08-18-2020, 06:17 PM | #1 |
Rock Crawler Join Date: Mar 2008 Location: Plainfield
| Dravtech spring rates?
Anyone running Dravtechs on their vs4-10? I’m knee deep in converting my scx10.3 to a pro chassis w/ vfd. I’d like to use the dravtechs but not sure what springs to start with. I have a set on a speed build but I think the mini T front springs will be too soft. Lou |
08-20-2020, 07:39 PM | #2 |
Quarry Creeper Join Date: Dec 2013 Location: NoVa
| Re: Dravtech spring rates?
On my Ultra, I'm running firm on front with medium rear. I do have steel bumpers & run a 5000mah battery.
09-01-2020, 09:26 PM | #3 |
I got the Mini T rear spring set, I was told on FB to run medium up front, firm in the rear. What oil are you using? Lou |
09-01-2020, 09:47 PM | #4 |
Quarry Creeper Join Date: Nov 2018 Location: So Cal
I'm not running actual Dravtech shocks but I do use Dravtech springs on TRX-4 shocks with the Dixieland RC shock mod that allows you to use Mini-T sized springs. I prefer to use the Dravtech softs front and rear on my lighter rigs, but on a heavier rig like a VS4-10 or TRX-4, I like to use the Dravtech Mediums front and rear. I collected the following from the Dravtech website which includes spring rate details and comparisons between Losi Mini-T springs and the Dravtech springs. Hope this is helpful. Mini-T Springs / Dravtech Springs Dravtech Ultra soft is softer than Mini-T pink Dravtech Soft is the same as Mini-T pink Dravtech Medium is the same as Mini-T red Dravtech Spring Colors: Ultra soft = white Soft = Black Medium = Red Hard = Green DravTech Springs compared to the Losi Mini-T front springs in regards of spring rate PN Color lbs/in. N/mm Notes DravTech White .40 lbs./in 0.07 N/mm Ultra Soft Losi Pink .74 lbs./in 0.13 N/mm DravTech Black .79 lbs./in 0.14 N/mm Soft Losi Red 1.43 lbs./in 0.25 N/mm Dravtech Red 1.43 lbs./in 0.25 N/mm Medium Losi Orange 2.00 lbs./in 0.35 N/mm DravTech Green 2.00 lbs./in 0.35 N/mm Hard |
Dravtech spring rates? - Similar Threads | ||||
Spring rates. | jeepd77 | Traxxas Crawlers | 0 | 10-29-2015 07:59 PM |
Spring rates... | simon170 | General Crawlers | 3 | 12-01-2010 09:57 PM |
Leaf spring kits and spring rates | BansheeManiac | Axial SCX-10 | 2 | 09-22-2010 02:23 PM |
What spring rates to use? | Flatty | Axial AX-10 Scorpion | 5 | 05-08-2008 04:12 PM |
spring rates? | carzlutt | Tamiya Clod Buster | 5 | 11-06-2007 03:21 PM |
