04-28-2015, 01:25 PM | #61 |
| Re: What to do. Won't stop breaking |
04-28-2015, 04:42 PM | #62 |
Rock Crawler Join Date: Feb 2012 Location: Tennessee
I don't own an Ascender yet, but I do own a Twin Hammer (basically the same axles) and a couple of my buddies have the Ascender. Just an opinion, but from what I can tell with these rigs the steering angle that they can achieve is too much for the axles to take, especially under power like trying to right your truck from a roll over. Setting the steering endpoints to a more realistic angle can only help. Again just my thoughts on this. |
05-04-2015, 08:34 AM | #63 |
Newbie Join Date: Jan 2015 Location: crawlorado springs
Got my HD r&p's installed this past Friday that Rich sent me, then took it out and broke my left front CV. I have my end points set to limit the steering throw, nothing was bound up, and I'm not running much power to it at all. It was just a basic small climb on a trail run. Guess its time to get back on the phone with Horizon again. All said though, I still love this truck
05-05-2015, 06:40 AM | #64 |
Rock Stacker Join Date: Nov 2014 Location: SoCal
OK, last night I pulled off my diff covers to inspect my gears. I built mine as per the manual, one shim each side. I put a generous amount of the supplied black grease on the gears when I built it. I used the brace on the diff cover as well. I run a 20T motor on a axial ESC with brake set at 50%. Battery is a 5000mah 50C short pack. I've got about 40 hours of run time on it up and down some gnarly rocky stuff as well as doing a few backwards wheelies. gears all looked great, no wear or broken teeth. There is some slop in the ring and pinion mesh. But everything looks fine. I relubed the gears with some 50K diff oil I had and put it all back together. My question for those breaking gears, did your diff cover have the 2 tabs on it that support the spool/bearings? Or did you cut them off? Mine are on still. |
05-05-2015, 08:55 AM | #65 |
Another big thumbs up to Rich and the rest of Horizon! I called them yesterday at lunch, new front CV's are on their way to me
05-05-2015, 01:30 PM | #66 | |
Pebble Pounder Join Date: Jan 2015 Location: Calgary
| Re: What to do. Won't stop breaking Quote:
05-05-2015, 06:11 PM | #67 |
I've got probably 20 hours on my first-batch kit. Half that before the HD gears/driveshafts came out. I still haven't broken anything and I'm not exactly easy on equipment. The trick is I only run a 55 turn (thinking about bumping it up to a 35 turn after this motor dies) on 2 cell. The reason the truck in question won't stop breaking is that the owner took a 1.9 scale truck and turned it into a 2.2 overpowered mudtruck. Maybe a different platform would be more suitable for such use? |
05-06-2015, 03:13 PM | #68 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
I run mine 2.2 ripsaws every other row cut out. Stock gears and drive shafts. Both ring gear shims on the gear side. Original gears. 55 turn holmes motor. 3s 40C zippy lipo's with 5 Oz of wheel weight on each front wheel. No problems yet. Of course if you jump it like a short course truck it is going to break. I have all the HD stuff to put on when the time comes. Have not needed it yet. Best stock shaft drive axle I have seen yet.
05-07-2015, 01:06 AM | #69 |
Quarry Creeper Join Date: Oct 2012 Location: Canada
My ROC412 twisted a stock drive shaft and pulled a tooth on the pinion just crawling at very low speed and very gentle on the throttle... Strange, since I was more throttle heavy in other parts of the trail, for more than 5 hours! |
05-07-2015, 07:39 AM | #70 |
The part that most people dont get is that what breaks parts might not be the activity you're doing at the moment it breaks, but rather something that over stressed it and did the damage previously. Look at it this way: I drive a Mercedes E55 AMG, lots of upgrades, PLUS a huge nitrous kit. I sprayed a big shot for ages and never had it go boom. One day driving down the road leaving a red light at very low throttle, she popped. Is the engine crap because it blew up at low load and low rpm, or was it because I'm a jackass and had huge shot on it for ages, causing all kinds of problems? I'm gonna go with its the fault of me driving the piss out of it and running the kit. The car is tough and overbuilt, you guys need to look at these trucks the same way. Very few of you use it for its intended purpose. |
05-10-2015, 11:58 AM | #71 |
Why does everyone seem to think that im blaming the truck or horizon for this breakage the whole point is that im looking for an hd replacement. I have never once said that the ascender is junk i prefer it in every way to my scx10 which is also set up very similar. Except that the scx10 had a much larger selection of aftermarket parts, obviously because it's been out far longer. I'm simply saying that the front cvs are a weak point (I'm not the only one breaking this part) and yes i no ive got to much power and to much tire blah blah blah. Im not the only one out there that wants to build theyre ascender in to a bad @$$ scale mud truck with too much power and too much tire. The scx10 im sure had similiar complaints when it first came out. All the ascender needs is better aftermarket selection and i think a good place to start would be hd cv axels. I dont understand why everyone is so againts this idea
What to do. Won't stop breaking - Similar Threads | ||||
Breaking axles! | Hacksaw707 | Formula Offroad | 9 | 05-05-2012 10:19 AM |
anyone breaking universals | twisted bender | Axial XR10 | 37 | 01-11-2011 08:15 AM |
Breaking Down | house_Fly | Chit Chat | 5 | 12-12-2009 08:53 AM |
Breaking News! | jason | Chit Chat | 17 | 09-17-2009 07:49 PM |
