01-13-2023, 08:42 AM | #101 |
Rock Crawler Join Date: Jan 2012 Location: Vitoria-Gasteiz
| Re: B-MOW's BF VP Bundle Build - VS4-10 Style
Oh yes , so pretty build !! love it !!
01-13-2023, 09:16 AM | #102 |
| Re: B-MOW's BF VP Bundle Build - VS4-10 Style |
01-13-2023, 09:36 AM | #103 |
I worked on the interior last night. I decided to use the Element Gatekeeper interior. Since I ended up buying 3 Gatekeeper Builders Kits last year, I've got a couple spare interiors floating around here. Had to chop most of the outer edges off in order to fit inside the narrow cab of the '35 Hot Rod Truck. Painted the underside Tamiya PS-5 Black, then used the film on top and cut around the drivers. Sprayed both with Tamiya PS-63 Bright Gun Metal to match the outside color and then topped the whole interior with Tamiya PS-55 Flat Clear to dull the shiny look. Installed the Twisted Tree RC skull whip antenna and hung the green "lucky" dice on the rearview mirror that was included with the dice. Put a dab of E6000 on the mirror to hold it to the inside of the windshield. Decided to go with the skull, well, because it matches the Rock Pirates RC pirate logo! The interior is held in with a few strips of Velcro. I cut out the side windows and added the LEGO netting to each window opening. This LEGO netting is the perfect scale and looks great! I held the netting in place with a few drops of black hot glue on the top and bottom of the netting. If you look closely at the picture you'll see what I did!!! |
01-13-2023, 12:05 PM | #104 |
Quarry Creeper Join Date: Dec 2022 Location: Akron, Ohio
That's a kick ass hot rod, that skull needs a stogy. I hope to see pics in the sticky of it on the roll. |
01-13-2023, 01:31 PM | #105 |
01-13-2023, 05:36 PM | #106 |
RCC Addict Join Date: Nov 2017 Location: 3rd rock pile on the right
Man, this has got to b one of my fav builds of yours brian. Nice touch with the netting in the windows. Ive seen a few of the 35 ford truck builds, im thinkin of pickin up the 33 coupe for a build |
01-13-2023, 06:13 PM | #107 |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
01-13-2023, 06:47 PM | #108 |
RCC Addict Join Date: Dec 2012 Location: Crookston
That thing is wicked looking. Love it. |
01-13-2023, 07:20 PM | #109 |
Rock Crawler Join Date: May 2021 Location: NorCal
Finishing touches are amazing!
01-14-2023, 09:09 AM | #110 | |||
First off, thanks for the kind comments guys! This scheme was really a struggle and I had to dig deep to figure it out. Just glad it turned out half way descent! Quote:
Thanks much Tom! It does look mean! I've got more detailing to do to make it look even better! Thanks Ballistic! Thanks Goro! More finishing touches are planned! | |||
01-19-2023, 02:18 PM | #111 |
Quarry Creeper Join Date: Dec 2021 Location: Glendora
Rock Pirates SS rails coming for my Phoenix Portal build based on how great yours turned out.
01-21-2023, 06:54 PM | #112 |
01-24-2023, 11:11 AM | #113 |
Received the frames and compared them to the stock ones. This set me into a deep thought mode (rare). I don't mind part substitutions and deviations from the stock configuration but I want these two Phoenix builds to be somewhat stock. But, I like the RP frame and shock towers and want to use them. So I'm thinking of a hybrid frame approach where I maintain the front and back sections of the stock frame but use the central section of the RP frame. Don't know if it will work but we will carefully move in that direction. Pics forthcoming unless everything is trash. Oh what the hay, pics forthcoming regardless.
01-25-2023, 06:24 AM | #114 |
01-25-2023, 10:09 AM | #115 |
01-25-2023, 02:06 PM | #116 |
| Re: B-MOW's BF VP Bundle Build - VS4-10 Style Not sure which way to go (bootie look familiar Twade?). RP gives a bit more low weight. VP has holes in correct positions (not a big deal). |
01-25-2023, 03:59 PM | #117 |
Pebble Pounder Join Date: Dec 2008 Location: Close
One thing I hate about the stock vs410 frame is how the front and rear dip down so low. To me that's the biggest advantage the RP rails have. I just chopped the front off one of my vs410 frames to get better approach angle and fit with the body I'm using on it.
01-25-2023, 05:06 PM | #118 |
| Re: B-MOW's BF VP Bundle Build - VS4-10 Style No bumpers then?
01-25-2023, 05:38 PM | #119 |
01-25-2023, 08:05 PM | #120 |
Rock Crawler Join Date: Jan 2022 Location: st louis
Holy hell, I need to long on more often DAMN THAT CAME OUT SWEET!!! Sent from my SM-S906U using Tapatalk |
B-MOW's BF VP Bundle Build - VS4-10 Style - Similar Threads | ||||
B-MOW's GSPEED V1-C1 Mojave Class 1 Build | B-MOW71 | 1.9 Scale Rigs | 148 | 03-12-2024 09:46 AM |
B-MOW's VS4-10 Phoenix Portal | B-MOW71 | Vanquish Products VS4-10 Origin | 159 | 12-30-2023 12:28 PM |
B-MOW's Element GK-Ecto-Knightrunner Build | B-MOW71 | Element RC 1/10 Enduro Trail Truck Sendero | 210 | 11-24-2023 04:40 PM |
B-MOW's VS4-10 Origin Limited | B-MOW71 | Vanquish Products VS4-10 Origin | 40 | 09-15-2023 06:18 AM |
B-MOW's GSPEED V3 VS4-10 Origin VFD Build | B-MOW71 | 1.9 Scale Rigs | 99 | 07-06-2021 09:22 AM |
