Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Ascender
Thread: Yeti.Stealths Ascenders
Old 01-08-2019, 02:44 AM   #521
Yeti.stealth's Avatar
Default Re: Yeti.Stealths Ascenders
I tried RC4WD IROK foams in the Voodoo KLR X4 tyres, but they are too soft and starting to fall apart, tyres just folds over on sidehills or downhill turns and it just plows forward with understeer.
Forgot I had these 2 stage CI foams, just the inner non comp cut foam was a really good fit, I think I originally got these for XL size Scorpios.
Whew! Hot again today! Sweating up just working on a toy car!
Yeti.stealth is offline   Reply With Quote
Old 01-08-2019, 02:54 AM   #522
The CI single stage inner foam is a great fit and is nicely held in place by the narrow wheels, no side to side movement of the foam.
The diameter seems just right too, good amount of air gap and with all the rubber that’s in these KLR X4’s they kinda hold themselves up, and give a good amount of squish when the going gets tough and don’t roll over on sidehills or hard downhill turns, I think they are gunna be good, or maybe I’ve just gone silly in the heat
Old 01-08-2019, 05:43 AM   #523
That truck just has so much character. Fantastic!
Sent from my Vivo XI+ using Tapatalk
mgputer is offline   Reply With Quote
Old 01-08-2019, 10:55 AM   #524
MEOW
Natedog's Avatar
Looks much improved! Just looking at your pics from here maybe if the foams were 1/8" taller, might get even better. My original Blazer is setup with single stage foams that have compressed down and now have about 1/4" air gap inside and work great. Sweatin to the oldie foams, we're shivering lately over here, but summer will bring the heat again like you've got now.
Edit; missed the diff/driveshafts rebuild, great job, truck has seen tons of use!
Old 01-10-2019, 03:48 AM   #525
Old 01-10-2019, 04:21 AM   #526
Old 01-10-2019, 04:27 AM   #527
Old 01-10-2019, 04:32 AM   #528
Old 01-10-2019, 05:34 AM   #529
Time for a change, this is the Vaterra C10 body for the V100 on-road car, I was planning on making it for my son, with a styrene bed, but that project stalled. He is getting the Proline 1966 Chevy body now. So I will make use of this body!
The Ascender cage doesnít fit, body is too short, time to cut and extend.
The little on-road wheel arches are way off, more chop shop!
Comp crawler wheel arches roughed out.
Old 01-10-2019, 05:46 AM   #530
Iím gunna need some sheet metal, if only there was an old cab lying around that I could cut up....
Took the bonnet ( hood to you guys ) while I was at it.
The rear wall off the cab will get glued onto new cab and sandwiched in place between bed roll bar and plastic pieces inside cab.
The door skins will be the filler pieces for the bed stretch, the rear part of the opposite side door has the right shape.
Damn that shoo goo and drywall tap is on there good!
Old 01-10-2019, 05:50 AM   #531
Sanded the old paint off the door skins and cut up to suit the gap, with left over piece to be glued in behind.
Old 01-10-2019, 06:13 AM   #532
Wow! I didn't realize you could do that with lexan. What kind of glue?
Looks great.
Browneye is offline   Reply With Quote
Old 01-10-2019, 06:14 AM   #533
A bit of sanding and filler and more sanding, pretty rough actually, but itís meant to look like a comp crawler thatís been chopped...
The painting was a bit of a disaster actually, I wanted an off white or ivory but Tamiya PS paints for lexan donít come in this colour.
It will have to be painted on the outside because of the bed stretch, so I painted the inside with silver, thinking when the outside gets scratched the silver will show and look like metal....
So for my custom ivory colour, I tried emptying the rattle cans into one of those preval spray paint things, mixed up white with a dash of camel yellow, half way thru painting, not enough paint, ran out, thinned it out and got a little more, stabbed the can of white with a screw driver and drained last bit out, add a little camel yellow oh no different shade not matching different shades going on got paint runs gun splattering maybe brush it on in places.... aarrrggghhh!!!!
Walked away hot and cranky, thinking I will sand it down later, and just spray plain white straight from the rattle can!
Gave it a scuff up with a scotch brite pad and different shades coming thru, went a bit hard in places and the silver paint on inside of shell coming thru a bit. Itís starting to grow on me, stuff it! Letís sticker it up and roll with it!
Stickers, on purpose, to hide dodgy bed stretch panel work!
Old 01-10-2019, 06:16 AM   #534
Looks great.
Shoo goo Chris!
Stays rubbery and is Ďflexin with the lexaní haha
Old 01-10-2019, 06:21 AM   #535
The rear part of the body is screwed to the rear cage, two at the rear, and 3 on each side. Had to make spacers to stand the body off the cage, rear two spacers are a bit short and are pulling the tailgate in, I will fix that tomorrow and have a flat tailgate.
Old 01-10-2019, 06:27 AM   #536
Kept the hood off the old cab, if I ever start feeling nostalgic, I will clip it on there for a while!
Old 01-10-2019, 06:44 AM   #537
Interesting write up! There were many points along the way where I was like "Oh no! What is he doing? He's ruining it." But, in the end, it looks like it turned out well.
rkj__ is online now   Reply With Quote
Old 01-10-2019, 07:02 AM   #538
Very nice. Awesome job. I found out how easy and fun it is cutting up lexan bodies when I bobbed the rear of my original blazer body. I like it with the black hood. Makes it look mean! Nice job.
Ben
Itali83 is offline   Reply With Quote
Old 01-10-2019, 10:17 AM   #539
CODYBOY's Avatar
Attachment 378185
Attachment 378186
Attachment 378187
Attachment 378188
Very nice Dean, I like the thinking out of the box work!!!! Your rigs always look like such shelf queens Hope it survives your test of time.
Ernie
CODYBOY is online now   Reply With Quote
Old 01-10-2019, 10:24 AM   #540
Fantastic. Turned out really well.
Yeti.Stealths Ascenders - Similar Threads
Life of one YETI - Tom Frajer's Axial Yeti build log TomFrajer Axial Yeti 320 05-22-2017 09:01 PM
Comp classes for ascenders? Biomedchad Vaterra Ascender 15 04-15-2016 02:19 PM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
