10-15-2014, 12:31 PM | #81 | |
Quarry Creeper Join Date: Sep 2005 Location: Sandy, UT
| Re: Pinion gear Quote:
10-15-2014, 01:17 PM | #82 | |
10-15-2014, 03:54 PM | #83 |
Newbie Join Date: Aug 2014 Location: Hagerstown
| Re: Pinion gear
I have nothing negitive to say about Horizon customer service it is hands down the best in the business. I have had issues with both diffs and driveshafts, that being said the ascender is a very capible truck, far more capable out of the box than axial... period.. Can anyone tell me when a person any person representing axial has come to a forum to address your cocerns over one of their "jeeps" and as we all know there have been many, we are just used to pulling junk axial parts off and replacing with aftermarket parts.
10-15-2014, 04:01 PM | #84 |
| Re: Pinion gear
Well actually, there's a couple Axial reps on here.
10-15-2014, 06:10 PM | #85 |
Newbie Join Date: Oct 2014 Location: farmington
| Re: Pinion gear Precisely what my biggest concern was. Leaky shocks. For some reason the plastic ones seem to leak. But that just gives us an opportunity to upgrade them. And yes they did cycle slow and I too decided on bigger piston holes but I decided to run it stock first. Crawlorado posted a video of his and it performed well box stock minus tire and wheel upgrades. This truck is amazing and I have full confidence in it.
10-16-2014, 02:48 PM | #86 |
Rock Crawler Join Date: Jul 2011 Location: palm desert (southern cali)
| Re: Pinion gear
Been driving this rig for 2 days now no difference in driving style from my scx10 still go same lines ect I have no issues with pinion gears nothing yet and I've had a few spots were it got bound up and good to go still trucking maybe I got a good batch of gears idk but so far truck is neat Sent from my iPhone using Tapatalk |
10-18-2014, 11:11 AM | #87 |
| Re: Pinion gear
A couple things I was thinking about these failed gearsets. It seems that the countersunk screw that retains the pinion gear to the "input shaft" could potentially put stress on the input gear because the countersunk is slightly pushing outwards on the gear when tightened. I assume that this is designed so that the countersunk centers the gear on the square portion of the input shaft, which it seems to do quite nicely. If overtightened, (which some undoubtedly are because no one wants that particular bolt to loosen, and it can't be torque checked without axle dissasembly) could it be putting enough outward force on the gear to stress it and essentially reduce the torque load required to break it? Would a properly splined input shaft and matching pinion gear secured with an E-clip offer any improvement? And I've noticed a few people mention driveshaft joints that bind. I found that all of the driveshaft CVD barrels had to be slightly opened up to get the pins to fit through. I foolishly forced the first one together with vice grips and fully assembled it and noticed a slight binding that was only present when the driveshaft was inside the pinion bearing. Upon removal and inspection it could be seen that the tight fitting pin wasn't perfectly centered in the barrel and the side that was sticking slightly out would contact the inside of the pinion bearing race when operated at steep angles. Centering the pin fixed the issue. I took a jewelers file to the other 3 barrels and they did not exhibit the binding. This binding could also side load the input shaft and add to deflection between the ring/pinion gears contributing to premature failure. If you have a notchy driveshaft and the pins didn't just fall right into place in the barrels, then I would encourage you to inspect if the pins are perfectly centered in the barrels. I noticed that I had to space the front upper shock mounts out about 3mm per side to keep the shock body from contacting the frame rail during full flex. When flexed out without the spaceres I could easily see that the shock shafts were not straight with the bodies. This will certainly cause leakage issues. |
10-18-2014, 05:09 PM | #88 | |
Pebble Pounder Join Date: Aug 2013 Location: near jax
Its this type of thinking that gets things figured out instead of complaining. Thumbs up to you good sir. Cant wait to get mine. | |
10-19-2014, 07:38 AM | #89 |
I wanna be Dave Join Date: Apr 2012 Location: Merrill, WI
| Re: Pinion gear
I had the same hitching in the shafts and the best thing to do is clean the notches up with a small file. Also on one I had to clean up the holes in the barrel. After almost doing it myself though I still think the issue is vapor lock from the threadlock causing the pinion to not be getting tight. |
10-19-2014, 11:14 AM | #90 |
Newbie Join Date: Feb 2005 Location: N/A
| Pinion gear
To avoid vapor lock, file, or Dremel a small groove in the screw threads from the tip to the head, and this will allow air to escape.
10-19-2014, 07:40 PM | #91 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
| Re: Pinion gear
Could some post up a pic of how the pinion and driveshaft all join together.
10-20-2014, 05:34 PM | #92 |
| Re: Pinion gear
I find it hard to believe that no one has their axle apart right now.
10-20-2014, 05:41 PM | #93 |
Quarry Creeper Join Date: Mar 2013 Location: Pilipinas
| Re: Pinion gear |
10-20-2014, 06:53 PM | #94 |
RCC Addict Join Date: Jan 2009 Location: Jacksonville Illinois
| Re: Pinion gear
That looks like a terrible design. |
10-20-2014, 07:38 PM | #95 |
| Re: Pinion gear Thanks Buddy , I think i'll wait and see what the aftermarket bring to the table before i send my money on this , When this was first talked about i was really excited to get one , Now not so much. It make me wonder why they designed it like this , Just to be different or what , Is there another rc out there with this setup?
10-20-2014, 08:17 PM | #96 |
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
| Re: Pinion gear
Doesn't look any worse than the typical e-clip set up, looks like less of a PITA to build and maintain to me compared to those. Is it possible that the countersunk screw has backed out on the guys who have has this issue and the gear has started to walk around? |
10-20-2014, 10:40 PM | #97 |
| Re: Pinion gear
When we first heard of the scale axle assemblies, I really thought that Vaterra would re-use the R&P from the MRC for a small, tough package. Big props to them for thinking outside of the box and trying something new, I'll just keep reading this section to see how this ring gear issue plays out before spending any money on the kit.
10-20-2014, 11:56 PM | #98 | |
Newbie Join Date: Sep 2014 Location: Ottawa
6mm shims for the pinion and 8mm shims for the spool... shim it and get the mesh right.. I broke a set..got all butthurt...knocked the kit, shimmed my replacements... and have been pounding the crap out of it since. Foot in mouth and all... No more problems. I love this truck. I'll get hardened gears when they come out or a set of axles with an offset front pumpkin later, but the gears aren't the end of the world with this truck. If they do happen to break, Horizon is taking care of us. Don't let this issue chase you away bud. | |
10-21-2014, 05:21 PM | #99 |
| Re: Pinion gear
''Don't let this issue chase you away bud.'' I'm still going to get one , But i'm just waiting to see how it all pans out .
10-21-2014, 11:09 PM | #100 |
| Re: Pinion gear I suppose that is possible for some people, but it didn't happen on mine. The screw was still tight when I pulled it to swap the new one in.
Pinion gear - Similar Threads | ||||
Which pinion gear works best with RC4WD Steel spur gear? | e32lover | HPI Wheely King | 8 | 03-10-2013 06:09 PM |
Which spur gear and pinion gear with 35t motor | vegas1973 | General Crawlers | 1 | 08-19-2012 11:42 AM |
Pinion Gear? | BIGNASTY | Axial Wraith | 20 | 03-13-2012 06:55 PM |
pinion gear | yukon635 | General Crawlers | 4 | 01-11-2006 02:16 PM |
