent amount of VS4 Pro's running. Here's a taste of what was going on. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk |
![]() | #53 |
Looks like it was a good time! That terrain looks awesome. It reminds me of a few places I've ran up in NE Ohio. I really wanted to go to it, but I had too much going on here to get away for the weekend. A few of my crawling friends here from Ohio went to it. They had a blast! |
![]() | #54 | |
| ![]() Quote:
It's really a good cooperation between RC4WD and the camp ground that it is held at. So many people being introduced to the RC world in a laid back setting really makes it special. I know people were knocking the Axial 1/24 Deadbolt and the little yeti side by side but campers were picking them up and playing and laughing. That is what is going to keep the hobby growing. At times while standing there watching I answered several questions from campers who were curious. The on site hobby shop did very well ![]() | |
![]() | #55 |
Picked this up over the weekend. Got a price on it that I couldn't pass up. ![]() I have never owned a servo winch before so my question is there anything with the way I am running the cable? Should I be doing something different? Any advice is appreciated. ![]() Sent from my iPhone using Tapatalk |
![]() | #56 |
Could you flip it the other way so the spool/line is in line with the guide in the chassis brace and bumper? It might hit the panhard link on up travel, maybe you could space it up until it just barely clears? |
![]() | #57 | |
| ![]() Quote:
![]() | #58 |
I’m not sure how well that type of servo winch will work. I think in order for it to work right you would need to rig up something to keep the winch line in the center of the spool. By doing that though, the line may be too high to angle back down to a fairlead. I’m using a homemade servo winch with the spool under the front brace. This way let’s the line run under the chassis brace out to the fairlead. This is what mine looks like on my Origin with the Wertymade bumper. ![]() Sent from my iPad using Tapatalk |
![]() | #59 | |
| ![]() Quote:
![]() | #60 |
I took Brandon's advice. Messed around with some spacers I have in the bin. I have a more direct line to the brace channel and out through the bumper. I have enough room underneath that the links don't hit.Don't mind the screws still testing. Any thoughts on this? ![]() ![]() Sent from my iPhone using Tapatalk |
VS4 for the 1.9 noob | mikemcE | Vanquish Products VS4-10 Origin | 137 | 04-09-2020 10:01 PM |
Vanquish Products VS4-10 Pro Kit - IN STOCK!! | RPP Hobby | RPP Hobby | 0 | 07-22-2019 09:41 AM |
Pre-Order Now - Vanquish Products VS4-10 Pro Kit! | RPP Hobby | RPP Hobby | 0 | 06-18-2019 11:17 AM |
Carpetfuzz's Venture SBK | carpetfuzz17 | HPI Venture | 42 | 04-10-2019 01:32 AM |
