02-08-2016, 06:49 PM | #1 |
Quarry Creeper Join Date: Aug 2014 Location: Chilliwack
| Servo Suggestions
I'm looking for a new servo for my Ascender. It's an RTR and I'm hoping to put something in stronger then whats in there. Would prefer waterproof. What do you guys suggest? Is it possible I would see an upgrade in the current Spektrum servo just by adding a BEC? I think it maxes out at 133 oz of torque. Last edited by Smonkman; 02-08-2016 at 06:59 PM. |
02-08-2016, 09:18 PM | #2 |
Pebble Pounder Join Date: Jul 2013 Location: Central Rockies
| Re: Servo Suggestions
I personally wouldn't waste my time with the stock spektrum servo, but I would however invest in a BEC. As far as servos go, I have had good luck with this one, and it doesn't break the bank either. Savox SW-0231MG Waterproof High Torque STD Metal Gear Digital Servo I have also used this servo with good results as well, 277oz/in at 6v. This servo would work well in your ascender if you can afford it. Savox SW-1210SG Waterproof Coreless Steel Gear Digital Servo Good luck with your search! |
02-08-2016, 10:08 PM | #3 |
I just ordered the 1210 for the TF2 kit I'm building. Maybe I should throw that in my Ascender and order the 0231 for my TF2.
02-09-2016, 09:58 AM | #4 |
Hitec HS-7955TG Hitec RCD HS-7955TG V2 High Res. Ultra Torque Titanium Gear Servo or Hitec HS-7950TH Hitec RCD HS-7950TH Mega Torque Ti Gear Digital Dual BB |
02-09-2016, 05:18 PM | #5 |
Newbie Join Date: Jun 2014 Location: Space
Just installed a 1210 savox and BEC in my bronco ascender. Strong Servo. Super snappy. The stocker was so saggy. This 1210 really snaps.
02-10-2016, 12:08 PM | #6 |
That's exactly how I feel about the stock servo. It's just blah. I wonder if the Savox 0231 will be enough. Don't have a lot of extra funds as I just bought everything for my Trailfinder kit
02-10-2016, 12:12 PM | #7 |
Pebble Pounder Join Date: May 2015 Location: St. Paul
I just recently added the Spectrum S6230 and a Bec and, it is 311 oz Torque at 6 volts and fast at 0.14 and it is waterproof.
02-11-2016, 05:42 PM | #8 | ||
| Re: Servo Suggestions Quote:
You can always add an AvidRC $1 ball bearing (6x10x2.5mm open, part # MR106) to the stock RTR servo output shaft, cheap, easy and will extend stock servo life by months. Post #277, you can see the bag of bearings next to the brass output shaft bushing that I removed from the servo and replaced with a bearing. Natedog's Vaterra ASCENDER Savox 0231 WP Savox SW0231MG STD Waterproof Digital Servo ~~~~~~~~~~~~~~~~~~~~~ Dimensions(mm): 41.8x20.2x42.9 Weight(g): 66 Speed(@6.0V sec/60): .17 Torque(@6.0V oz-in): 208.0 Gear: Metal Bearing: 2BB Case: Plastic 25 Tooth Spline Spektrum S6230 S6230 Digital Surface Servo (SPMSS6230): Spektrum - The Leader in Spread Spectrum Technology ~~~~~~~~~~~~~~~~~~~~~ Size Category:Specialty TypeigitalApplication:1/10 Buggy, Truck, On-Road Torque:311 oz-in (22.4kg-cm) @ 6.0V Speed:0.14 sec/60 deg @ 6.0V, at no load Length:1.61 in (41mm) Width:0.82 in (20.8mm) Height:1.18 in (30mm) Weight:2.1 oz (59.5g) Bushing Or Bearing:Bearing BearingualMotor Type:Coreless Connector Type:Z-connector, removable Gear Type:MetalGear Material:Steel, Aluminum Current Draw Idle:9.8 mA @ 6.0V Current Draw Stall:4900mA @ 6.0V Voltage:6.0V Deadband:4µs Last edited by Natedog; 02-11-2016 at 05:45 PM. | ||
02-11-2016, 05:44 PM | #9 |
Quarry Creeper Join Date: Nov 2011 Location: In the woods
I have a 7995SH sitting and waiting for the ascender to come in. Brand new off eBay for 60 bucks shipped.
02-12-2016, 04:02 PM | #10 |
Rock Crawler Join Date: Jan 2008 Location: Lehigh Valley, Pa
I have a 5955 (same as current 7955) and it works very well. Feeding mine from a BEC as well just for fun. Sent from my iPhone using Tapascrap |
02-12-2016, 06:27 PM | #11 | |
Both good servos. | |
02-12-2016, 07:05 PM | #12 |
Quarry Creeper Join Date: Mar 2015 Location: Castle Rock, Colorado
Anyone got the Spectrum S6030? I'm curious about performance and what the tooth count is for the horn. I can't seem to find a review. Sent from my iPad using Tapatalk |
02-12-2016, 09:53 PM | #13 |
It's the same as a JR servo. I never used mine until I recently made it my shift aervo Sent from my iPhone using Tapascrap |
02-13-2016, 07:01 PM | #14 |
Rock Crawler Join Date: Dec 2008 Location: Fortuna Calif.
I am running 7955s in two different trucks, I have been beating on one for 6 or 7 months with no problems. The other is in a Class 1 I just finished, only a few runs on it but I really like these servos. |
02-14-2016, 01:22 PM | #15 | ||
S6030 Digital Surface Servo - High-Torque (SPMSS6030): Spektrum - The Leader in Spread Spectrum Technology KEY FEATURES Delivers torque with silky smooth precision Heavy-duty Dual ball-bearing output shaft Overload protection 8 inch 22AWG lead Mounting lug height optimized for surface applications PRODUCT SPECIFICATIONS Size Category:Standard TypeigitalApplication:1/10-scale servo for monster trucks, buggies and truggies Torque:222 oz-in (16 kg-cm) @ 4.8V; 278 oz-in (20 kg-cm) @ 6.0V Speed:0.18 sec/60° @ 4.8V; 0.15 sec/60° @ 6.0V Length:1.6 in (41mm) Width:0.8 in (20mm) Height:1.5 in (38mm) Weight:1.8 oz (52.4 g) Bushing Or Bearing:Bearing Bearingual Motor Type:Coreless Connector Type:Z-connector Gear Type:Metal Gear Material:Titanium Voltage:4.8V or 6.0V (4- or 5-cell) Quote:
Great 1.9 servo! I like mine. | ||
02-14-2016, 09:21 PM | #16 | |
So far so good. I am waiting in slightly warmer weather, only 11 degrees here today and my replacement cv shaft to get back going. It's probably overkill for shifting duties but it was a close reach for now... Sent from my iPhone using Tapascrap | |
Servo Suggestions - Similar Threads | ||||
any suggestions on a servo? | maddogs1965 | Electronics | 1 | 05-26-2012 12:33 PM |
New servo suggestions | JRW7072009 | Axial XR10 | 15 | 09-04-2011 10:51 AM |
Servo Suggestions? | hntz4x4 | Electronics | 8 | 08-30-2009 03:25 PM |
looking for a better servo...suggestions? | fatwreck | General Crawlers | 9 | 03-03-2006 09:41 PM |
1/4 Scale Servo Suggestions....... | mike | Electronics | 5 | 12-18-2005 10:07 PM |
