06-11-2017, 09:02 PM | #1 |
Newbie Join Date: Jun 2017 Location: Hendersonville
| Out boarded my rear shocks and now i have issues
I out boarded the rear shocks and now I seem to have a lot less rear articulation. it seems to take a lot more force to get the suspension to compress. I have the Vaterra Aluminum shocks mounted. Overall the shocks seem mushy and less responsive. any thoughts on the cause? Thanks |
06-11-2017, 10:46 PM | #2 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Out boarded my rear shocks and now i have issues Quote:
Ernie | |
06-12-2017, 04:37 AM | #3 |
Rock Crawler Join Date: Dec 2009 Location: Suffolk
The shock has more leverage on the axle now so you effectively increased the spring rate for when the axle twists. Spring rate for compressing the axle on both sides equally has not changed but that is a rare occurrence in normal crawling. This is also the reason you are getting less torque twist. The torque twist solution that has the least affect on axle articulation is moving the upper link chassis mounting locations up. If your shocks seem stiffer when compressing the axle equal on both sides, something else is going on. Check your ring that floats between the two springs. It likes to drag on the threads of the shock body at least on the stock shocks. |
06-12-2017, 06:06 AM | #4 |
Thanks, I guess I will look in to moving the links up and double check how the shocks are moving. Thanks help! |
06-13-2017, 12:02 AM | #5 |
Rock Crawler Join Date: Apr 2008 Location: pittsburgh
There def is less travel after outboarding
Out boarded my rear shocks and now i have issues - Similar Threads | ||||
Rear SSD Diamond Offset issues | Beorn | Axial Wraith | 22 | 10-25-2015 11:19 PM |
Dingo Rear Axle issues | Huber1918 | Axial SCX-10 | 14 | 04-09-2013 11:37 PM |
Rear differential issues? | Kanine38 | Axial AX-10 Scorpion | 18 | 05-18-2010 05:48 PM |
issues with rear axle build | slegh | Tamiya TLT Crawlers | 6 | 06-02-2008 08:57 AM |
Mamba Max Issues... Rear not working? | run2jeepn | Electronics | 16 | 07-27-2007 02:12 PM |
