Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vanquish Products VS4-10 Origin
Thread: It has begun! Doc Hamilton’s VS4-10 Pro
Old 04-08-2020, 05:15 PM   #21
Default Re: It has begun! Doc Hamilton’s VS4-10 Pro
Decisions, decisions, decisions...
Which wheel/tire setup do I use? AND, I have a set of Vanquish Method wheels arriving tomorrow. I’m going to mount them to the tires that came with the kit.
I have had these sets for over 7 yrs! I purchased them for a couple builds I was going to do. I’m going to resurrect one and build a new SCX10 ii for Axialfest in June! I’m fairly certain that I will not be using any of these on this rig. I just wanted to see what the possibilities are...
doc.hamilton is offline   Reply With Quote
Old 04-08-2020, 05:18 PM   #22
Originally Posted by JatoTheRipper View Post
Warped as in out of round or won't lie flat on a table? Mine was out of round, but it's usable. I just had to ensure it was centered on the shaft.
BTW - I agree with what the others are saying about bumpers. You want plastic bumpers so they slide on the rocks. The plastic also flexes a bit when hitting something instead of stopping you dead.
Thanks Jato!
Perhaps a bumper can be 3D printed? I’ll pause on the bumper for right now.
Cheers
Doc
Old 04-10-2020, 09:17 PM   #23
Decided on wheels... Vanquish Method - the first two went together real smooth. The second set, took quite awhile, as the tire bead kept slipping out. It was frustrating but a lesson in patience.
Last edited by doc.hamilton; 04-10-2020 at 09:22 PM. Reason: Forgot to include the photo
Old 04-10-2020, 09:32 PM   #24
Here’s tonight’s progress...
I’m wondering how I can lengthen the wires from the motor...
Old 04-10-2020, 09:33 PM   #25
Of course I just realized that I neglected the motors sensor wire! Ugh... and it’s stupid long too. I’ll see if I can get a shorter one.
Oh well.
Cheers
Doc
Old 04-11-2020, 04:13 PM   #26
Have you noticed a fair bit of toe-in on your Pro build? Just curious since we're building at the same time.
Shinook is offline   Reply With Quote
Old 04-11-2020, 08:12 PM   #27
I have - though I think if I back out the ends of the steering link a couple turns it may solve that?
Keep me posted!
Today I spray painted the fender wells.
Cheers
Doc
Old 04-11-2020, 08:28 PM   #28
Keep me posted!
Cheers
Doc
I adjusted the frontmost rod, I think it's the drag link? I opened both sides about one to one and a half turns, it seems to have straightened it out. It was pretty dramaticly toed in.
I'm not sure if that's the right bar to adjust, it's just what I started with.
Old 04-12-2020, 06:43 PM   #29
Thanks Shinook!
I’ll give that a try. I’m going to do a test run on my electronics tomorrow... Btw - I like how you placed your esc and receiver box
I know, I know I should have done that already but
Cheers
Doc
Old 04-12-2020, 07:07 PM   #30
Thanks Shinook!
Thanks.
I considered running the receiver to the fuel cell in the back, but it not being waterproof and running the FS-BS6, I wanted to keep it in a box. I stole the Traxxas idea from Jato, my only gripe is that it can't be bolted in, I had to use servo tape, which wasn't ideal, but it will be easier to remove/install than removing the battery tray and all the bolts for the panels. A pleasant surprise was the structure of the box, which is different than the stock one on my TRX4, the aftermarket one I used was more compact and slightly neater to wire.
The ESC was tricky to position, there isn't a ton of space with the battery mount in place, that's the only way to mount it that fits easily. The Mamba X is larger than my HW1080, so that was a bit of a surprise.
Jato also mentioned he had the same issue with the steering, he put spacers in to close the gap, which I may do also once I get it dialed in. LMK how you manage, I think I took around a turn to turn and a half out on each side.
Old 04-20-2020, 03:11 PM   #31
Small update:
And did I mention how much I am enjoying putting this kit together? This has been so much fun!
Onto the snaps...
Old 04-22-2020, 10:15 PM   #32
Congrats Doc, looks like such a fun build. Love the wheel choice, but Im partial to that model. I need to pick up a VS4-10 of my own. Maybe after I finish rebuilding my TRX4.
CLOUT is offline   Reply With Quote
Old 04-23-2020, 07:21 AM   #33
Go Buckeyes!
B-MOW71's Avatar
Build is coming along great!
Nice wheel choice!
B-MOW71 is offline   Reply With Quote
Old 04-26-2020, 08:46 AM   #34
Paint!!! Not my best job, not my worst either...
I’m painting the grill, door handles, wipers & light buckets silver
Old 04-26-2020, 02:32 PM   #35
Dude, that came out fantastic! Did you use rattle cans? Duratrax or Tamiya?
Wish I could do mine two-tone but I really suck at painting. That is the part of the build that I'am most concerned with... I'm even scared to paint the fenders!
el_Fernando is offline   Reply With Quote
Old 04-26-2020, 05:16 PM   #36
Thank you!!!
I used Tamiya spray. The bear was masking off the interior. I wish I could redo that. The interior looks ok, but the rear bed... ugh. I may try to repaint it on the exterior. I wish I could purchase just the interior from Vanquish.
Cheers
Doc
Old 04-30-2020, 07:13 PM   #37
Well I got my electronics sorted out. Shortened the wires from the motor, a friend shortened my BEC wire, and, well, it’s alive!!!
Also painted the detail pieces... ordered the “Scout” badges to help complete the rig!
Old 05-01-2020, 08:03 PM   #38
It’s all in the details!
Old 05-01-2020, 08:07 PM   #39
First time outdoors!
Old 05-31-2020, 09:34 AM   #40
what holes did you use to mount the spur, maybe a pic, thanks
sgtlt is offline   Reply With Quote
It has begun! Doc Hamilton’s VS4-10 Pro - Similar Threads
Vanquish VS4-10 Pro vs SSD RC Trail King Pro Panther6834 General Scale Talk 23 11-30-2019 10:51 PM
VS4-10 pro J55TTC Videos! 0 08-22-2019 09:29 AM
Assaulted-New Pro Gun Rights Doc Needs Our Help SMR 510RR Chit Chat 3 10-04-2012 12:50 PM
