09-07-2016, 05:50 PM | #1 |
Rock Crawler Join Date: May 2014 Location: Cluj-Napoca,Romania
| First Vaterra rig:K5 Blazzer or K10 pickup
what shouldi get.I was waiting for the SCX10 II,but no luck as axial can't be right with the deliveries.So i decided to get my first vaterra.Wich one should i get.They look similar under the body(maybe i am wrong),probably the wheel base is different....So,any hints?
09-07-2016, 06:45 PM | #2 |
Rock Crawler Join Date: Apr 2008 Location: pittsburgh
| Re: First Vaterra rig:K5 Blazzer or K10 pickup
Its nice to get the kit, because you can make any of the 4 wheel bases ya want, and change a few things to improve performance when you build. With the rtrs, your limited to that trucks wheelbase unless you buy more parts.
09-08-2016, 02:12 AM | #3 |
So should i go for the blazer kit?
09-08-2016, 03:51 AM | #4 |
RCC Addict Join Date: Sep 2015 Location: Australia
All 3 of the ready to run trucks are the same chassis but built into the 3 different wheelbases to suit the 3 different bodies. Some other small differences like bumper mounts, no rear bumper or no side bars. All RTR's have the same radio gear, motor, electronics, gearbox etc etc. and all RTR's have the same mechanical parts that you would find in the builders kit like links, axles, steel gears etc. The Bronco is a wheelbase 1 chassis, the shortest. K10 Chevy pickup is at wheelbase 2 No RTR released yet in wheelbase 3 Blazer is the longest at wheelbase 4 Hope that helps with your decision. |
09-08-2016, 04:37 AM | #5 |
Rock Crawler Join Date: Oct 2015 Location: Kristiansand
If you like crawling, I am sure the K10 is the most "ready to run". I don't own an Ascender myself, but based on my scx10 experience, I would prefer not to have to trim wheel wells and drag that enormous k5 body around Sent from my SM-G930F using Tapatalk |
09-08-2016, 07:13 AM | #6 |
Pebble Pounder Join Date: Apr 2007 Location: shadyside
I went with the kit, but I like to build them, then picked up the k10 cab an cage, you will really like the rtr k10 trk before the rtr blazer, you cant go wrong with any of them thou.
09-08-2016, 09:31 AM | #7 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: First Vaterra rig:K5 Blazzer or K10 pickup |
09-10-2016, 06:12 PM | #8 |
Quarry Creeper Join Date: Jan 2016 Location: US
I just finished the kit last night, threw on an old body I had laying around (looked goofy, way too small) because I'm waiting on paint to come, and got to drive around for 15-20 minutes today. couldn't do much since I also hadn't glued the tires yet either.... ANYWAY....couple things about the kit, the measurements for the upper front link are still wrong (I realized that after it was installed...) the shims that go in the axles are there...but no mention of where they are supposed to go(I put both behind the gear to snug up the gear mesh as people suggested). I read of some people finding little paper inserts with additional instructions, but there were none in my kit. over all the build was pretty straight forward, instructions were not as clear as an sxc10....but the end product is much much nicer than a stock scx10, so a little head scratching and trips the the forum is well worth it!!! cheers!
09-14-2016, 02:52 PM | #9 |
Well radios doesnt help me much as i have a spektrum for all cars.I think i might go with the Blazer,altough i kind of like the K10.To bad that there is no KIT version of it as the electronics doesnt help mem uch,as i would anyhow throw a waterproof servo and some holmes combo
09-14-2016, 03:57 PM | #10 | |||
| Re: First Vaterra rig:K5 Blazzer or K10 pickup Quote:
09-14-2016, 03:59 PM | #11 |
So should i go for k10? Sent from my SM-N910F using Tapatalk |
09-14-2016, 04:03 PM | #12 |
Yes I would, but do you like the body?
09-14-2016, 06:58 PM | #13 |
Dont think of the KIT as a Blazer! It just happens to come with a Blazer body. The kit also comes with all the parts you need to build any of the 4 wheelbases, buy the kit, buy the K10 body, put your waterproof servo and Holmes combo in it, run it with your spektrum radio, job done! |
09-14-2016, 08:27 PM | #14 | |
Newbie Join Date: Jul 2016 Location: Oviedo
This.... That's what I did, we don't have much crawling areas around here so I wanted to run a peppy brushless setup. I can't leave shit alone, so the kit was my best choice, let me pick all my own everything. I personally picked the K5 to match my real truck, but I'm planning to buy the K10 body/cage to swap on if I want. Or it'll end up on my clod, either way it'll be slick. | |
09-15-2016, 02:27 AM | #15 |
09-15-2016, 02:34 AM | #16 | |
09-15-2016, 06:48 AM | #17 |
Buy the one that you like the looks of most. If you change your mind you can easily change the truck down the road. The Blazer body is huge and it will get hungup in the rocks. The K10 looks to be smaller, but then you have the different wheelbase. |
09-15-2016, 03:09 PM | #18 |
Was watching on yputube,the K10 looks more agile....
First Vaterra rig:K5 Blazzer or K10 pickup - Similar Threads | ||||
Codyboy Design: 1972 Chevrolet K10 Pickup Ascender | CODYBOY | Vaterra Ascender | 218 | 01-11-2018 07:11 AM |
New Vaterra Acender: 1972 K10 Pickup RTR | fxman | General Crawlers | 4 | 07-02-2016 11:50 PM |
F650 Pickup. My tow rig | lonleycreeper | Non Crawler RC's | 9 | 03-15-2014 02:20 AM |
Whose Green Pickup rig was on the RC Crawler home page logo a few days ago? | TheHeadHunter | Chit Chat | 4 | 02-18-2008 11:26 PM |
