08-03-2017, 02:39 PM | #1 |
Quarry Creeper Join Date: May 2017 Location: Bellevue
| Vaterra aluminum coil over shocks
Anyone happen to know what weight shock oil comes in the (VTR334017) Vaterra aluminum shocks? Any recommendations on what oil weight I should use? Sent from my iPhone using Tapatalk |
08-03-2017, 03:28 PM | #2 |
Rock Crawler Join Date: Jan 2012 Location: Hudsonville, MI
| Re: Vaterra aluminum coil over shocks
I've read 30wt works well in them, and also limit them internally 5 or 6mm. Sent from my iPhone using Tapatalk |
08-05-2017, 09:28 PM | #3 |
Rock Crawler Join Date: Dec 2016 Location: Minnesota
So I actually just took these off my truck. They just didn't pass my bench test as I felt like the collar was grabbing too much on the threads and they seemed to want to lock into place and not move until forced. I would set it on a spare tire or 2 and whatever wheel was raised by the tire would stay when I picked the truck up. One of my other big gripes was the top mount and the lack of pivot ball. Yes there are ways to get close with fuel tubing or shrink tube but I was never 100% satisfied. Sitting at the bench tonight looking at them I solved part(s) of my problem(s). Sticky collar? I'm gonna give them a go without the upper spring and collar. Lack of pivot ball issue? Steal the tops off the stock plastic shocks as they screw on just fine. They might leak or come loose but I figure it's worth a shot. I'll report back after get around to making the change. Sent from my SM-G930V using Tapatalk |
08-06-2017, 01:11 PM | #4 |
I hear ya. I ended up sanding the inside of each collar and that really did the trick. Sent from my iPhone using Tapatalk |
08-07-2017, 05:29 AM | #5 |
I had a RTR Ascender a couple years ago. I didn't keep it long, ended up selling it to fund another project. Anyway.... I put the Vaterra aluminum shocks on my RTR. It seems like I used the the pivot balls out of the stock shocks, and put them in the aluminum shocks. I can't remember for sure, but I did something like that. I know that didn't use fuel tubing or shrink tubing on them. Did you try popping the pivot balls out of the stock shocks and put them in the aluminum shock caps? Sent from my iPhone using Tapatalk |
08-07-2017, 07:21 AM | #6 | |
| Re: Vaterra aluminum coil over shocks Quote:
Sent from my SM-G930V using Tapatalk | |
08-07-2017, 07:25 AM | #7 | |
Hmmmm.... Ok. I remember using something in those aluminum shock caps. I just can't recall what I did exactly. Regardless... Good to know the plastic cap is working for ya!! Sent from my iPhone using Tapatalk | |
08-07-2017, 09:46 AM | #8 | ||
Nice to know the caps interchange. | ||
08-07-2017, 01:31 PM | #9 | |
Yes I put the stock pivot balls in the aluminum shock cap. What I did was put an o-ring on the inside against the flange side of the pivot ball and that got rid of the excess movement. Sent from my iPhone using Tapatalk | |
Vaterra aluminum coil over shocks - Similar Threads | ||||
Vaterra coil over shock | JIMBO1810 | Newbie General | 1 | 03-04-2017 09:25 AM |
Vaterra Aluminum shocks adjusting | nickunger2784 | Vaterra Ascender | 2 | 09-23-2016 08:50 PM |
Vaterra Adjustable Coilover Aluminum Shocks | JatoTheRipper | Vaterra Ascender | 16 | 06-24-2016 09:43 PM |
Vaterra aluminum shocks | Power to Satisfy | Vaterra Ascender | 9 | 01-11-2016 06:59 PM |
