07-17-2015, 11:38 PM | #1 |
RCC Addict Join Date: Sep 2014 Location: Alberta
| What light kit are you using?
Hi all, Can you please tell me what light kit you're using for your K5? Links and pictures would be awesome! Thanks in advance. |
07-18-2015, 01:42 AM | #2 |
Rock Crawler Join Date: Jan 2014 Location: Frog Lake AB, Canada
| Re: What light kit are you using?
Here's the list that i shop from: HeyOK's RC Electronics items (all in one place) I use the reverse/brake/driving light controller in my ascender for now, but I have The Lighting Controller just sitting around waiting for me to buy a 4ch radio. At the bottom of the list there are helpful tips, like how to wire L.E.Ds. |
07-21-2015, 12:17 PM | #3 |
Nothing yet, prolly solder up some LEDs, here's a great led that comes with nice long leads already soldered on if you're running 3s, but I"m running 2s on this truck so I'll find something else for this truck. https://www.superbrightleds.com/more...ent-light/639/ Leds cut to length and solder on a roll https://www.superbrightleds.com/more...led-5050/2138/ Might run a pair of Vaterra Slickrock strip leds for rock lights Vaterra LED Light Bar Insert Slickrock Then wire up LED headlights in the Blazer body. |
08-12-2015, 07:26 AM | #4 |
Pebble Pounder Join Date: Jun 2006 Location: Grand Blanc/Traverse City
These make great rock lights, waterproof and durable as hell, run 12VDC and easy to wire and take a beating. I can get them through my work in strings of 50 but they can be cut to any length. I have 2 setup as headlights and 3 as rock lights. they have two holes to mount with screws or 3M sticky tape. Have tested them in water with no issues. They come with about 5 inches of wire between the lights so it can cut down on a lot of wiring. |
08-12-2015, 10:47 AM | #5 |
Rock Crawler Join Date: Jan 2012 Location: Hudsonville, MI
I'll probably just use regular super bright LED's and a couple resistors. I have a Heyok light controller already. Probably going to get the rear light buckets from RCaddict. Sent from my iPhone using Tapatalk |
08-12-2015, 11:47 AM | #6 |
Quarry Creeper Join Date: Aug 2013 Location: Wijnandsrade, NL
The last time i soldered my onw led's the world stopped turning and the only thing i saw where flashes and then it went dark..... So, i decided to buy lightkits and i do not regret it. Especially not for the money they cost. Running this in my (not an Ascender) SCX10. By Asiatees. Plastidipped the whole damned thing, been submerged more then once and just keeps on burning. Killerbody Led Light System W/Control Box (12 Leds) KB/48102 This one is in my G6 and also works always: G.T. Power Smart LED Lighting System GT/LB1002 |
08-17-2015, 07:14 PM | #7 |
Pebble Pounder Join Date: May 2015 Location: St. Paul
I am using the Common Sense RC's LED Lighting Kit for Cars and Trucks https://www.commonsenserc.com/produc...oducts_id=2636. Was simple to hook up with a y harness between the ESC and receiver and another y harness between the steering servo and receiver. I also picked up RCAddicts Tail Light bucket kit. So I have low beams on all the time and High Beams when moving forward, left and right turn, tail lights and brake/ back-up lights. I did have to do some cutting and soldering so I could run my wires from its control board which I have under the hood and ran the wires down the sides of the body and across the front and back, instead of center mounting and running straight to each light. |
08-17-2015, 07:17 PM | #8 |
Quarry Creeper Join Date: Oct 2014 Location: Milpitas
That's a good deal. The Tamiya ones I was getting were much more expensive and don't have the blinker.
08-17-2015, 09:33 PM | #9 | |
| Re: What light kit are you using? Quote:
EDIT: Here's the exact bulbs I bought, but they come in all colors. https://www.commonsenserc.com/produc...oducts_id=4723 Last edited by Natedog; 08-17-2015 at 09:36 PM. | |
08-20-2015, 05:48 AM | #10 | |
How do you like the RCAddicts rear tail light buckets? Been thinking about getting a set. How is the fit and assembly on them? Sent from my iPhone using Tapatalk | |
08-20-2015, 07:43 PM | #11 |
Newbie Join Date: Jul 2015 Location: Wheeling
Thanks for all the info, I just ordered the buckets and lenses from Rcaddict for my ascender
08-21-2015, 06:22 AM | #12 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
I use the Axial AXI24257 simple LED controller with leds for a lot of my builds. It's simple, comes with 4 white and 2 red LED's and it works good. Axial Simple LED Controller w/LED lights [AXI24257] | Parts - AMain.com - AMain.com |
08-13-2017, 09:48 AM | #13 |
Newbie Join Date: Aug 2017 Location: Portland
I'm using Common sense RC led light kit on my trx4. I just got it all wired to what they say and now my blinkers don't work correctly when I turn right I get nothing but when I turn left all four blinkers blink. Can anyone help? If I didn't provide enough info please let me know.
