12-30-2014, 03:57 PM | #141 | |
Sr. Product Developer Join Date: May 2005 Location: Fontana
| Re: Pinion gear Quote:
8mm shims | |
01-16-2015, 09:54 AM | #142 |
Newbie Join Date: Mar 2009 Location: Pocatello
| Re: Pinion gear My son and I both bought one, after getting them done went to our local hobby store to do some driving and both broke first run. (diff pinion) son had the hobby shop call horizon and I called from home and the customer service was great we both got are parts and both up and running. but we got different parts mine on the left looks like the stock part, his on the right might be the hd? |
06-20-2015, 03:47 PM | #143 |
Rock Crawler Join Date: Jan 2014 Location: Frog Lake AB, Canada
| Re: Pinion gear
My ascender just lost its first tooth on the front ring & pinion, my how they grow up so fast. That was all carry on...... |
06-20-2015, 05:09 PM | #144 | ||
Was it heavy duty version, forget what power you're running and what were you doing at the time? | ||
06-20-2015, 06:23 PM | #145 |
| Re: Pinion gear
I have no clue if it was HD, what ever came in the RTRs is about all I can share. Power wise I've got a holmeshobbies 540 outrunner, paired to a Tekin RX8 GEN2, with the recommend 2s reaction lipo. My rear left tire got hooked on a rock ledge, and I used the throttle to pull the tire free/over, and then there was a clicking sound. Last edited by Alexander_0_1; 06-20-2015 at 06:39 PM. |
06-20-2015, 06:27 PM | #146 |
Pebble Pounder Join Date: Jul 2008 Location: Elk Grove, Ca
| Re: Pinion gear
Still waiting on overdrive and under drive ring and pinion gears for the axles !! come on Vaterra lets get the ball rolling please Last edited by luv2ridemx; 06-20-2015 at 06:33 PM. |
06-24-2015, 02:36 PM | #147 | ||
Here's the HR aluminum diff covers, they are pretty nice pieces! VTA12C01 - Hot Racing CNC 6061 Aluminum Differential Covers – CKRC Hobbies Hot Racing Vaterra Ascender 1:10 Chevrolet K5 Blazer RC Car upgrades and Hop-ups Quote:
06-24-2015, 03:57 PM | #148 | |
6mm shims for the pinion and 8mm for the ring gear. I've been beating mine hard too and so far everything has been fine. Even did some forward reverse throttle the other day, just to see if the diffs would blow and it's still on original set of HD gears and driveshafts. Also been letting it hop and bounce on steep climbs, steering full lock in both directions, some tumbles mostly on 2S, but some 3S too, mine is all stock still. I checked diffs and had to re-shim them properly and added one shim of my own per diff. Two shims on ring gear side of spool and one shim on the other end of the spool, extra little spot of grease and that's it. Last edited by Natedog; 07-01-2015 at 02:48 PM. | |
Pinion gear - Similar Threads | ||||
Which pinion gear works best with RC4WD Steel spur gear? | e32lover | HPI Wheely King | 8 | 03-10-2013 06:09 PM |
Which spur gear and pinion gear with 35t motor | vegas1973 | General Crawlers | 1 | 08-19-2012 11:42 AM |
Pinion Gear? | BIGNASTY | Axial Wraith | 20 | 03-13-2012 06:55 PM |
pinion gear | yukon635 | General Crawlers | 4 | 01-11-2006 02:16 PM |
