Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Ascender
Thread: I bought a blazer kit....
Old 04-16-2016, 10:32 AM   #1
Default I bought a blazer kit....
... About 6 mo ago. Been having fun running it stock. Only things ive done were added some beadlocks, and a dummy v8 thru the hood. Running a rc4wd 45 turn, trx xl5, and an lhs500bbmg servo. Also a traxxas am radio I had lying around.
rag6 is offline   Reply With Quote
Old 04-16-2016, 10:41 AM   #2
Default Re: I bought a blazer kit....
[/URL]
[URL=http://s649.photobucket.com/user/gizmorc371/media/Mobile%20Uploads/IMG_20160416_123646_zpsjpptrxps.jpg.html]
Old 04-16-2016, 11:49 AM   #3
So... This truck has been great stock, but now I want to start upgrading. What should I do first? My shocks kinda suck, was thinking of getting a set. Any suggestions?
Old 04-16-2016, 01:39 PM   #4
Natedog's Avatar
Looks like fun, you need some zoomie pipes sticking out too!
Read some of the build threads here, stock shocks can drill pistons, lower ride height etc. If you want new shocks the Vaterra aluminum one are very nice! What mods did you have in mind?
And welcome to RCC and congrats on your Ascender!
Old 04-16-2016, 01:51 PM   #5
I agree with Nate, the vaterra aluminum shocks are a real nice choice for the truck. I would consider adding some good aluminum diff covers, they hold also are what holds the diff bearings in place and they will add some rigidity to the axle housing and help keep the ring and pinion mesh right on the money. Maybe also consider some metal sliders like the SSD ones. The stock ones get hung up on stuff.
HDMM is offline   Reply With Quote
Old 04-16-2016, 02:09 PM   #6
Checking out the gcm relocation kit. The shocks that gcm offers are pretty sweet, I would like to get a set for the front that would match. I see that many here like shocks shorter that stock. What length front shocks would be best to go along with the relocation kit out back?
Old 04-16-2016, 02:25 PM   #7
Natedog's Avatar
Thanks HDMM, to mention aluminum diff covers, SSD is the shiz.
Metal sliders are great addition, GCM forward relocation kit is sweet. Any shocks can be internally limited to get travel you want.
Old 04-16-2016, 03:08 PM   #8
Cool. Ill I'll check the sliders out and front motor kit too. Right now I have 2 shocks, hat are leaking and worn out. Do you know the length of the gcm rear shocks? Wondering if my traxxas big bores would work?
Old 04-16-2016, 03:21 PM   #9
The SSD sliders are defintely one of the best upgrades right out of the box. They slide over everything and work great to pivot around rocks as well.
NickDanger is offline   Reply With Quote
Old 04-16-2016, 04:54 PM   #10
I'm running the GCM rear shock kit with 90mm front shocks and 70mm in the rear for my lowered setup. To keep a level ride height with the GCM kit, you want a front shock that is 20-25mm longer than the rear.
svt923 is offline   Reply With Quote
Old 04-16-2016, 08:08 PM   #11
Sweet. That helps a lot. This truck needs to get lower. Im about as low as I can go on body with out cutting it.
Old 04-20-2016, 12:35 PM   #12
I think I want a 2 speed...
Old 04-20-2016, 02:19 PM   #13
They are nice. I love mine. Very versatile. I get myself of situations with high gear that only high KV brushless motors would do. I don't use it much, but when it do, it really works.
Ben
Itali83 is offline   Reply With Quote
Old 04-20-2016, 05:26 PM   #14
II run a lot on hills with loose dirt. I have a 45 turn rc4wd motor. I also have an mmp sitting here doing nothin. Could I run 3s with that motor? Would my low speed throttle control suffer? What I mean is, will I not need the 2spd if I run 3s?
Old 04-20-2016, 06:33 PM   #15
Natedog's Avatar
Yes, you could run that motor on 3S, low speed control will suffer unless you use smaller pinion gear on motor. Do both.
Old 04-20-2016, 08:35 PM   #16
Nice... I can do that for the price of a battery, and a couple of connectors!
Im gonna get 2 of these and run them in parallel:
http://spcracingbatteries.com/index....&product_id=53
Old 04-20-2016, 11:26 PM   #17
Found my driver
And put in a dash. Top of dash is from a 1/8 scale buggy, with a bunch of styrene shoegoo`d to make firewall. Steering wheel was the plastic inner ring of a roll of pinstripe, with the pinstripe wrapped around it to make the grip
Old 04-20-2016, 11:40 PM   #18
And I know its sloppy. Ive never done this before, so I gotta start somewhere right?
Old 04-20-2016, 11:43 PM   #19
I think this will be my electronics layout, with the rx just in front of the mmp
Old 04-20-2016, 11:55 PM   #20
Or I could do this w/battery mounted normally
But something tells me to leave the spot up front open...
I bought a blazer kit.... - Similar Threads
Just bought the kit; could use your advice Angus_Beef Vaterra Twin Hammers 17 03-04-2015 05:43 PM
Just bought a Wraith Kit Tommy_Boy_1184 South Carolina 31 03-12-2012 03:33 PM
buildin a kit i bought axialnut Axial AX-10 Scorpion 2 01-19-2011 01:28 PM
bought the AX 10 KIT bjerk1 Axial AX-10 Scorpion 1 09-24-2009 01:47 PM
