01-15-2021, 01:03 PM | #1 |
Newbie Join Date: Mar 2016 Location: Royal Oak
| Rear portal OD?
Looking at building a rear portal / standard front axle. Watched Harleys build where he used portal OD gears in the rear to balance out the gearing, but looking at all the Vanquish site, says the OD gears are recommended for front axle only? Any reason why?
01-15-2021, 02:31 PM | #2 |
Quarry Creeper Join Date: Aug 2014 Location: holland
| Re: Rear portal OD?
Have to look it up but In assume it has to do with Gear reduction in the portals. Without overdrive gears installed the overdrive (as result of the portal reduction) will be over the top. Over driving the rear will bring the front- and back axle speed somewhat closer together. I think.... |
01-15-2021, 03:29 PM | #3 |
| Re: Rear portal OD?
I guess I should ask if there’s a “fit” issue? OD gears should fit the rear portal housings, right?
01-16-2021, 03:08 PM | #4 |
Pebble Pounder Join Date: Feb 2019 Location: SIGNAL MOUNTAIN
| Re: Rear portal OD?
Might want to ask Topher about this. I believe he has built up a straight front, portal rear rig.
01-21-2021, 11:55 PM | #5 |
Rock Stacker Join Date: Sep 2018 Location: boise
| Re: Rear portal OD?
Yes overdrive gears will work in the rear. They go in the portal boxes, which are the same gear configuration.
Rear portal OD? - Similar Threads | ||||
SCX10.3 Rear Portal Housing swap possible? | joaquinriviera | Axial Capra | 7 | 05-18-2021 07:32 PM |
Brandon's VS4-10 Rear Portal Yota Build | Brandon | Vanquish Products VS4-10 Origin | 61 | 04-03-2020 12:21 PM |
Rear portal bearing missing | Vinman02 | Traxxas TRX-4 | 4 | 09-20-2017 02:39 PM |
