02-07-2021, 11:31 PM | #141 | |
Rock Crawler Join Date: Apr 2014 Location: Portland
| Re: Carpetfuzz's VS4-10 PRO Quote:
Looking Fantastic and all but.. Shouldn't that swaybar link be twisted the other way? The way you have it looks like it might limit articulation. | |
02-08-2021, 08:14 PM | #142 |
Rock Crawler Join Date: Jul 2015 Location: Butler, Pa
| Re: Carpetfuzz's VS4-10 PRO |
02-08-2021, 09:15 PM | #143 |
02-08-2021, 09:41 PM | #144 |
| Re: Carpetfuzz's VS4-10 PRO I see what you see. I did this to get around the shock. The rear sway bar does limit the travel even with the straight rod ends. This is going to be all redone as I have changed the shocks and they are bigger and rub the sway bar.
02-08-2021, 10:30 PM | #145 | |
I see what you saw and get why you did what you did. | |
02-13-2021, 09:07 PM | #146 | |
Rock Stacker Join Date: Jul 2019 Location: Bullard, TX
Sent from my moto g(7) power using Tapatalk | |
02-13-2021, 09:31 PM | #147 |
| Re: Carpetfuzz's VS4-10 PRO I removed some of the inner plastic on the shock towers. Sanded out a spot on the side of the tower for the pre load adjusting ring. I already had the spot on the side done to fit the SSD shocks. Some material inside the tower was removed to fit the SSD again. I just needed to remove a little bit more as the Element shocks are bigger diameter than the SSD. I will get some pictures up tomorrow the truck is out in the garage.
02-14-2021, 02:45 PM | #148 |
Newbie Join Date: Dec 2011 Location: Venezuela
A what brand of bronze/brass ball links that you have on the SSD shocks? My SSD shocks came with chrome ball links and they don’t fit the axle mounts on the VS4-10: Vanquish ball links are shorter. I did swap ball links from the Incisión shocks but they appear to be slightly smaller diameter. (SSD ball links diameter is larger than Incision ones) Any help would be appreciated 😎
02-14-2021, 06:52 PM | #149 | |
Here’s what I used They fit in the SSD rod ends. All I did to get them to fit in the VP axles was file down the sides a little bit on each side till they slipped into place. If you have any more questions please ask away. Sent from my iPhone using Tapatalk | |
03-20-2021, 09:19 AM | #150 |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
Hey Mark. After you sent me the pictures and videos I had to come check out your build thread. I really like how this turned out. the d44's are a great touch.
03-20-2021, 01:39 PM | #151 | |
Hey thanks buddy. It is really a great truck. Stay tuned I have a couple updates to it that I haven’t posted up yet. | |
03-22-2021, 01:02 PM | #152 | |
Newbie Join Date: Mar 2021 Location: USA
03-22-2021, 06:29 PM | #153 |
| Re: Carpetfuzz's VS4-10 PRO I know. You would think that they would have an optional motor plate. I have thought about getting an extra one taking it to a local machine shop to see there is a way to remove some material just for the motor.
Carpetfuzz's VS4-10 PRO - Similar Threads | ||||
VS4 for the 1.9 noob | mikemcE | Vanquish Products VS4-10 Origin | 137 | 04-09-2020 10:01 PM |
Vanquish Products VS4-10 Pro Kit - IN STOCK!! | RPP Hobby | RPP Hobby | 0 | 07-22-2019 09:41 AM |
Pre-Order Now - Vanquish Products VS4-10 Pro Kit! | RPP Hobby | RPP Hobby | 0 | 06-18-2019 11:17 AM |
Carpetfuzz's Venture SBK | carpetfuzz17 | HPI Venture | 42 | 04-10-2019 01:32 AM |
