06-16-2017, 05:53 PM | #1 |
Rock Stacker Join Date: Apr 2017 Location: CT
| Hubs and Knuckles
I'm in the process of installing Vaterra aluminum hubs and knuckles on my Ascender Blazer. Or spindle and carriers as Vaterra calls them. I can't seem to get the spindle to slide over the carrier while the axle is aligned in the bearing inside the spindle. What am I doing wrong? It seems as if once the axle stub end goes in, it throws off the alignment of these two components.
06-16-2017, 08:41 PM | #2 |
Newbie Join Date: May 2016 Location: Rockies
| Re: Hubs and Knuckles
Run into the same problem each time. Turn the C hubs, get the axle shaft engaged, while keeping the shafts engaged rotate the C hubs to line up the screw holes. Hope that helps a bit.
06-17-2017, 05:58 PM | #3 |
| Re: Hubs and Knuckles Thanks! After reading this a couple times, it clicked. Then I knew what I had to do. Went right together, but it's still a mystery to me why it wouldn't line up. |
06-23-2017, 10:18 AM | #4 | |
| Re: Hubs and Knuckles Quote:
Good. I was reading RPP Hobby's blog on their Ascender build the other day and they said to install the knuckle to the C and then install them to the axle housing as a unit. Little more work if you're doing field repairs due to steering linkage but this helps the inner axle shaft line up with the spool. | |
Hubs and Knuckles - Similar Threads | ||||
VP 8* knuckles and hubs | Mutant_Xj | Axial SCX-10 | 0 | 02-19-2012 02:45 PM |
knuckles and c hubs | hoghead5150 | Axial Wraith | 5 | 09-17-2011 10:45 PM |
inner knuckles (c-hubs) | twistedsmily | Newbie General | 4 | 07-12-2008 07:39 AM |
