11-23-2019, 08:45 AM | #701 |
Rock Stacker Join Date: Oct 2019 Location: Lantz, NS
| Re: What did you do to/with your Ascender today
I moved the light bar from the cage to the front bumper. The light is actually useable there, as it was just reflecting off the white roof before. I also installed a BEC as the Savox 1230 just wasn't getting enough power from the ESC, and I hooked up the headlights to the front body posts so they'll come on when the body is put on. They are still on a switch though incase I don't want them on. All the new wiring is temporary as I'll be redoing it all when my new ESC arrives. Oh, I also camo wrapped the aluminum bits on the rear. Sent from my VOG-L04 using Tapatalk |
12-05-2019, 09:04 AM | #702 |
Pebble Pounder Join Date: Jan 2019 Location: Corning
Rigged me up a servo winch. All is well except how I have the line run through the bumper. Any ideas to make it better would be appreciated
12-06-2019, 12:45 AM | #703 |
Quarry Creeper Join Date: Feb 2016 Location: Pembroke ON Canada
Finally finished my GCMracing install. Back to the K10 from a Proline Kodiak/Topkick Sent from my FRD-L14 using Tapatalk |
12-06-2019, 12:49 AM | #704 |
And gcmracing rear truss. Ended up readjusting both up rear links to 4.5mm instead of the 3mm gcmracing said to and all looks good. Sent from my FRD-L14 using Tapatalk |
12-06-2019, 10:03 AM | #705 |
YOu could cut out a larger hole in that bumper and bolt a fairlead on or buy/make a different bumper. Motor forward, very nice! |
12-06-2019, 11:59 AM | #706 |
Looking for suggestions to find inner fenders sections for my K10. In comparison to my trx4 K10 having inner fenders just helps the cosmetics of not seeing the inside electronics as much. any ideas? Red is for comparison of yellow what i want to do. Sent from my FRD-L14 using Tapatalk |
12-06-2019, 12:04 PM | #707 |
Didn’t even think about the fair lead route! This lil rig is a crawling machine. With Trujillo spring mod plus inner ink pen spring it’s solid with almost zero TT
12-10-2019, 07:51 PM | #708 |
So been trying to fix the Issue of drag lin and panhard to minimize the bump steer made no progress. What are the correct link lengths for panhard and drag links? Reusing stock rod ends. Sent from my FRD-L14 using Tapatalk |
12-10-2019, 10:22 PM | #709 | ||
| Re: What did you do to/with your Ascender today Quote:
Just measured, my custom tie-rod is 145mm eye to eye (stock uses 90mm aluminum tube with 20mm setscrews and stock plastic ends). This is same for all Ascenders regardless of wheelbase. Drag link for WB1/WB2 is shorter than WB3/WB4 WB1-2 is not sure as I don't have one. WB3-4 is about 75mm eye to eye, however I prefer to run a longer adjustable turnbuckle to top of steering knuckle, with plastic ends that is about 90mm eye to eye. Stock uses 38mm aluminum tube with two 20mm setscrews and stock plastic ends, eye to eye about 75mm length. BRB, gotta see if I can find my stock one to measure. Updatess... Ascender manual for K5 Blazer KIT WB4 is here, starting on page 30, step B9 Lower steering link assembly: https://www.horizonhobby.com/pdf/VTR03023_Manual.pdf Exploded view of the F100 WB2: https://www.horizonhobby.com/pdf/VTR...loded_View.pdf VTR23406 is listed as the steering linkage parts, but there was an omission of the part number for shorter wb draglink length and part number. The proper length is listed in my Ascender thread, if you read through it, iirc it was 30mm aluminum tube plus the setscrews and plastic end link bits. Last edited by Natedog; 12-10-2019 at 11:33 PM. | ||
12-11-2019, 12:18 PM | #710 |
Rock Crawler Join Date: Jun 2018 Location: Orange County, CA
I donated mine to a young man at work because I have too many in my collection. I'll miss my first trail/crawler RC! It was a TANK!
12-11-2019, 07:31 PM | #711 | |
Thank you for the response it is very much appreciated and helpful. I need to get me a Calipers to get more exact measurements and details Sent from my FRD-L14 using Tapatalk | |
12-12-2019, 10:45 AM | #712 |
| Re: What did you do to/with your Ascender today |
12-12-2019, 06:58 PM | #713 |
Why have a link on top of one knuckles and. Other under it? For bolt on position? Sent from my FRD-L14 using Tapatalk |
12-13-2019, 06:34 AM | #714 |
Rock Stacker Join Date: Apr 2018 Location: GR, MI
Look at the second pic Natedog posted. The goal is to have the steering link and the panhard link parallel to each other when looking at them from the front.
12-13-2019, 11:12 AM | #715 |
I didn't realize that. Sent from my FRD-L14 using Tapatalk |
12-21-2019, 12:42 PM | #716 |
12-25-2019, 06:07 PM | #717 |
Newbie Join Date: Dec 2019 Location: Colorado Springs
I picked up the Yeah Racing, Desert Lizard internal spring shocks. Set them up for 50/50 droop, (mid length soft springs between the Piston and lower cap, mid length medium weight springs in the upper part of the shock, single hole pistons, 10wt oil). This setup has virtually eliminated any torque twist.
12-25-2019, 08:35 PM | #718 |
Rock Stacker Join Date: Jan 2018 Location: East Snob
12-25-2019, 09:10 PM | #719 |
People say there is no such thing as Santa....
12-28-2019, 02:52 PM | #720 |
Got me some cheap beadlocks, pitbull mad beasts, and CI dual stage foams. I also made me a servo winch out of 25kg servo.
What did you do to/with your Ascender today - Similar Threads | ||||
i got a vaterra ascender rtr today | 4x4pornstar | Indiana | 8 | 12-20-2015 11:29 AM |
My Ascender Built, One Bad ascender | CustomCrawlRCMike | Vaterra Ascender | 3 | 07-03-2015 03:45 PM |
