03-22-2019, 05:25 PM | #601 |
| Re: Yeti.Stealths Ascenders
Likey! Nice truck, how fast does it go?
03-22-2019, 09:28 PM | #602 |
RCC Addict Join Date: Sep 2015 Location: Australia
Nah it's not fast Nate, still using stock rtr gearing. With the 550 21t motor on 2S its as fast as a 540 35t on 3S. And on 3S it scoots along a bit faster than that. It should be the same as your ascender you have with that same motor.
03-25-2019, 04:51 PM | #603 |
Hey Dean, was just kidding about the speed, there's no more likey button, so I had to say something more. Usually first question out of a bystander, "How fast does it go?" |
03-25-2019, 05:14 PM | #604 | |
I wanna be Dave Join Date: Apr 2012 Location: Merrill, WI
| Re: Yeti.Stealths Ascenders Quote:
Sent from my Vivo XI+ using Tapatalk | |
03-25-2019, 07:27 PM | #605 |
Ah you got me there Nate LOL! I was thinking to myself “ he should know how fast it is, it’s the same spec as his “ |
03-25-2019, 08:15 PM | #606 |
Yeah, but NOBODY has one with that sweet custom body/cage setup you made... Keep the rubber side down, down under! |
03-26-2019, 05:27 PM | #607 | |||
Good one. | |||
03-27-2019, 12:40 AM | #608 |
Hey Durok! We don’t worry too much about keepin’ it rubber side down! Just gotta roll with it mate! Glad you dig my new body. I made a mistake when I ordered the link spacers to extend the Bronco to wheelbase 4 and did not get enough of them, have been ordering from amain a bit lately due to nil in stock locally of the parts I need. Amain always have everything, envious of you guys with ya big fancy hobby shops and ya custom parts and ya axialfests and ya proline by the fires and ya G6’s ...... Got me some titanium rear lower links for both rigs, and now have all the parts I need to convert the Bronco. The titanium parts are surely gunna make it go faster now! I’m bettin’ it will be over 9000! |
03-30-2019, 12:23 AM | #609 |
It’s the end of the road for the Bronco! Time to stretch it out to wheelbase 4 for use under the proline 66 Chevy pickup body. Disconnect all the links from the skid plate and chassis, and remove all the skid plate screws. Fit the longer male and female driveshafts to the rear. Unscrew the upper links and remove the short set screws. |
03-30-2019, 12:30 AM | #610 |
Remove the short set screws and replace with the longer ones, slip a 12 mm spacer on and reassemble. The rear upper and lower links need a spacer on each end and the front links only require 1 spacer. Last edited by Yeti.stealth; 03-30-2019 at 03:53 AM. |
03-30-2019, 12:35 AM | #611 |
I used SSD titanium rear links for the lower links only so no spacers required, the SSD links are one piece at the correct length for WB4. 1 spacer added to each front link. Checking links against Rich’s post. Very helpful. |
03-30-2019, 12:43 AM | #612 |
Starting at WB1, with everything unbolted. Telescope chassis apart, slide apart by hand and stop on the correct mark stamped into the outside of chassis rail. Slide the skid plate along to the correct mark that is stamped on the inside of chassis rail. Refit links, battery tray mounts etc and screw it all back together. I had to lengthen the motor wires and use a servo extension cable to finish it off. |
03-30-2019, 01:01 AM | #613 |
Got me some Vaterra V100 body posts, I need 2 more short ones for the pick up bed. New body just sitting on chassis. Looks good! |
03-30-2019, 01:19 AM | #614 |
What’s in this old box I got stashed away.... Good times! This will be great for the next trail drive! No hurry now to get the 66 Chevy body done, I think the old Blazer body will get another run for a while! |
03-30-2019, 02:33 AM | #615 |
RCC Addict Join Date: Nov 2010 Location: England
That's had some use I still have my unpainted K5 body in the box.
03-31-2019, 03:03 AM | #616 |
Yes had some use for sure m1tch, that’s my old rtr blazer body from years ago. It saw some action today on a trail drive, was good to get out and wheel with my son driving the blazer. |
03-31-2019, 03:14 AM | #617 |
Today’s trail drive, sand, rock, dirt. Followed a trail down to a little beach and explored to granite nearby. Some parts we drove, some parts we climbed! |
03-31-2019, 03:18 AM | #618 |
| Re: Yeti.Stealths Ascenders |
03-31-2019, 03:19 AM | #619 |
I "likes".
03-31-2019, 03:22 AM | #620 |
Yeti.Stealths Ascenders - Similar Threads | ||||
Life of one YETI - Tom Frajer's Axial Yeti build log | TomFrajer | Axial Yeti | 320 | 05-22-2017 09:01 PM |
Comp classes for ascenders? | Biomedchad | Vaterra Ascender | 15 | 04-15-2016 02:19 PM |
