Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Ascender
Thread: VTH trans
Old 07-31-2017, 07:50 PM   #1
Default VTH trans
Will the VTH trans fit bolt-up to the ascender skid?
Thickone is offline   Reply With Quote
Old 07-31-2017, 09:32 PM   #2
Default Re: VTH trans
Yes. Are you looking for the 2 speed option in an Ascender?
Ascender'nMN84 is offline   Reply With Quote
Old 08-01-2017, 03:21 AM   #3
Yes and no. If you are taking a twin hammers transmission out of a twin hammers and trying to put it in an ascender, no it will not drop right in. The motor plate is different and there is one screw holding it on from inside of the transmission case. Which means you have to split the transmission case to remove the motor plate. Once you put the ascender motor plate on, it'll drop in the ascender skid. Found that out the hard way myself.
Ben
Itali83 is offline   Reply With Quote
Old 08-01-2017, 10:31 AM   #4
Thanks Ben
Old 08-01-2017, 11:25 AM   #5
Originally Posted by Thickone View Post
Thanks Ben
No problem
VTH trans - Similar Threads
Twin Hammers 3D Printed Stinger Di_Spencer Vaterra Twin Hammers 37 09-25-2017 10:36 AM
VTH Electronics/Upgrades? Weichert crawling Vaterra Twin Hammers 4 02-14-2016 08:54 AM
Outrunners in the VTH cooperDG123 Vaterra Twin Hammers 11 11-07-2013 07:21 PM
vxl experiences on VTH diesel kawboy Vaterra Twin Hammers 2 11-05-2013 10:38 AM
