02-14-2018, 01:35 AM | #141 | |
Quarry Creeper Join Date: Aug 2017 Location: Surface of the Sun
| Re: Ummm... Quote: I KNEW I've seen them before, I just couldn't place it. Sucks getting older! Yeah, my Katrina does that too! She's less than 5lbs, but she can make herself VERY large at times!! | |
02-16-2018, 03:36 PM | #142 | |
Rock Stacker Join Date: Feb 2018 Location: Raleigh
| Re: Ummm... Quote:
Did you receive your scalerfab link mounts yet? Got mine in today and having issues trying to figure how to put it on. I searched YouTube and couldn’t find any information on them. | |
02-17-2018, 02:43 PM | #143 |
| Re: Ummm...
Nvm, I was able to get it figured out. I ended up tearing some things to try and figure out how. Silly me. Now, onto gettting rock sliders!
02-17-2018, 04:00 PM | #144 |
| Re: Ummm...
I still haven't received mine. You're look like they are working out great! I may paint mine prior to install, since they will be fairly visible on a K10. I'll be finally performing all the updates to my Ascender when the final parts arrive. Got my TFL winch from Australia(!) and it's really nice looking, but the WertyMade bumper and the winch plate don't have matching holes... I'll need to figure something out, there. Also, I may need to decide on either lights OR winch - doesn't look like both will fit simultaneously. Lots going on outside of the RC world for me right now, may not be here as often as I'd like for the near future.
02-17-2018, 05:21 PM | #145 |
| Re: Ummm...
Speak of the devil...
03-04-2018, 07:34 PM | #146 |
| Re: Ummm...
I'm annoyed - just stripped my Wiha 2mm nutdriver after 2 of the 4 RC4WD wheels... maybe I'm tightening them too tight... LOLz Now I'm back to using the 2mm "adapter" that comes with the wheels. It's a freakin' nightmare and I've almost stripped it out, too. Nearly done, though. I'll work on installing the bumper, the Boom Racing front shock tower, the TRX-4 shocks, and the SSD brass rear axle weights next. Might be tomorrow night before I'm done and have the new wheels & tires mounted. Test drive, maybe - weather permitting... (with a 18t pinion? On 3S with the HH 550 can, oh boy...) Then paint the new cab, cut the diamond-plate for the new cage, mount all the scale accessories. I'll check if I can add the GMade round light buckets to the WertyMade bumper, last. ...and I've started listing some unneeded parts to try and recoup some of what I blew on upgrades - the end of my contract is coming up fast. Last edited by durok; 03-04-2018 at 08:28 PM. |
03-04-2018, 09:37 PM | #147 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Ummm... Quote:
Ernie | |
03-05-2018, 01:22 AM | #148 |
| Re: Ummm...
Ernie, that sounds like a good setup!! You brought up something else, that has been a thorn in my side for over 30 years!! For the Springs, you labelled them 30s and 39s.... To me, even with a long time in the Hobby, those numbers mean nothing to me. Not just that - but it seems like nearly EVERY Manufacturer has a DIFFERENT way of measuring Spring Rates!!!! For example - on my Wraith, I used 1.77 in/oz in the front and 1.21 in the rear. I recently learned that comparable Springs from Associated would be 2.95/1.45 (F/R). Duratrax would be Black/Purple. Losi, Soft/XX Soft! There was a couple of more I looked up, but can't remember... In your (or anyone's) opinion, is it already too late to institute some Standards - Especially for frequently used tuning parts, such as Springs??? I've been in Model Railroading even longer than RC (started in 1975!). Hobbywide - there has been a major governing body (NMRA) that set Standards, that the Manufacturers have just followed, since 1954!! ANY Model Train WILL couple with any other Manufacturer's Trains, and everybody's wheel spacing and flange depth, HAS to be the same, and run well on anyone's Brand of Track! There's Hundreds of other Standards, but you get the idea.... There are several things related to RC Vehicles, that seems way too proprietary, unique, or just plain WEIRD!!! Spring Rates may just be the WORST. Maybe I'm just blowing smoke...... Back to our regularly scheduled programming! |
03-05-2018, 06:39 PM | #149 | |
Quarry Creeper Join Date: Jun 2017 Location: Yavin 4
| Re: Ummm... Quote:
From what I have heard, Traxxas will be offering a "lift Kit for the TRX4 Bronco with 2.2 wheels and will have taller shocks...might have to hold out a bit and see what length they are going to have. Last edited by ScoJac; 03-05-2018 at 06:46 PM. | |
03-18-2018, 05:14 PM | #150 |
| Re: Ummm...
