12-25-2019, 01:37 PM | #1 |
Quarry Creeper Join Date: Dec 2015 Location: Norway
| Bolt pattern vs410 sliders
Would the vs410 pro sliders fit an axial chassis?
12-27-2019, 08:08 AM | #2 |
| Re: Bolt pattern vs410 sliders
They should fit if you use these together: https://www.vanquishproducts.com/vs4...versal-slider/ https://www.vanquishproducts.com/origin-rock-sliders/ |
12-31-2019, 07:02 AM | #3 | |
| Re: Bolt pattern vs410 sliders Quote:
12-31-2019, 09:09 AM | #4 |
Here is a step pulled from the VS410 Pro manual. It shows how both parts are used. You can see the Slider mounts in step 4 already mounted to the chassis. Then the Origin sliders bolting to those. If you use the Vanquish slider mounts they will bolt to a SCX10 chassis, then the Origin sliders can be used with a SCX10. The Origin sliders by themselves will not fit a SCX10. That help? |
12-31-2019, 10:13 AM | #5 |
Thanks |
01-09-2020, 10:45 PM | #6 |
Quarry Creeper Join Date: Nov 2018 Location: So Cal
A related question... Are the Origin Plastic sliders (VPS10124) wider than the universal sliders that come with the VS4-10 chassis kit? The universal sliders on my VS4-10 chassis kit are about 1/4" to 3/8" too narrow for the ProLine Toyota HiLux SR5 body I am running. Wondering if the Origin Plastic sliders will make it all the way out to meet the SR5 body width. I think they are a little too long for my front-cab only rig, but could probably cut them down to fit length-wise. |
01-10-2020, 09:39 AM | #7 |
Origin sliders are about 1/2" or 13mm wider per side. That may reach beyond the width of the SR5 body which would be ideal because they are designed with a groove for the body to rest in. Ive seen the SR5 on the VS410 with the Origin sliders before and it looked good. I would assume the length was trimmed to fit accordingly. |
Bolt pattern vs410 sliders - Similar Threads | ||||
Injora wheel hub bolt pattern. | Lukescb7 | Tires and Wheels | 1 | 05-07-2018 11:34 AM |
Wheels with axial 1.9 6 bolt beadlock pattern? | Grandbuggy | Tires and Wheels | 6 | 03-30-2017 01:02 PM |
bolt pattern for ax10 and wraith trannie | Oregon crawler | Axial Wraith | 1 | 03-28-2013 02:30 AM |
bolt pattern? | 27cameron | Axial AX-10 Scorpion | 3 | 08-12-2009 11:02 AM |
ford wheel bolt pattern | wheelspinner | Chit Chat | 5 | 08-03-2007 08:39 AM |
