06-28-2015, 06:47 AM | #1 |
Rock Stacker Join Date: Jun 2015 Location: K
| Ascender Sway Bar (Anti-Torque Twist)
Been searching around on the forums and internet for sway bar ideas for my Ascender. This is what I've come up with, its made from a traxxas slash 4x4 rear sway bar and end links. I just used a longer screw holding in the shocks and lower links to hold the rod ends to the sway bar linkage. Mounted some make shift hinges to the bottom of the esc plate with lock nuts from the kit. The goal is to try and eliminate torque twist in the chassis when its under load. Let me know if you guys have any other ideas for sway bars with the Ascender. I will report back about how this setup performs. Last edited by stillsmokin875; 06-28-2015 at 07:13 AM. |
06-28-2015, 09:06 AM | #2 |
Pebble Pounder Join Date: Oct 2010 Location: Marengo Oh
| Re: Ascender Sway Bar (Anti-Torque Twist)
Would like to know how well this works!
06-28-2015, 10:06 AM | #3 |
Rock Crawler Join Date: Jan 2014 Location: Frog Lake AB, Canada
I've been wanting an Erik D_lux universal sway bar set, I've seen people putting them on the SCX platform.... Maybe I could get it to work on my ascender.
06-28-2015, 10:20 AM | #4 |
Just finished testing it out, and it actually worked! Definitely kept the frame from twisting as much when under torque. Also still allows the suspension to flex just as much!
06-28-2015, 02:17 PM | #5 |
| Re: Ascender Sway Bar (Anti-Torque Twist) Nice, got any pics at full stuff? What did you use to mount to esc plate? One thing mounting to esc plate will reduce effectiveness somewhat because those mounts will flex some under swaybar load, which is much more force than the weight of an ESC. That may be why you still get same amount of flex travel.
06-28-2015, 03:51 PM | #6 | |
| Re: Ascender Sway Bar (Anti-Torque Twist) Quote:
I checked the esc mounting plate flexing and you are right. I guess I need to figure out a way to mount to the frame to correct that. But even with it flexing, I can still tell that it is working to help with the twist. Thanks for the advice, I will post up some more pics. | |
06-28-2015, 04:07 PM | #7 |
Thanks for update and part link.
06-28-2015, 05:49 PM | #8 |
| Re: Ascender Sway Bar (Anti-Torque Twist) |
06-28-2015, 06:02 PM | #9 |
Clears very nicely thanks for the clear pics.
07-01-2015, 04:40 PM | #10 |
Pebble Pounder Join Date: Aug 2013 Location: near jax
Just did this to mine. It works. I didn't have the esc plate so i made a plate out of stiffer plastic. Mounted the same way. I need to trim the rod ends down though as they hit the frame with more up travel/flex left on the shock.
07-01-2015, 05:18 PM | #11 |
| Re: Ascender Sway Bar (Anti-Torque Twist) Did you use the same slash rear sway bar or something else? I want to make a hard mount to the frame instead of using the flexible ESC plate. I'll post some pics when I figure out how to do it. Glad the sway bar mod worked out for you.
09-20-2015, 02:18 AM | #12 | |
Updates? | |
Ascender Sway Bar (Anti-Torque Twist) - Similar Threads | ||||
panhard/ anti-sway bar work together? | terrible | Axial Wraith | 5 | 01-22-2014 09:25 AM |
wroncho sway/anti roll bar help | steveo 561 | Axial SCX-10 | 7 | 12-14-2012 04:05 PM |
Anti-sway bar | mitchr97 | Axial SCX-10 | 18 | 08-05-2012 11:11 PM |
The V-link anti torque twist experiment. | miller | Axial AX-10 Scorpion | 38 | 12-12-2009 10:56 AM |
V-link anti torque twist experiment. | miller | Axial AX-10 Scorpion | 2 | 11-26-2009 08:47 PM |
