02-10-2018, 03:23 PM | #121 |
| Re: Ummm...
I'm stoked... I may need to try ordering another rear tower, this time in black - to see if I get multiple shock mounts AND body post mount screw pin holes... Boom Racing must be continually improving these. I am especially excited, because I've decided I don't particularly want to hack my cage up on the new body/cage that I'm preparing to install. With multiple shock locations front AND rear, my new shocks will be easier to set up properly for the 1.7" wheels and 4.19" tires - I'm going to be running lower all over, but am hoping to keep decent suspension travel AND crawlability! (BTW - that's my word of the day: "Crawlability") Pic from auction site of what the Boom Racing towers were "supposed" to look like (See? NO extra shock mount holes!): And, what the heck - here's the shocks I got, also on auction (pulled off a new TRX4, still oil-filled!), fire extinguisher, Hi-lift jack, recovery towstrap w/duffel bag, 18t (oh, yeah!) pinion, and..... SSD brass rear axle weights. There are a couple more scale items coming (one all the way from some of you guys homeland, AUSTRALIA!) but i am practically out of things that I even plan on getting - all I am toying with is replacing all the links with a stronger material - SS or Ti... I'm thinking of Ti turnbuckles mostly... There will be a set of 1.9" wheels that are currently back-ordered from LURC - but I got the rings and tires already, to clarify - these will be SHARED with one or both of my upcoming Bomber builds! ........cuz they are super-schweet and TALL, they may only be run using the existing basher body/cage that's got trimmed fenders. NOT trimming up the new body, keeping that one's fenders all nice and full. Pics of these also below - just setting the ring on a tire as I don't yet have the wheels. |
02-10-2018, 03:44 PM | #122 |
Quarry Creeper Join Date: Aug 2017 Location: Surface of the Sun
| Re: Ummm...
I am definitely going to have to check out those Sandstorms!! Obviously can't get them yet, but I realize that my plastic Axial Beadlocks will only last so long....
02-10-2018, 04:19 PM | #123 |
| Re: Ummm...
Yeah, I remember when Boom Racing first released the Krait Sandstorm/Golem/Venomous lineup - they really did a neat job with them - the price is doubly impressive since hardly anyone else includes external hub covers with their wheels... plus they include shims to help with installing various tire bead thicknesses. BTW - if anyone needs scale Hi-lifts & canisters, find a vendor that sells the TRX4 parts - only $3 for the Hi-lifts, choice of red or black, $3.50 per 2 for canisters in red/white/blue/yellow/black! Last edited by durok; 02-10-2018 at 05:08 PM. |
02-10-2018, 05:44 PM | #124 |
Rock Stacker Join Date: Feb 2018 Location: Raleigh
| Re: Ummm...
[QUOTE=durok;5799435]I'm stoked... I may need to try ordering another rear tower, this time in black - to see if I get multiple shock mounts AND body post mount screw pin holes... Boom Racing must be continually improving these. I am especially excited, because I've decided I don't particularly want to hack my cage up on the new body/cage that I'm preparing to install. With multiple shock locations front AND rear, my new shocks will be easier to set up properly for the 1.7" wheels and 4.19" tires - I'm going to be running lower all over, but am hoping to keep decent suspension travel AND crawlability! (BTW - that's my word of the day: "Crawlability") Pic from auction site of what the Boom Racing towers were "supposed" to look like (See? NO extra shock mount holes!): I wish I new about the multiple shock hole options before sending off my TSO1's back yesterday. Of course, I would need to figure out a way to attach the Bronco Body if I choose to get the gray ones. The black would not look bad either.to it some how. BTW, any luck hearing back from Shapeway's for the upper link mount? Seems like a worthy investment provided they do not break as you experienced. Last edited by BroNCo85; 02-10-2018 at 05:51 PM. |
02-10-2018, 06:51 PM | #125 |
| Re: Ummm...
I think there are better places to utilize 3D-printed parts other than for suspension mounting points... I'm not yet convinced that the "premium" material Shapeways uses is up to the task. Thus far I haven't bothered to contact them... Because I'd rather not have to just replace them again if they continue to fail. $16 is a cheap lesson. Currently, I'm using the stock floating battery tray mounts rotated 180 degrees and installed on the opposite end of the skidplate as a temporary solution, but they flex a bit when I cycle the suspension - I don't need them for their original purpose because I did away with the stock battery tray. Vaterra hop-up aluminum replacements are available & would be fine, but they are pricier (2x) than the solution I'm now choosing - so I'm waiting for ScalerFab to make these steel side plates & then ship them (for $12.95): https://www.scalerfab.com/products/s...-riser-mount-2 They make another version that are even cheaper ($9.95) for those users retaining the stock Vaterra battery tray: https://www.scalerfab.com/products/v...-cage-brackets I'm going to be painting mine black to blend in to the chassis a little better, but they allow for multiple choices in mounting the suspension links... Last edited by durok; 02-10-2018 at 06:58 PM. |
02-10-2018, 07:20 PM | #126 |
| Re: Ummm...
I'm waiting on another order to arrive from a different vendor - containing a WertyMade Ascender Flat-top bumper, a RC4WD winch anchor, and a scale pair of hard-anodized compressed air tanks from (gasp!) Integy - the only reason I got 'em is they were on closeout for less then $8 after the February discount code. Also, a cheap TFL winch from fleabay (coming all the way from Down Under!). Oh - and I almost forgot - I got a nice sheet of diamond plate (in a pattern I preferred to the standard) from Hot Racing, I'm hoping to trim it without ruining it to use in the cage area: |
02-10-2018, 07:29 PM | #127 | |
| Re: Ummm... Quote:
02-10-2018, 10:05 PM | #128 |
| Re: Ummm...
