Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vanquish Products VS4-10 Origin
Thread: Installed 80mm Big Bores on my Ultra.
Old 05-27-2020, 02:21 PM   #21
Default Re: Installed 80mm Big Bores on my Ultra.
Here we go! Built another set of these fantastic 80MM shocks for my Class 1!
Step 1) Identify the section you'll be filing off:
Step 2) File away! I start with a coarse file to get close and a jewelers flat file to finish it off. I do not flatten the top:
Step 3) Identify the inside dimple you'll be drilling:
Step 4) Drill away. I start with a small 3/32 or 1/16":
Step 5) Finish the hole off with a 3mm drill and prepare for installing the rod end:
Step 6) Use a generous amount of thread locker inside, install the screw, wipe any threadlocker off that is now outside the cap, and install the rod end:
Step 7) Finish building your shocks and your newly modded caps:
*Note - the shafts are slightly long for the bodies. I use about 3/16" of silicone fuel tubing.
GTSLOW is offline   Reply With Quote
Old 05-27-2020, 02:55 PM   #22
I didn't think you were supposed to use thread lock on plastic.
GA Dawg is offline   Reply With Quote
Old 05-31-2020, 03:46 PM   #23
This is great!
I ended up using a very slightly different method:
1) I hacksawed off the original hoop (I hear dremel cutting wheels are quicker for this), filing down any burrs.
2) Then I drilled with a 7/64" bit, and tapped for M3 (this part isn't great, maybe 3/32" would work a little better, an M3 tap wants 2.5mm, 3/32"=2.38mm, 7/64"=2.78mm)
3) Screw on the rod end, add oil & bleed.
I've heard of using thread lock to seal the hole, but shouldn't the diaphragm be doing that anyway? I attempted to use shoe goo, but had issues getting something I thought would seal while not gumming up the cap threads...
Munchagepeople is offline   Reply With Quote
Old 05-31-2020, 04:49 PM   #24
Moderator
JatoTheRipper's Avatar
It can make some plastics brittle.
Old 07-20-2020, 06:16 AM   #25
JPP
Are you using front or rear mini-T springs?
Thanks in advance!
JPP is offline   Reply With Quote
Old 08-04-2020, 10:36 PM   #26
I should have clarified that. The intended purpose of the threadlocker is to lock and seal that screw in place from the inside. No thread locker was actually used on rod end.
Originally Posted by Munchagepeople View Post
This is great!
Awesome! Have any pictures of how yours turned out?
Thanks in advance!
Hot Racing Losi Mini T 2.0 Linear Rate Front Spring Set MTT30FS148
This is the set I'm using. Spring rates feel the same as your typical Losi brand set. However, the colors are much more astheticaly appealing.
Sent from my SM-N960U using Tapatalk
Old 08-04-2020, 10:39 PM   #27
Small update! I've now designed three additional shock cups. So we have 0, 2, 4, and 6mm preload. Essentially it's lime having an adjustable shock collar. Since mine have a slot you can change them on the fly too. Pics tomorrow....
Old 08-18-2020, 09:02 AM   #28
I'm kinda happy with how mine turned out:
I did hope that the diaphragms would stop any leaking without resorting to thread lock or shoe goo, but that wasn't the case and I need to tear them apart and fix that. Only one shock is leaking, so I guess my drilling/tapping was better on the other 3 caps
Old 08-23-2020, 05:23 PM   #29
These shocks have become quite popular locally. I've modded a few for friends. I would HIGHLY advise installing the fuel tubing on the shock shaft. The top of the shaft will impact the diaphragm and potentially cause leaks from the cap area.
I have not seen one leak yet with the fuel tubing mod.
NOTE: A friend installed a set on his VS4-10 Pro and they are SICK!
Old 08-24-2020, 08:27 AM   #30
The tubing is a good idea -- increasing the height of the spring cups by 3/16" should have the same effect, no? (I have a .stl for the cups and a 3d printer, but no fuel line )
Installed 80mm Big Bores on my Ultra. - Similar Threads
Traxxas Big Bore in 80mm? GTSLOW General Crawlers 26 04-09-2020 05:21 PM
