01-06-2020, 10:58 AM | #41 | |
I wanna be Dave Join Date: Sep 2019 Location: US
| Re: VS4-10 Modular System Official Thread - Info and FAQ's Quote:
~ More peace, love, laughter & kindness would make the world a MUCH better place | |
01-06-2020, 11:40 AM | #42 | |
01-19-2020, 07:17 PM | #43 |
Rock Stacker Join Date: Feb 2018 Location: Ozarks
Pardon my ignorance,, but what would be a good brushed motor wind and pinion for the following config? Trail use mostly with some crawling. I'm probably going to go with something from Team Brood. VFD with 20% overdrive 30/8T Front 27/8T Rear 2.2 wheels with 4.7" tall tires |
05-02-2020, 07:25 AM | #44 |
Quarry Creeper Join Date: Jun 2008 Location: Portsmouth UK
Is the bolt pattern for the rock sliders the same as SCX10 ll?
05-04-2020, 08:26 AM | #45 | |
Yes they should match up. The skid plates can interchange and most rock sliders utilize those same holes. | |
05-17-2020, 03:54 PM | #46 |
Newbie Join Date: Apr 2020 Location: UK
Hi, Not sure if this is the correct section to ask this question Is there a restriction on what shocks will fit between the webs on the chassis mounts. I want to get the VS4 10 chassis and convert my scx10 ii, i'm in the process of buying new shocks for it and don't want to buy anything that won't fit between the sides, ie big bore AE shocks. I will more than likely buy Incision shocks, but it would be good to know. Thanks Last edited by Ross71; 05-17-2020 at 03:57 PM. |
05-17-2020, 07:58 PM | #47 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
Unless the shock sizes are drastically different you should be okay as long as you use incision or similarly sized ball ends. For example, the ball ends from the new axial kits (Capra, scx10.3) won’t fit the VP housings but pop some incision balls in and it’s good to go.
05-18-2020, 03:56 PM | #48 | |
05-28-2020, 08:24 PM | #49 |
Rock Stacker Join Date: Mar 2013 Location: Irwin
I'm building a pieced together truck using VFD tranny, VS4-10 chassis with D44 axles. Would I use Incision Scx10ii rtr driveshafts? Thanks in advance. |
12-05-2020, 07:11 PM | #50 |
Newbie Join Date: Dec 2011 Location: Venezuela
I can’t find anywhere info on the maximum length of 540 motor that will fit the VFD Transmission? Hobbywing came out with new 540L motors that are longer. Would like to know what’s that maximum space available?
12-06-2020, 06:55 AM | #51 |
Quarry Creeper Join Date: Nov 2016 Location: Switzerland
The 540L does fit, but you need to remove some material from an upper link mount. Else the transmission wont fit anymore. Someone on rockcrawler.de made it work. https://www.rockcrawler.de/thread/38...27#post1382827 Just get the "old" Hobbywing combo with 2300kv. I run this combo in the pro and it is great! |
12-06-2020, 10:20 AM | #52 |
Thanks Grim I just bought the 540L 2100kv on Black Friday 15% discount. Still deciding go dump $750 on the Vanquish Pro lol.
04-09-2021, 03:31 PM | #53 |
Rock Crawler Join Date: Dec 2005 Location: Hawaii
will a VFD trans/skid bolt in to a SCX10ii chassis with little to no mods?
04-09-2021, 10:38 PM | #54 | |
Pebble Pounder Join Date: Mar 2020 Location: Maine
The VFD skid won't bolt up to the stock Axial SCX10 ii rails and the VFD transmission would also require you to change the front axle to one with an offset pumpkin. You may be able to grind down enough of the skid to get it to fit in the rails but there's no way of getting around the axle issue other than to swap it. Also, for those that have asked, the distance between the VFD motor plate and the transmission is 59.75mm measured with calipers so that would be the longest motor that would fit. If you're using a brushless motor that has the sensor wire coming out of the end of the motor you'd need to consider that in the overall length since clearance could be an issue. Last edited by mjensen; 04-10-2021 at 03:23 AM. | |
04-10-2021, 01:46 AM | #55 | |
Thanks. If it were possible to put the VDF in the SCX10 ii I would have either gone SCX10 iii straight axles or use a SSD offset pumpkin housing for the AR44s Sent from my iPhone using Tapatalk | |
11-20-2022, 08:16 AM | #56 |
Pebble Pounder Join Date: Nov 2015 Location: Switzerland
Can anybody confirm that the SCXII Rock Jock Axles will fit in VS410 Phoenix? Thanks! |
11-20-2022, 09:13 AM | #57 | |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
They will bolt up no problem, but you will have driveshaft issues if running the vfd. Rockjock housings are center diff front, vfd requires an offset diff. Sent from my iPhone using Tapatalk | |
11-20-2022, 09:29 AM | #58 |
Great to see this thread pop up! I completely forgot that Brandon started this. Looks like it needs some updating! A lot has happened over at VP since the last updates! |
11-20-2022, 10:39 AM | #59 |
Thanks Twade! Dumb question! It‘s obvious that there are issues with the driveshaft! Yes, some updates are required. |
12-23-2022, 11:15 AM | #60 |
Quarry Creeper Join Date: Dec 2022 Location: Akron, Ohio
Great thread, I'm a newbie and this info will help tremendously. Thank you.
VS4-10 Modular System Official Thread - Info and FAQ's - Similar Threads | ||||
**Official** 2009 Pro-line World Championships Info | KING BLING | RC Rock Crawling Worlds | 181 | 08-26-2009 06:01 PM |
**Official Thread** 2009' Axial West Coast Championships Signups & Info | KING BLING | Past RCCA qualifiers | 221 | 06-24-2009 12:38 AM |
2008: USRCCA Official Rules Info | Fishmaxx | WRCCA Rules | 72 | 02-12-2009 06:28 PM |
