02-04-2016, 10:38 AM | #101 |
| Re: Newbie
I haven't measured my packs against the specs but I would say they are more accurate than Hobbyking on their published specs. You may be able to fit 2 of the 2200 packs in the tray, I'll have to check on that when I get home. Edit: I remember some build on here used this pack in their Ascender. Turnigy 4000mAh 3S 20C Lipo pack (Perfect for QRF400) Last edited by svt923; 02-04-2016 at 10:42 AM. |
02-04-2016, 11:52 AM | #102 |
Rock Crawler Join Date: Jan 2016 Location: US
| Re: Newbie
I just got to say some of yall r nuts with detail u put in to these rigs and all the performance options for them too its nuts so thank u guys for all the answers to my ? And ideas from other threads like the thread about thread very impressive never would have thunk it LIFE IS GOOD |
02-04-2016, 11:59 AM | #103 |
| Re: Newbie
My plan for rest of rig is finish bolt on stuff slowly work on my hard body and then electronics probly servo fairly soon just becouse the bronco is starting to get very fat but once done i am going to do a full leaf sprung truck probly buy a used one cheap and build how i want LIFE IS GOOD |
02-04-2016, 05:25 PM | #104 |
| Re: Newbie
2 2200mah 3s packs are a tight fit but not bad at all. 4400mah of 3s runtime or 6s power if you are sadistic. |
02-04-2016, 06:48 PM | #105 | |||
| Re: Newbie Quote:
Oooh, you could also do a pair of 2S for 4S, that would be nice. | |||
02-05-2016, 08:55 AM | #106 |
| Re: Newbie
I got front end done last night will take pics tonight then assemble everything and get it ready to play. I am very happy with the gpm products everything lined up great everything came with new hardware i have not extended frame i will do that next week so all in all the only bad spot on all my bolt ons so far was the shocks but that was my fault for not checking the caps lots of pics tonight of finshed product before i play LIFE IS GOOD |
02-05-2016, 10:03 AM | #107 |
| Re: Newbie
Ok just ordered gcm shock kit for better body mounting no more will be bought for awhile LIFE IS GOOD |
02-05-2016, 10:04 AM | #108 |
Rock Stacker Join Date: Apr 2008 Location: Salt Lake City
| Re: Newbie |
02-05-2016, 11:12 AM | #109 |
| Re: Newbie
I know right LIFE IS GOOD |
02-05-2016, 05:58 PM | #110 |
| Re: Newbie
The boggers and 2.2 look alikes r same height so thats nice well all my first wave of orders r in and so far so good i will test on sunday the boggers r for yota body so that will be next weeks ride LIFE IS GOOD |
02-05-2016, 06:21 PM | #111 |
| Re: Newbie
Wheels and tires look good! BTW, your upper shock mounts need to use a ball mount (like stock) or a piece of fuel line as a bushing (and don't over-tighten mounting screw) so that when the axle articulates (flexes) the upper shock mount can swivel a bit and not bind the shock shaft. Otherwise your suspension will bind and shocks will wear and leak much quicker. |
02-05-2016, 07:20 PM | #112 |
| Re: Newbie
Ty for the tip LIFE IS GOOD |
02-06-2016, 09:02 PM | #113 |
| Re: Newbie
Ok done with bolt ons except for rear hubs they will be here tuesday still flexs real good with sway bar LIFE IS GOOD |
02-06-2016, 09:05 PM | #114 |
| Re: Newbie going to have to jack up rear body supports for awhile cos of touch longer wheelbase LIFE IS GOOD |
02-07-2016, 06:26 PM | #115 |
| Re: Newbie
Ok so this happened today i am not impressed withe quality of rc4wd products atm i am going to send an email just to see what they say not expecting anything but never hurts to try LIFE IS GOOD |
02-07-2016, 06:33 PM | #116 |
| Re: Newbie
But on to better news the rear sway bar completely took out my torque twist lost enough of the flex i got hung up a few times on rocks cos rear did drop like before LIFE IS GOOD |
02-07-2016, 06:38 PM | #117 |
| Re: Newbie LIFE IS GOOD Last edited by pete959; 02-07-2016 at 06:41 PM. |
02-07-2016, 07:04 PM | #118 |
| Re: Newbie LIFE IS GOOD |
02-07-2016, 07:06 PM | #119 |
02-07-2016, 07:10 PM | #120 |
| Re: Newbie
If u click on clips u can watch it LIFE IS GOOD |
Newbie - Similar Threads | ||||
help from a newbie | judgeshock | Venom Creeper | 0 | 04-26-2012 06:52 PM |
Another Newbie. | john__505 | Newbie General | 3 | 01-19-2012 10:04 AM |
newbie with a jk | rch8r | 2.2 Scale Rigs | 29 | 07-06-2010 02:42 PM |
Newbie from SE Wi | andy736 | Wisconsin | 34 | 02-10-2009 01:04 PM |
im not a newbie | james22 | Comments, Suggestions, and Help | 13 | 05-16-2008 11:04 PM |
