Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Ascender
Thread: How to convert Ascender trans to a Two Speed
Old 02-26-2016, 07:08 AM   #61
Default Re: How to convert Ascender trans to a Two Speed
Great in info, I've been thinking about doing the 2-speed conversion on one of my rigs, that I'll be using for towing.
HDMM is offline   Reply With Quote
Old 02-26-2016, 10:18 AM   #62
i like the 2 speed. have a hh motor and esc. good wheel speed and crawls great.. try to find yourself a complete twin hammer tranny.
m1009cucv is offline   Reply With Quote
Old 02-26-2016, 11:38 AM   #63
X2 ^
Make sure you get the metal gears too.
Itali83 is offline   Reply With Quote
Old 04-21-2016, 01:11 PM   #64
MEOW
Natedog's Avatar
Bump for good info.
Old 04-21-2016, 08:04 PM   #65
this should be a sticky
Crash13 is offline   Reply With Quote
Old 11-28-2016, 05:05 AM   #66
Assembly Tip:
After putting the two halves of the gearbox casing together, tighten the screws until they are just barely flush with the casing, then install the slipper clutch and tighten the spring all the way. Then tighten each screw holding the gearbox casing together a bit at a time, checking for free movement of the top shaft; if binding is felt, back off a little and move to the next screw. After this is complete, readjust the slipper clutch to a reasonable setting.
For reasons I don't understand, having the slipper clutch as tight as possible amplified the binding I felt after initially assembling the gearbox, hence my recommendation above.
fyrstormer is offline   Reply With Quote
Old 01-25-2017, 06:25 PM   #67
MEOW
Natedog's Avatar
More good info Fyrstormer, this thread really ought to be a sticky please.
Old 01-28-2017, 12:10 AM   #68
Another tip: Before assembling the gearbox, take a small file and smooth-off the edges of the square hole in the middle of the shift puck. Those edges are slightly sharp from the factory, and they tend to grab onto the surface of the output shaft and keep the shift puck from sliding properly, even if everything is greased properly. You can also polish the square portion of the output shaft to make it smoother, but this is less important than smoothing the edges of the square hole in the shift puck.
Old 02-11-2018, 11:54 AM   #69
Thanks for the list. Just ordered all the parts I need.
Apx2Apx is offline   Reply With Quote
Old 08-06-2019, 07:40 AM   #70
ok.. so the OP list comes up to 105$ without shipping.. is that normal, or I just picked a too expensive HS?
ChILd_ReBoRn is offline   Reply With Quote
Old 08-06-2019, 01:40 PM   #71
You picked a WAY TOO expensive hobby. Get used to it.
Ben
Old 08-06-2019, 09:28 PM   #72
I used the 2 speed out of an inherited WLToys twin hammers clone ..has proven very durable as it tows a trailer with a Kyosho Chevelle on it. I also installed a 26.00 ebay 17.5t sensored BL with a permanent mount Zippy LIfep04 3s 4200....really luvin this K5 now...really fast in 2nd and creep crawl in low(no cogging)
willygee is offline   Reply With Quote
Old 08-07-2019, 01:03 AM   #73
MEOW
Natedog's Avatar
Ben
How to convert Ascender trans to a Two Speed - Similar Threads
Which 2 speed trans to get???? help! dwblue00 Axial SCX-10 10 08-23-2013 01:37 AM
2 speed trans DIZZE004 General Scale Talk 0 11-07-2010 01:27 PM
What 2 speed trans to use? McCready 2.2 Scale Rigs 2 08-13-2010 08:13 AM
Scale Speed... how do you convert it??? norbyx Chit Chat 11 06-16-2010 11:39 AM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
