03-11-2020, 12:38 PM | #1 |
RCC Addict Join Date: Jan 2009 Location: Bend
| Diving in head-first...here we go!
Ordered a Pro and some goodies the other day. We'll see where this one ends up... My kit and most of the parts should begin arriving tomorrow. No real plan for this one beings I just overthink everything anyway. Just, doing it. Kit: -Vanquish Products VS4-10 Pro (Clear) Kit Upgrades: -Vanquish Origin Body Set -Vanquish Products VFD Aluminum Light Weight Motorplate (Clear) -Vanquish Products VFD Dig Unit -Vanquish Products 21% Overdrive Gears -Vanquish Products VS4-10 Shock Towers (Silver) -Vanquish Products VS4-10 Panhard Mount (Clear) -Vanquish Products 20mm Servo Horn (25T) (Steering) -Vanquish Products 24mm Servo Horn (25T) (Dig) -Vanquish Products 12-14T 32P Pinions (15T Included In Kit) -Team KNK VS4-10 Pro Stainless Hardware Kit Wheels & Tires: -Vanquish Products Method 105 (Silver/Black) -Vanquish Products Original Beadlock Rings (Blue) -Vanquish Products SLW Hubs (Raw, .225 & .350, X4 each for tuning) -Axial 1.9 Falken Wildpeak MT -Crawler Innovations Deuces Wild Closed Cell Foams (Mad Beast Size) Electronics: -TX/RX: Futaba 4PM with R334SBS S.Bus2 RX -Motor: Holmes Hobbies 2700KV Puller Pro V2 -ESC: Castle Mamba X with Castle Futaba S.Bus2 Telemetry Module -BEC: Castle 10 Amp Coated With Acrylic Conformal Coat (Powering Seering Servo...Mamba X 8 Amp Internal Unit Powers The Dig Servo And Light Kit @ 6V) -Steering Servo: Protek 370TBL Black Label -Dig Servo: Protek 100T -Light Controller: Powershift RC Technologies PST 2 Position Switch W/12V Booster -Light Kit: Powershift RC Technologies VS4-10 Origin OEM Light Kit -Batteries: Turnigy Nano-Tech 45-90C 2200 3s Last edited by 89redranger; 03-22-2020 at 01:36 PM. |
03-11-2020, 01:10 PM | #2 |
| Re: Diving in head-first...here we go!
Congrats! The VS4-10's are fun builds! You got lots of good stuff.
03-11-2020, 01:12 PM | #3 |
Quarry Creeper Join Date: Mar 2014 Location: san antonio
Sweeeet! Looking forward to seeing another build. Sent from my iPhone using Tapatalk |
03-11-2020, 01:19 PM | #4 | |
| Re: Diving in head-first...here we go! Quote:
03-11-2020, 01:23 PM | #5 |
I have to say, I’ve built probably 5-6 axial kits, a couple Venture SBKs, and an Element kit prior to buying my Pro. It’s been the most enjoyable build for me to date. Everything goes together as it should and I enjoyed the build a ton. Sent from my iPhone using Tapatalk |
03-12-2020, 03:30 AM | #6 |
Rock Crawler Join Date: Jan 2012 Location: Vitoria-Gasteiz
| Re: Diving in head-first...here we go! |
03-12-2020, 06:08 AM | #7 |
| Re: Diving in head-first...here we go! There are still Limited kits out there, but I think you made the right choice with the Pro.
03-12-2020, 06:08 AM | #8 |
Congrats! My favorite build so far! Looking forward to following along with the build! |
03-12-2020, 08:08 AM | #9 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
Congrats on the grab! Glad you landed in a good place. Always good to hear for a fellow RC’er. I agree with the others, my cobbled together VS4-10 Pro is one of my favorite rigs too drive and it was an enjoyable build. Good looking parts list there, however I am curious as to the tire choice, have you had good luck with those tires? I’ve never ran them myself but thought it was interesting to see an rtr tire over the other options out there. |
03-12-2020, 09:26 AM | #10 | |
I also run Wildpeak MTs on my real rig ('97 Kia Sportage, 4" lift, 30x9.50r15s on 15x7s), my girl just ordered the same tires for her real rig (also a Sportage), and my kids have Falkens on their Barrage Gen 2s. Just continuing the trend. Sent from my SM-S767VL using Tapatalk | |
03-12-2020, 11:22 AM | #11 |
That makes sense! Scale wins sometimes, especially when it matches 1:1. Looking forward to seeing the build |
03-12-2020, 12:05 PM | #12 | |
03-12-2020, 12:14 PM | #13 |
I may give them a shot sometime. I’m in the same boat as being tired of the bloated class 2 XL tire size.
