08-29-2014, 01:38 PM | #1 |
Sr. Product Developer Join Date: May 2005 Location: Fontana
| How to shorten your Ascender Axle Housing Track width
For you customizers, one of the features we designed into the Ascender but not mentioned in the instruction manual is the ability to reduce the overall track width by as much as 12mm. To do this you will need some additional parts to make up for the narrower width and have to trim the housing,drill a couple holes and trim the carrier. Our Axles have flats built into them so that they can slide in and out of the Spool so no need to modify the axles. You will need to shorten the steering link by 12mm. You can use a 66mm link and a 12mm spacer if you use our parts. Since the carrier is being slid in behind the suspension mount on the housing, you will loose the ability to secure the carrier on the back side. You'll use one screw but i would suggest drilling a hole from below the housing and use a set-screw to keep in more secure. The panhard bar is easy, just remove the 12mm spacer that was installed on the kit with the stock width. The rear is easier as you will only need to trim the housing and drill new holes. I realize these are not perfect step by step instructions but i wanted to share some unique features that I could not in the instruction manual. I will post a more detailed "how to" in the next couple weeks. Last edited by Rich Trujillo; 08-29-2014 at 01:47 PM. |
08-29-2014, 01:46 PM | #2 |
| Re: How to shorten your Ascender Axle Housing Track width
Forward thinking, nice! |
08-29-2014, 10:21 PM | #3 |
RCC Addict Join Date: Jan 2009 Location: Bend
Rich, any insight as to whether or not multiple housings can be used to build offset versions of this housing? One of these will be finding it's way to my home soon enough, but I'd like to build a true passenger offset housing. Basically, what I need to know is, are the tubes a consistent inside diameter so they can be cut, sleeved, and glued back together like Wraith housings? Then comes the battle with shafts... Sounds like shortening the short side shaft should be no problem, but I may have to get creative with coming up with a long side shaft. Maybe you guys can release some "unfinished" extra length optional shafts or something for those of us willing/wanting to get creative with these rigs...hint hint. Maybe a little over an inch longer than stock, without the flats cut. Then we can cut and mod them as needed for custom builds? BTW, While I do have my reservations about the ring/pinion size, I really like where you guys are headed with this rig. Lots of innovation here! |
08-30-2014, 09:26 AM | #4 | ||
| Re: How to shorten your Ascender Axle Housing Track width Quote:
Thanks, | ||
09-07-2014, 08:31 PM | #5 |
Rock Crawler Join Date: Apr 2013 Location: Buena Vista
What would be the track width (hex to hex) after trimming 6mms on each side? What is the stock width?
09-08-2014, 09:34 AM | #6 |
That sir, is a very nice feature! Not a bad way to go ilo a multi-piece (expensive) axle housing.
09-08-2014, 01:34 PM | #7 |
| Re: How to shorten your Ascender Axle Housing Track width |
09-08-2014, 02:01 PM | #8 |
09-09-2014, 10:36 PM | #9 |
RCC Addict Join Date: Jun 2009 Location: Australia
10-23-2014, 09:48 AM | #10 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
I forgot all about this, I might have to give it a try on my FJ build! I'll know for sure later today when my body shows up.
10-24-2014, 04:21 AM | #11 |
Rock Crawler Join Date: Jan 2008 Location: NORWAY
What is the inner and outer diameter of the axle tube ?
10-24-2014, 09:08 AM | #12 |
10-24-2014, 12:14 PM | #13 |
03-06-2015, 01:43 AM | #14 |
Newbie Join Date: Dec 2014 Location: Vitoria-Gasteiz
What about any step by step photo tutorial? Any help with the safts? Would be very helpful... =)
07-25-2015, 11:54 PM | #15 |
Pebble Pounder Join Date: May 2011 Location: Santa Cruz, Ca.
Anyone attempted this yet? Any extra tips after it has been executed?
07-26-2015, 01:25 AM | #16 |
Newbie Join Date: May 2014 Location: spokane
I did this mod its fairly straight forward. I did shorten my steering link 12mm, and that was all i found that needed to be shortened. Sent from my SCH-I545 using Tapatalk |
08-02-2015, 12:10 PM | #17 | ||
01-18-2016, 06:12 PM | #18 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
Awesome! You can correct or gain castor while your at it |
01-27-2016, 09:01 PM | #19 |
Rock Crawler Join Date: Aug 2009 Location: San Antonio
| Re: How to shorten your Ascender Axle Housing Track width Did you use a set screw to hold the top part of the carrier or did you drill through the shock mount and secure from the top.
01-28-2016, 09:09 AM | #20 |
I'm thinking set screw because based on my measurements the carrier doesn't seat far enough under the shock mount. So drilling through the shock mount would be pointless. I might just try removing a little of the outside shock mount, just enough so the carrier can be secured from the top.
How to shorten your Ascender Axle Housing Track width - Similar Threads | ||||
Best axle = narrow track width for D90 Build. | Desert Rc | General Scale Talk | 7 | 12-05-2011 05:14 PM |
Track width, vanquish rims what width and hbs? | Kraqa | RC4WD Bully | 10 | 01-14-2010 08:50 PM |
WK axle + 1.9 rim = what track width? | 4x4boy | 1.9 Scale Rigs | 6 | 10-21-2007 07:52 PM |
TLT axle + 1.9 rim = what track width? | STANG KILLA SS | 1.9 Scale Rigs | 2 | 05-16-2007 10:03 AM |
