04-14-2017, 06:45 AM | #101 |
Rock Crawler Join Date: Dec 2014 Location: Union Bridge, MD
| Re: Codyboy Design: 1972 Chevrolet K10 Pickup Ascender
Looks great Ernie! SHOme Sent from my Speak and Spell |
04-14-2017, 06:49 AM | #102 |
Pebble Pounder Join Date: Jan 2016 Location: Port Huron
| Re: Codyboy Design: 1972 Chevrolet K10 Pickup Ascender |
04-14-2017, 08:56 AM | #103 | |||
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Codyboy Design: 1972 Chevrolet K10 Pickup Ascender Quote:
Ernie | |||
04-14-2017, 10:03 AM | #104 |
LOL, just measure in aboout 1" at 45* angle and then clip off that much of the rear corners. I think it'll look better and it should crawl better in tight spots. |
04-14-2017, 02:28 PM | #105 | |
To do that sounds easy, but had to build a new frame, each bed needs to be at a 22.5 angle. It was quicker than doing a retro on the old one. I built the frame as a one piece rap around, and mitered the frame at each bend. I will post photos later. Ernie Last edited by CODYBOY; 04-14-2017 at 02:31 PM. | |
04-14-2017, 04:29 PM | #106 |
I'm not surprised, I've done that kinda stuff now and then and then I look at it and have to re-do it. Now you've done it the way it should really be done. |
04-14-2017, 05:55 PM | #107 | ||
Just a start, but I think I'm going to like it! Everything is just sitting in place. The black lines on the cab are where the old cage was riding. I want the flatbed to ride a little lower than the bed of the cage did. Wheel base will be 12 3/8", so the rear should have good clearance. I'm going to do a tall rear bumper plate tucked up under the bed. That's where I'll mount the lights. Going to have a light bar mounted on a headache rack covering the rear window, and tapered bars running down each side of the bed. Starting to really get into this build! Ernie | ||
04-14-2017, 06:30 PM | #108 |
Nice! Now to leaf the rear and get that bed lower. Sent from my iPhone using Tapatalk |
04-14-2017, 08:02 PM | #109 |
Rock Crawler Join Date: Apr 2008 Location: pittsburgh
Or some side panels like 5he stock cage?
04-15-2017, 08:51 AM | #110 | |
When I get closer to mounting to the body I will take a look and see how I think it will look and function best. Good idea Rich, I should have painted the link mount black so it doesn't jump out at you. May even try to incorporate the stock panel. Thanks for the suggestion guys! Ernie | |
04-15-2017, 09:01 AM | #111 |
Quarry Creeper Join Date: Aug 2016 Location: Or-eee-gun
Nice work. Looks fantastic!
04-15-2017, 11:55 AM | #112 |
RCC Addict Join Date: Aug 2008 Location: Paulina
That's exactly what I was thinking of for my build. What's the thickness of the bed channel and wood?
04-15-2017, 02:05 PM | #113 |
04-15-2017, 05:07 PM | #114 |
Sure does. I had a 4ft stick of aluminum C channel, 3/8" ID of the channel, in my hands the other day but wasn't sure. Thanks for confirmation.
04-15-2017, 06:26 PM | #115 | |
Ernie Nice day today in Oregon, so needed to get some yard work done. So didn't spend much time in the shop. But I did get a little bit done on the bed. It is just sitting on a board, but is at about the height I'm going to run. Thanks for looking. Ernie Last edited by CODYBOY; 04-15-2017 at 06:38 PM. | |
04-15-2017, 07:45 PM | #116 |
Rock Crawler Join Date: Dec 2014 Location: In the sticks
Wow! I miss a few days and I come in to this! Super awesome Ernie But I'm starting to get a little jealous of your talents though |
04-15-2017, 07:49 PM | #117 |
Rock Crawler Join Date: Dec 2016 Location: Minnesota
Looking really good Ernie!! Sent from my SM-G930V using Tapatalk |
04-16-2017, 07:35 AM | #118 |
Quarry Creeper Join Date: Jan 2016 Location: US
Looks awsome Ernie! Looking at that thick piece of wood, I bet you could take a router to the back side of the board and rout out quite a lot of material. Just a thought to cut a little weight out. Sent from my SM-G900V using Tapatalk |
04-16-2017, 09:28 AM | #119 | |
OK, need some help from you guys. In order to get the bed as low as possible I need to put on some shorter shocks or clearance the bed for the shock towers. I'm going to make custom towers anyway. I could cover the towers and shocks on the top side with scale accessories. This would give me a little more shock travel. Suggestions? Ernie | |
04-16-2017, 11:36 AM | #120 |
Great idea on route out backside of wood, gives little more shock tower room too cantilever shocks or Proline Scaler 90mm shocks with x-rings so they don't leak.
Codyboy Design: 1972 Chevrolet K10 Pickup Ascender - Similar Threads | ||||
New Vaterra Acender: 1972 K10 Pickup RTR | fxman | General Crawlers | 4 | 07-02-2016 11:50 PM |
Vaterra 1986 Chevrolet K5 Blazer Ascender - Another Trail Run | eunique | Scale Videos! | 0 | 02-04-2015 12:26 AM |
RCBuzz - Vaterra Ascender (1986 Chevrolet K5 Blazer) | RCBuzz | Vaterra Ascender | 2 | 11-12-2014 09:15 AM |
Badger's 1986 Chevrolet K-5 Blazer Ascender | badger | Vaterra Ascender | 3 | 09-30-2014 12:16 PM |