03-13-2020, 03:09 AM | #14 |
Just got my kit about 4:30 this afternoon...it's 2:09 AM now. Chassis, axles, and trans are together. Shocks need oil still, bumpers and sliders need installed, and I need to get some shims for the front spool and pinion. The included 0.2mm units didn't cut it and the spool has about 0.5mm slop side to side. Going to take advantage of that by shimming the pinion and spool both in tight. Feels like there might be a little room for the shims on the rear pinion to be moved inside the housing to tighten up the lash back there as well. Otherwise, this is an amazing kit to build. Time for me to head to bed though. More parts arrive tomorrow! Sent from my SM-S767VL using Tapatalk |
03-13-2020, 04:40 AM | #15 |
Excellent work . It is a car that does not make you want to stop riding, I loved it, I have not yet released the PRO and I am already thinking of an ULTRA ...
03-13-2020, 06:17 AM | #16 | |
I didn't put any shims inside the axles and my kit didn't come with any. I didn't think it was necessary. I did use the included shims between on the output shafts of the axles between the housings and the driveshaft. I haven't had any luck with the "new" R35 compound tires even with different foams. The old R35 compound, like on the Ripsaws, performed much better for me. | |
03-13-2020, 09:51 AM | #17 |
One thing I wanted to note...I hate slop BTW...the transmission, while a very nice piece of engineering, does have a bit of slop in the top shaft and outputs. This can easily be cured by swapping the stock slipper eliminator spacer for a total of 4 Traxxas 5x8x0.5mm fiber washers. I used two behind the top shaft bearing to push the top shaft completely into the trans, which fully engages the pin in the top shaft with the top shaft gear. The other two fiber washers can be used behind the slipper eliminator hub just like the stock spacer. I have also shimmed the outputs tight with the same washers. One between each drive shaft and bearing. And the results are quite nice. No in/out slop in the shafts, full pin engagement in your gears, and it's silky smooth. Sent from my SM-S767VL using Tapatalk Last edited by 89redranger; 03-13-2020 at 04:06 PM. |
03-13-2020, 10:44 AM | #18 |
Good info! I'm far too lazy and impatient to try to take the slop out of everything. Sometimes finding the correct spacer or shim is a chore.
03-13-2020, 11:00 AM | #19 | |
The one size I don't have is for those damn spool bearings. A 7mm inside diameter is hard to find. Going to have to try to find some with a 14mm outside diameter to match the bearings, and shim the bearings in on the spools. I'll be sure to post up some parts numbers when I find something suitable. Sent from my SM-S767VL using Tapatalk | |
03-13-2020, 02:35 PM | #20 |
Got all the hotrod parts installed and the car is a complete rolling chassis now. Waiting on foams and electronics. Still gotta decide on a motor and batteries and order them also. Also have to do some hacking on the rear body posts. The billet shock towers won't allow the rear body mount posts to drop any lower. Time to get out the Dremel and get creative. Sent from my SM-S767VL using Tapatalk |
Diving in head-first...here we go! - Similar Threads | ||||
I'm diving in! TF2 or Dingo..hmmm | Indetrucks | Newbie General | 21 | 01-22-2014 12:17 PM |
Celebrity diving....Really!!! | RiceBurner | Chit Chat | 3 | 04-06-2013 07:52 PM |
Commercial Diving with Griz | Grizzly4x4 | Chit Chat | 35 | 09-18-2010 10:30 AM |
Sky Diving? How about Space Diving? | Bryan732 | Chit Chat | 0 | 07-15-2010 07:31 AM |
Diving Accident NSFW | K_Willis | Chit Chat | 24 | 09-19-2009 08:31 AM |
