08-03-2017, 03:26 PM | #1 |
Rock Crawler Join Date: Jan 2012 Location: Hudsonville, MI
| Questions about narrowing axles.
I'm thinking about narrowing my Ascender axles, but I have a couple questions. I've been reading some threads about narrowing the axles, and I've seen that some people have narrowed them 6mm and 12mm. When they say that they narrowed them 6mm, is that 3mm per side, or is it 6mm per side? How much do I narrow the Ascender axle to make it the same width as the Yota axle on the TF2? How much per side? What's the best method (or tool) to use when trimming the axles, to make sure they're cut straight? Thanks in advance! Sent from my iPhone using Tapatalk |
08-04-2017, 07:52 AM | #2 |
| Re: Questions about narrowing axles.
6 mm per side (12 mm total) is the most the housing are designed to be narrowed. Narrowing them by the maximum amount gets them down to 180 mm which is the same as RC4WD Yota II axles (the Yotas on the TF2 are 178 mm so close enough). To make sure I cut them straight, I use the rear lockout as a guide to keep the cut square after I marked off 6 mm (slip it on the housing up to the 6 mm mark then cut at the end of the lockout). I used either a razor saw or hack saw to do the cutting. Drilling the new screw holes for the rear housing is easy since it doesn't matter if the holes line up perfectly from left to right, the front is a little more tricky. There is a mold seam on the axle housing and c hub that line up perfectly at 0 caster. I use that as an index mark to make sure both sides were even before drilling the c hub mounting holes. |
08-06-2017, 07:24 PM | #3 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
Man this like switching to geico. I was about to buy RC4WD k44 axles until i saw this. Although the k44 may look nice, its more about budget for now. There is only one question i have about this... after narrowing, can you still run cody boy mod? That would be the ultimate set up, imo. |
08-07-2017, 05:22 AM | #4 | |
| Re: Questions about narrowing axles. Quote:
Thank you very much! That answers all of my questions! Sent from my iPhone using Tapatalk | |
08-07-2017, 06:59 AM | #5 | |
If you haven't bought the axles yet, you can ask to have Ernie narrow them when you order. I'm sure a man of his skills can handle it. | |
08-07-2017, 08:09 PM | #6 |
Pebble Pounder Join Date: Jan 2016 Location: Port Huron
8mm is the max you can narrow with codybody axles I have them on my c1. The chub is up against the link mount on the front axle. To narrow just the stock plastic housing I use a pipe cutter. Keeps it straight without guessing. Sent from my iPhone using Tapatalk |
08-07-2017, 08:11 PM | #7 | |
The pipe cutter is an awesome idea!! I have a decent pipe/tubing cutter, didn't even think about using that!! LOL!! Sent from my iPhone using Tapatalk | |
08-07-2017, 08:16 PM | #8 | |
This is what you used to cut the axle housings? Sent from my iPhone using Tapatalk | |
08-08-2017, 04:07 AM | #9 |
| Re: Questions about narrowing axles. |
Questions about narrowing axles. - Similar Threads | ||||
Narrowing the axles? | mmbackpacker | Axial SCX-10 | 7 | 07-12-2009 06:56 PM |
Wheel questions..Locking rings, narrowing ect.... | RYY | Tires and Wheels | 2 | 10-16-2006 11:15 PM |
A few questions about narrowing | joshm101 | Tires and Wheels | 4 | 06-16-2006 09:41 PM |
Narrowing 40 Seires Beadlocks Questions | Samurai | Newbie General | 3 | 04-30-2006 08:19 PM |
Narrowing dually's.. A couple of questions.. | Heavy | Tires and Wheels | 2 | 11-02-2004 03:22 PM |
