08-08-2019, 02:46 AM | #1 |
RCC Addict Join Date: Apr 2008 Location: Singapore
| Siggy's VS4-10 Pro |
08-08-2019, 02:47 AM | #2 |
| Re: Siggy's VS4-10 Pro |
08-08-2019, 10:11 AM | #3 |
Orange one looks Grrrrreeeeaaaat! See what I did there? |
08-09-2019, 08:00 AM | #4 |
08-09-2019, 01:33 PM | #5 |
| Re: Siggy's VS4-10 Pro WOW #1! ABSOLUTELY why We Must own and will Surely Enjoy Driving the NEW VS4-10 PRO! The Ultimate is NOT only about lowering CG, or Weight Reduction, or Strength & Reliability, or aesthetics. But a Simple & Straightforward Design, yet Superbly & Surpassingly Smooth - ZERO Bind. Just the way a TRANSMISSION should be Made. Don't have to believe me, TRY It! And yes there is access to grease the Transfer are Gears for Easy Grease Maintenance. Kudos to Team VP Last edited by Siggy; 08-09-2019 at 01:42 PM. |
08-09-2019, 01:58 PM | #6 | |
Rock Crawler Join Date: Jun 2017 Location: Land of burning couches
| Re: Siggy's VS4-10 Pro Quote:
08-09-2019, 02:00 PM | #7 |
Newbie Join Date: Jul 2019 Location: Orange County
Do you believe that gap is due to assembly or manufacturing?
08-09-2019, 02:18 PM | #8 | |
You just need to tighten screws of your VS4 PRO but first be 100% sure gears and shaft are assembled correct and aligned. Careful not to over tighten. And don't forget to grease. Plan is to disable tranny and axles to check and use quality synthetic. It's a new tanny Design - easy to familiarise by assembly and dissemble - checking the manual if there is a bind or driveshaft don't fit. Cheers! | |
08-09-2019, 02:42 PM | #9 |
| Re: Siggy's VS4-10 Pro Yes Assembly but not a problem. I intentionally did not tighten the screws I plan n to dissemble to check all is ok and grease, power motor before installing. Same for axles, same if there will be a bind in the drivetrain. Take out motor and check how it rolls. This is how we have been doing it for almost two decades. Cheers! Last edited by Siggy; 08-09-2019 at 02:46 PM. |
08-09-2019, 03:14 PM | #10 |
08-09-2019, 10:24 PM | #11 |
| Re: Siggy's VS4-10 Pro Front Axle Assembly Bag A1 & A2 |
08-10-2019, 12:13 AM | #12 |
| Re: Siggy's VS4-10 Pro We Put together Left and Right Spindle. And the Front Axle Housing. There was some bind and tightness in fastening screws that secure Spindle to C's. We discovered that the C-Hub chromoly "sleeve" rotated -- did not seating properly. Just carefully fasten the screw, and all is Bind-Free. SWEET! |
08-10-2019, 12:19 AM | #13 |
| Re: Siggy's VS4-10 Pro Fhere also was some bind in the axles. We had to make sure axle cover secured by 4 screws is properly mounted. We loosened then moved fraction a millimetre the cover looking for that sweet spot. Axle is bind Free. Sweet! Plan is to disassemble axles and tranny to grease before final assembly. These axles are very different form the VS4-10 Origin. WOW Factor #2 is the overdrive of the front Axle. That should significantly improve climbing performance. AWESOME! Next Rear Axle. |
08-10-2019, 07:11 AM | #14 |
| Re: Siggy's VS4-10 Pro Totally Different. The New VS4-10 PRO, an Awesomely Delightful Evolution! They should have called VS-Evo! |
08-10-2019, 07:38 AM | #15 |
| Re: Siggy's VS4-10 Pro Vanquish VSEvo |
08-10-2019, 11:21 PM | #16 |
| Re: Siggy's VS4-10 Pro Free Banner Last edited by Siggy; 08-11-2019 at 12:06 AM. |
08-11-2019, 02:15 AM | #17 |
Going Sensored Brushless Motor How many Turns a Sensored Brushless Motor do you guys have installed with the New VS4-10 Pro and VFD Tranny? I have a couple of XR10Pro. How many Turns of the G# Motor is recommended. I also got the Old School HH 7T Cobalt Puller. If it fits, I will probably go with this and a FXR-Pro like what's in my Orange VS4-10 Origin + UMG10. |
08-11-2019, 10:01 AM | #18 |
| Re: Siggy's VS4-10 Pro Try-Out: FXR-R Pro + 17.5R 540 Torquw Brush Motor |
08-12-2019, 03:19 AM | #19 |
08-12-2019, 07:22 AM | #20 |
Siggy's VS4-10 Pro - Similar Threads | ||||
Carpetfuzz's VS4-10 PRO | carpetfuzz17 | Vanquish Products VS4-10 Origin | 152 | 03-22-2021 06:29 PM |
B-MOW goes PRO with the VS4-10 | B-MOW71 | Vanquish Products VS4-10 Origin | 128 | 12-01-2020 06:41 AM |
new2rocks probes the Vanquish VS4-10 Pro | new2rocks | Vanquish Products VS4-10 Origin | 13 | 08-08-2019 11:18 AM |
Celt's VS4-10 Pro | celt | Vanquish Products VS4-10 Origin | 3 | 07-28-2019 07:04 PM |
Vanquish Products VS4-10 Pro Kit - IN STOCK!! | RPP Hobby | RPP Hobby | 0 | 07-22-2019 09:41 AM |
