09-07-2017, 09:37 PM | #1 |
Newbie Join Date: Jul 2017 Location: Canada
| Big Vivs Ascenders
New to here. Here's my 2 rigs. The yellow one I built from kit. The black one I got used. I plan on changing it to the shorter WB K10. Cheers! Sent from my SGH-I337M using Tapatalk |
09-07-2017, 09:42 PM | #2 | |
| Re: Big Vivs Ascenders Quote:
Sent from my SGH-I337M using Tapatalk | |
09-07-2017, 09:44 PM | #3 |
| Re: Big Vivs Ascenders |
09-07-2017, 10:36 PM | #4 |
Nice trucks! I had the same problem with my stock links. They bent like no other links I've ever dealt with.
09-08-2017, 10:15 PM | #5 |
Newbie Join Date: Feb 2015 Location: australia
I made 4mm stainless links on mine and just reused the stock rod ends drilled to suit, problem solved.
09-09-2017, 09:00 AM | #6 |
Newbie Join Date: Aug 2015 Location: Novara
same here, drilled and threaded 6mm diameter stainless steel rods, no issues so far
09-11-2017, 04:29 PM | #7 |
Where do you get the 4mm stainless food from? Sent from my SGH-I337M using Tapatalk |
09-11-2017, 04:30 PM | #8 |
Rod. Sent from my SGH-I337M using Tapatalk |
09-12-2017, 03:19 PM | #9 |
Mounted up some Fanquish beadlocks and rock beasts. I really like the looks of the black wheels with this body better. The tires work nicely too! Sent from my SGH-I337M using Tapatalk |
09-28-2017, 04:23 PM | #10 |
Just an update... The second k5 blazer ascender has been dismantled. I sold the body and picked up the k10 cab and cage. Next will be changing chassis to WB2. Glad my first ascender was a kit for the extra bits! Pics coming soooooon..... Sent from my SM-G955W using Tapatalk |
09-28-2017, 05:38 PM | #11 | ||
Looking forward to some pics, love both my Ascenders! | ||
11-03-2017, 07:19 AM | #12 |
Finally got the body put together and painted. WB2 with rear WB4 links. Also put on the new SSD heavy knuckles and made up a weight to mount into the battery tray. Sent from my SM-G955W using Tapatalk |
11-03-2017, 07:22 AM | #13 |
Currently getting the electronics wired up. Integy 35t motor, hobby wing 1060 esc, hitec 7950 servo and castle bec. Sent from my SM-G955W using Tapatalk |
11-03-2017, 11:17 AM | #14 |
I just noticed that I think I have the front grill mounted upside down. Doh! That explains the gap on the top! Sent from my SM-G955W using Tapatalk |
11-03-2017, 12:02 PM | #15 |
11-03-2017, 02:04 PM | #16 |
SSD. Brass. Extra heavy. Yeah, they are nice and come with bigger than stock bearings.
11-08-2017, 05:49 PM | #17 |
Gonna try out these Hyrax tires. Looks like I'm going to have to do some fender trimming. Anyone else running these on the K10 Body? Sent from my SM-G955W using Tapatalk |
11-09-2017, 01:57 PM | #18 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
What wheels are those? I love the 8 hole wheels, especially for this type of truck.
11-09-2017, 02:26 PM | #19 |
11-09-2017, 02:28 PM | #20 |
Thanks. I may need to try a set.
Big Vivs Ascenders - Similar Threads | ||||
Yeti.Stealths Ascenders | Yeti.stealth | Vaterra Ascender | 758 | 08-23-2020 06:39 AM |
Comp classes for ascenders? | Biomedchad | Vaterra Ascender | 15 | 04-15-2016 02:19 PM |
