02-09-2016, 07:14 PM | #1 |
Newbie Join Date: Jul 2011 Location: So. Indiana / Louisville
| Servo Winch in swb Bronco
With the steering servo being mounted across the width of the swb chassis, is there still enough room to properly locate and mount a servo for a winch?
02-10-2016, 05:27 AM | #2 |
| Re: Servo Winch in swb Bronco
Looking at the overhead shots on Vaterra's web site it looks like the battery tray may be the reason the servo is turned the way that it is. Can anyone confirm?
02-11-2016, 02:28 AM | #3 |
RCC Addict Join Date: Oct 2011 Location: Brighton UK
I'm just in the process of trialling a servo winch in this set up. My servo The output I'll be using The current gap Forced in till it just clears the steering servo horn The line of site from spool to fairlead I'm hoping to hold it in by firstly the tight grip already in place, servo tape it onto the current steering servo and then finally send a couple of pointed screws through that cross member horizontally so there bite into the servo casing slightly. The force angles should stop it from moving........but thats in the testing. I'm just waiting for a small ESC to arrive then I'll put my findings here. |
02-11-2016, 04:16 AM | #4 |
Very interesting I will be following your progress. Thanks for the reply. |
Servo Winch in swb Bronco - Similar Threads | ||||
1.55 Bronco, swb chassis, SSD D60 axles | Killa-Cotton | 1.5 Scale Rigs | 64 | 07-07-2017 09:23 AM |
SWB Bronco spare parts build | LamChop | RC4WD Trail Finder 2 | 25 | 02-02-2016 05:46 PM |