SWEET!! Scalerfab has some awesome stuff! I followed the link, and then looked around. They can hook up my Wraith too! Steel Stingers - front AND rear. And something I hadn't even thought about.... Steel Rock Sliders! It just dawned on me, that there's nothing hitting Rocks under there but soft plastic! OK, I realize that many people have wheeled Wraiths for over a Decade. It still seems that I should have some more protection under there, especially with the main Chassis to Cage mounting Screws right there! 40 bucks is somewhat steep, ESPECIALLY for me. But that's more like Insurance for my Rig! And YOURS! It's becoming less and less Vaterra by the Day!! Awesome Build, and I'm glad to be following it. |
02-12-2018, 07:14 PM | #129 |
| Re: Ummm...
So, I got a couple more parts... gettin' closer to finished! (BTW - that Integy part (only thing I ever got from them, I think?) only cost me around $8, and I can disassemble it and use it differently, thought it would be a cool scale accessory for the caged bed (the other colors are more expensive, but I think they are discontinuing all of 'em - love scoring little trinkets like this!) |
02-12-2018, 07:48 PM | #131 |
| Re: Ummm...
A side note - meine katze is always with me (in spirit) when I'm tweaking my R/C vehicles... whenever I go to move my chair back I check that I'm not going to run her over, and whenever it thunders I catch myself looking for her, too... Stormy: |
02-12-2018, 07:49 PM | #132 | |
| Re: Ummm... Quote:
02-12-2018, 09:40 PM | #133 |
| Re: Ummm... Sweet looking bumper, got a picture of it mounted up yet? Awesome another cute kitty buddy to help with RC tweaking! Yes, always got to watch where we step, roll the chair etc. |
02-12-2018, 10:51 PM | #134 |
| Re: Ummm...
OK...... I'm gonna sound like a N00b here... WHAT are those bolts, and where can I get some?? I also think it's great when Kitteh wants to help! Mine helps by knocking over hardware!!! NICE HAUL!!! Always good to score a good deal. Like the Stinger too! The Air Tanks can always find some use on our Rigs, and even represent a few different things. Last edited by PoorManRC; 02-13-2018 at 07:37 AM. |
02-13-2018, 12:14 AM | #135 | ||
| Re: Ummm... Quote:
SalerFab just notified me that my chassis plates/RULRs are cut and shipped, and RC4WD back-ordered 2 parts that I wanted, but shipped 2 others... Do you know how hard it is to find a decent scale-appearing toolbox that is NOT 3D-printed? I've decided I'll begin the conversion to new body/cage/tires/front shock tower/shocks/bumper/RULRs once the RULRs arrive. Oh, yeah - and trimming the diamond-plate... I'll need to be careful there. I can wait on the scale accessories - there's still more coming - (winch/canisters/hi-lift/light kit) - but that's it. Whew! p.s. ..... as for Stormy, she's unfortunately ONLY here in spirit. I rescued her from a muddy ditch after a weekend of torrential downpours and kept her as a purely inside cat for 9 years. Sad to say, when I had my apartment fire in 2009, it was early in the AM and I was spending the night at a lady friends place. My feline companion had passed from smoke inhalation before i got there. Haven't since been able to deal with getting another furry four-legged friend. | ||
02-13-2018, 01:34 AM | #136 |
| Re: Ummm... I feel ya Bro. People who get pets either as a Home Decor or merely a toy for the kids, have NO idea what someone goes through, when you've let a furry friend into your Heart, not just your House, and tragedy hits. |
02-13-2018, 09:12 AM | #137 |
Quarry Creeper Join Date: Jan 2016 Location: Boulder
| Re: Ummm...
Yeah, I'd really like to see some pictures of that bumper on a few different bodies. I have a Proline 4runner so I'd like to get an idea of how far out it would stick. I periodically paint bodies whenever I'm cat sitting for a buddy. Sophie the cat likes to sit in my lap while I'm trimming and prepping the body. Needless to say, those bodies always come out with a few cat hairs embedded in the paint. Fortunately, after a few rollovers it's really hard to distinguish between what are trail-scratches and what are cat hairs. |
02-13-2018, 09:23 AM | #138 |
RCC Addict Join Date: Sep 2017 Location: The OC
| Re: Ummm... |
02-13-2018, 09:58 AM | #139 | ||
| Re: Ummm... Quote:
At least you had her for 9 years and gave her a great life, it's difficult and we've had our share of sadness when they pass, but remember them for the happiness. Quote:
Nice to have Sophie keeping you company, they remind me when to take breaks too. | ||
02-13-2018, 10:37 AM | #140 |
| Re: Ummm... Hate to hear the loss of a loved one. I know all too well losing animals is a hard thing to bear. Lyla, my current cat would always get in the way of my RC parts and just plant her sassy butt down knowing full well what she was doing |
Ummm... - Similar Threads | ||||
ummm... | JasonInAugusta | Chit Chat | 15 | 07-10-2009 12:07 AM |
Ummm... | JasonInAugusta | Chit Chat | 13 | 08-10-2007 07:56 PM |
