02-08-2021, 11:04 AM | #21 |
Quarry Creeper Join Date: Nov 2016 Location: Switzerland
| Re: Motor options for VS410 Pro
Yay. Pictures Medium should be fine. I aim for 800 px width in this forum. |
05-12-2021, 04:40 PM | #22 |
Rock Crawler Join Date: Apr 2020 Location: Drums
Maybe I missed some details here but can you fit the Hobbywing Quicrun Fusion FOC in the VS410 Ultra?
07-11-2021, 12:26 PM | #23 |
Quarry Creeper Join Date: Jan 2021 Location: in the Canyon
Required trimming to fit an AXE 540L, which is 58mm long, and the Fusion is 64mm long, so I'm gonna say... nope. In the photos, it looks like there's ~2mm between the end of the can and the transfer case. Which is a shame, as the Fusion is a fantastic setup.
07-11-2021, 02:40 PM | #24 |
Pebble Pounder Join Date: Mar 2020 Location: Maine
To fit the Fusion you could do what a number of people have said they've done and remove the red end cover on the motor and it will fit but there is a component of the built in ESC that has a thermal pad on it that rests against that cover so the cover may be acting as a heat sink. Some of the early reviewers claimed the Fusion ran a bit warm so removing the end cover may cause issues but none the folks that have done this have reported one way or the other. Or you could go nuts and do what I did. Make a longer top shaft for the transmission, longer standoffs for the motor plate, and a new skid and have what Vanquish should have made in the first place, a transmission that will accommodate any 540 or 550 can motor. |
12-27-2021, 03:59 PM | #25 | |
Newbie Join Date: Dec 2021 Location: Wilsonville
| Re: Motor options for VS410 Pro Quote:
12-27-2021, 04:48 PM | #26 | |
Rock Crawler Join Date: Mar 2021 Location: Santa Barbara
12-30-2021, 03:35 AM | #27 | |
To be honest I built that transmission to go into a custom chassis. To get it to fit into the Vanquish Ultra chassis would require a new skid, front motor mounts, and steering servo mount at very least. I expect the Phoenix would be the same. If you want to use an all in one combo you might check out the new Spektrum motor/esc combo which I believe is shorter than the Hobbywing and may fit. Last edited by mjensen; 12-30-2021 at 03:58 AM. | |
12-30-2021, 03:57 AM | #28 | |
I had a brief explanation over in my VFD Capra build thread. VFD Capra...Can I Still Call It A Capra? It worked great and was pretty easy to do with some pretty simple tools. The most critical thing is getting the spacing of the 2mm cross pin holes on either end of the shaft right. I eventually found someone to machine me some custom one piece shafts but I still have the one I made in one of my VFD transmissions and it works as well as the custom ones. | |
Motor options for VS410 Pro - Similar Threads | ||||
Mamba Max Pro motor options.. opinions wanted. | morg59jeep | Team Losi Comp Crawler | 24 | 11-27-2009 11:17 AM |
