06-07-2016, 09:02 AM | #1 |
Rock Stacker Join Date: Feb 2011 Location: Washington DC
| Options for Reducing Torque Twist
Hi, I know there have been some threads on this but nothing really definitive on what really works and what does not. So far the options I have seen are: 1) RURLS - rear link location 2) GCM Rear Axle Truss (not sure if this helps or not) 3) Custom Rear Sway Bars (not wild about this option - would be great if someone had a direct fit kit). 4) Shock spring/oil adjustment or upgraded vaterra/proline shocks Is there anything that I'm missing? any options work better than the other? I'm thinking of giving the RURLs a try since its the cheapest option. |
06-07-2016, 11:31 AM | #2 |
Quarry Creeper Join Date: Mar 2015 Location: Castle Rock, Colorado
| Re: Options for Reducing Torque Twist
I have installed the RURLS and the Vaterra aluminum shocks. I see no improvement in torque twist as a result. Sent from my iPad using Tapatalk |
06-07-2016, 11:50 AM | #3 |
Moving the shocks further out on the axles is an option as well. This is fairly effective for a (almost) free mod. I had the same observation on the RULRs, did not provide any noticeable reduction in TT. |
06-07-2016, 12:00 PM | #4 |
Pebble Pounder Join Date: Sep 2015 Location: Centralia, WA
Yeah, I didn't see much if any at all noticeable benefits with the RULRs. In fact, mine are disconnected now, still just attached to the frame but when I installed MIPs the RULRs didn't fit anymore.
06-07-2016, 12:57 PM | #5 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Options for Reducing Torque Twist Quote:
The sway bar would be your best bang for the $$$ to combat TT. Ernie, | |
06-07-2016, 01:08 PM | #6 |
Thanks guys for the helpful insights - so looks like I can cross out the RURLs. What do you mean by moving the shocks further out? any thread with some pics of this done? |
06-07-2016, 01:09 PM | #7 | |
06-07-2016, 01:22 PM | #8 | |
Pebble Pounder Join Date: Dec 2015 Location: Edmonton
Rear driver side tire rubbing | |
06-07-2016, 01:30 PM | #9 | |
This pic gives the basic idea: | |
06-07-2016, 02:06 PM | #10 | |||
06-07-2016, 02:17 PM | #11 | |
Sent from my XT1094 using Tapatalk | |
06-07-2016, 02:24 PM | #12 | |
The kit by itself does nothing for torque twist. However, when combined with stiffer rear shocks, TT has reduced considerably with no impact in performance. I have detailed the process in my Ascender thread. | |
06-07-2016, 02:53 PM | #13 |
| Re: Options for Reducing Torque Twist |
06-08-2016, 10:45 AM | #14 |
Rock Crawler Join Date: Jan 2016 Location: US
On the beater i did rulr and 45w in unmodded rear shock it helped alot but i am going to put a sway bar kit on it the flex u lose is almost unuse able anyways imo. The biggest improvement i have seen is a nice firm rear end mmmmmm LIFE IS GOOD |
06-10-2016, 03:57 PM | #15 |
Newbie Join Date: Oct 2013 Location: sunderland UK
I run the RULR, Wraith sway bar and lowered shocks and I get very very little twist. The Ascender has tons of flex so losing a little from the rear is more of a benefit than a problem, lowering the shocks 10mm and lowering the body has made it into a very stable rig also.
06-11-2016, 10:42 AM | #16 |
I put a set of Icons on my SCX based ToyZuki rig, so I'm going to try the stock SCX10 shocks I had from that and maybe put a little bit longer mounts on the bottom and see how those work with the Ascender. They'll be shorter then the stock shocks and I'm a big fan of the SCX shocks. I would assume bring the axle up a little bit with shorter shocks, therefore leveling out suspension links a bit could help with TT, correct? Or is my geometry off here? |
06-14-2016, 06:48 PM | #17 |
Rock Crawler Join Date: Dec 2014 Location: In the sticks
I'm very new to the Ascender world, so new that mine is still in tiny little bags in a big box. With that said, I got to drive around an Ascender that was completely stock except for one cheap upgrade, and it didn't have any torque twist. I ran it threw all kinds of rough spots, and the owner competed with in in C2, and did pretty good considering he took it out of the box, worked on it for 5 minutes and entered it. IMO this is a good 23 bucks spent.
06-15-2016, 02:09 AM | #18 |
Rock Crawler Join Date: Jun 2009 Location: UK
Who sells those?
06-15-2016, 05:21 AM | #19 |
06-15-2016, 05:28 AM | #20 |
RCC Addict Join Date: Sep 2015 Location: Southern Maine
What is that contraption? How does it fit and what hooks to it? I don't do Facebook so in any look it up.
Options for Reducing Torque Twist - Similar Threads | ||||
ECX Temper Torque Twist Mod - Reduce torque twist | driftomaniacs | Scale Videos! | 0 | 05-14-2016 04:39 PM |
GC-3 Chassis trick reducing torque twist | Getrag | Losi Mini-Rock Crawler | 24 | 05-13-2011 08:42 AM |
Torque Twist | thebeast | Axial AX-10 Scorpion | 16 | 07-01-2009 06:53 PM |
Torque Twist Options | Mike Poulson | General Crawlers | 40 | 03-13-2008 06:33 PM |
Reducing torque twist/roll.....? | 5150bronco | Newbie General | 7 | 03-30-2007 12:47 AM |
