01-07-2019, 07:18 PM | #621 |
RCC Addict Join Date: Sep 2017 Location: The OC
| Re: What did you do to/with your Ascender today
Scaler-fab...check 'em out. Good and cheap. They're steel but the paint flakes off. Oh well. I'm not sure if the stock K5 ascender ones fit or not - I have a couple of those. They're nylon plastic and hold up pretty well. Last edited by Browneye; 01-07-2019 at 07:21 PM. |
01-07-2019, 08:14 PM | #622 |
Rock Stacker Join Date: Jan 2018 Location: East Snob
A few days late, but Jeffery, Walter and Donnie got some new duds, courtesy of Codyboy, aka Ernie.... While this aggression will not stand, the boys are patiently waiting to test out the new legs.... |
01-07-2019, 09:23 PM | #623 | |
Rock Crawler Join Date: Dec 2018 Location: Ontario, Canada
| Re: What did you do to/with your Ascender today Quote:
The Scaler Fab sliders are the best I’ve seen, but I don’t want to pay over $40 for them at this time. I have not even received my credit card statement with the truck on it yet! Sent from my iPhone using Tapatalk Last edited by rkj__; 01-08-2019 at 07:55 AM. | |
01-08-2019, 08:09 PM | #624 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
Lets see that steering!!!! Did you get the tire rub figured out? Ernie | |
01-09-2019, 08:53 PM | #625 | |
To the right: From the angle of the pic, it may be hard to see, but I am getting tire rub on the panhard bar mount... I have adjusted the endpoints, but that just limits the steering... Thinking I "may" be able to carve out some space and move the panhard bar mounting point up higher and closer to the frame, but before I do, I will let those with more (IE: literally any) experience with suspension geometry chime in... LOL | |
01-10-2019, 10:03 AM | #626 | |
Hey DJ, I can't see what wheels you have on your truck, but if you could go to a little wider hub, I would do that before you start changing pan hard geometry. JMO. If you want to try some different widths, I could send you some to try before you lay $$$ for new ones. Ernie | |
01-10-2019, 10:49 AM | #627 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
hey man, those axles really tie the rigs together ;) *while we are talking geometry, that bend in the tie rod should be jutting forward, not downward. its to clear the pumpkin at full steering lock. ;) Last edited by Shinchu; 01-10-2019 at 10:51 AM. |
01-10-2019, 09:01 PM | #628 | |
Yeah I got the tie rod squared away.... Wheels are SSD Beadlock 8 spoke steelies w/ the brake rotor hubs.... Thinking I am going to grab some 3 and 6mm offset hubs to try to see if I can get them to clear the panhard mount.... | |
01-13-2019, 03:14 PM | #629 |
Quarry Creeper Join Date: Jun 2017 Location: St George
Getting Chevy zr2 body ready. I liked the Toyota body but it hasn’t held up. Seems like every time I take it out it cracks. I can use my front bumper but it looks like I’m going to have to ditch the rear. It has a molded bumper not sure how it’s going to hold up. Sent from my iPhone using Tapatalk |
01-13-2019, 07:54 PM | #630 |
Woohoo another ZR2. Sent from my iPhone using Tapatalk |
01-15-2019, 02:36 PM | #631 |
This just came across my desk today... Protek has updated their compact LiHV packs to 4100mah, up from 3600 for the previous generation. I have a couple of these...the chief complaint is that some can puff after 30-40 cycles. I have about that on my first one and it's just ever so slightly starting to puff (especially on a hot day), but still working fine, so... I charge them to 4.3/cell. I'm going to drop that down to 4.25, and my standard lipos to 4.15 for longest life/most cycles. I try to never leave them at higher than storage charge for more than a day. So far I've had good luck with my lipos. IMO this is the defacto choice for Ascender...YMMV. I've run them for several hours - 2-3 hours at a time - and never run down near 50% - usually they still show 3.85-3.9 volts when I put them on to discharge. I have never had one auto-shut off for low voltage. AMain has/had them, also losipartshouse.com here in LA. I thought the latter would discount them some, but still $59.99 although free shipping. I guess their 2019 stock just came in. |
01-15-2019, 05:54 PM | #632 |
Strapped my mountain bike lights to my Ascender for some night crawling testing. Ok, so the light cannon in front of the grille is not very “scale” but it kinda works. LoL Sent from my iPhone using Tapatalk |
01-23-2019, 09:25 PM | #633 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
I removed a glued Super Swamper from its wheel. It can be done, but releases a pretty good blast of chemicals |
01-25-2019, 08:00 AM | #634 |
I did not do this today, but I’m considering colour matching the aluminum cage panels on my truck. I think I'll try it out when I get a chance. Sent from my iPhone using Tapatalk Last edited by rkj__; 01-25-2019 at 11:13 AM. |
01-26-2019, 08:22 AM | #635 |
RCC Addict Join Date: Nov 2010 Location: England
At last someone in the Uk had SDD's rear axle weights. So installed them while it's chucking it down with rain and waiting for my week long cold to go away. |
01-26-2019, 09:47 AM | #636 | |
01-26-2019, 11:12 AM | #637 | |
That’s a clever method. I’m going to try covering the panels with some stick on vinyl. I’m only in it for $1.50. Sent from my iPhone using Tapatalk | |
01-26-2019, 07:13 PM | #638 |
Newbie Join Date: Feb 2016 Location: Henry Co. GA
I dusted the cobwebs off the ole K5 and ran a pack, its been a almost 3 years since ive posted and drove it. been flyin Fpv and having a blast but i always come back. thinking about doing the two speed upgrade that i never got around to doing since i have all the parts to do it. also maybe switching to a hardbody rubicon.
01-27-2019, 05:42 PM | #639 |
| Re: What did you do to/with your Ascender today |
01-27-2019, 08:34 PM | #640 |
Finally got around to installing the 6mm spacers I got the other day to see if the tires would stop rubbing on the panhard bar mount... They did stop... May have gotten away with 3mm, but this gives me more room for the Codyboy Steering to flex its muscle... |
What did you do to/with your Ascender today - Similar Threads | ||||
i got a vaterra ascender rtr today | 4x4pornstar | Indiana | 8 | 12-20-2015 11:29 AM |
My Ascender Built, One Bad ascender | CustomCrawlRCMike | Vaterra Ascender | 3 | 07-03-2015 03:45 PM |