Out crawlin'..... will edit post upon return, much to report - not all of it great news, I'm afraid... EDIT: Pics: See anything wrong? (first pic) (hint - look closely...) The Boom Racing front shock towers are not mirror images of one another - the damn body post holes are out of line! I had installed them, was about to thread the plastic post down in and noticed the hole was drilled off-center for the grub screw that keeps them in place, THEN I noticed the whole damn thing was cast incorrectly - almost as is the part was for another vehicle entirely - but even then the mis-drilled grubscrew location is a complete FAIL. Needless to say, I'm going to notify AsiaTees/Boom Racing of this, maybe they can just send a gunmetal replacement set if they check out... not sure if ALL the black ones are defective yet... For now, DON'T ORDER part # BR682004BK for the Vaterra Ascender... (!) 2nd pic, had to bend RULR to clear 550 Holmes can - may make a cut here and refinish or perhaps even cut a similar version myself later on... Last edited by durok; 03-18-2018 at 10:22 PM. |
03-18-2018, 10:48 PM | #151 |
| Re: Ummm...
Other pics - I installed the WertyMade bumper, Gmade headlights (without wiring them up for now, no bulbs in housings), TRX-4 rear shocks (not the fronts because without installing the Boom Racing front towers I had no way to mount them lower), SSD Brass rear axle ends, RC4WD 1.7" Raceline beadlocks w/RC4WD Goodyear MT/R 1.7"x4.19" tires w/stock foams, 18t Robinson Racing pinion (to make up for tire size reduction). I redid the servo & electronics mounting AGAIN, found a very entertaining olution to extending my drag link... (used a bit of hardware from a CPU cooling fan mount... and I have a couple extra! They are hex-shaped, with M3 threads on both ends). My run was cut short by a sudden hailstorm (!!!)... but all was fine, speed and handling was fine, less rollovers with the SSD weight, LOVIN' the tires! Got a couple very short crappy videos I may post later... (had to prep my laptop for a Skype interview for tomorrow after work - I'm typing this on "SquareHead v2", aka my hardcore overclocked & overvolted handbuilt gaming desktop) |
03-19-2018, 06:27 AM | #152 |
RCC Addict Join Date: Sep 2017 Location: The OC
| Re: Ummm...
1.7 wheels huh? Makes the tires look much larger than 4.19. They would look good on my TJ copy - the original had MTR's - best tire back then - a lot of the BFG's would get sidewall slices but not the GY's. |
03-19-2018, 10:54 AM | #153 | |
| Re: Ummm... Quote:
More pics and/or video would be cool, when you have time. Very nice and would look great on your little TJ copy! | |
03-19-2018, 11:41 AM | #154 |
| Re: Ummm...
I downloaded an inclinometer app for my Pixel XL to go back to the drainage area, I climbed up the most insane angle, was that grippy concrete... Not a "real" crawling test, but I was just in the office park behind my apartment...
03-20-2018, 08:46 PM | #155 |
| Re: Ummm...
Devil's Backbone:
04-11-2018, 09:36 PM | #156 |
| Re: Ummm...
As it sits now... Dang, I need to paint up that new cab and assemble the rear cage, and load it up w/my recent scale accessory purchases... and maybe blow the dust outta this thing?
04-12-2018, 01:35 AM | #157 |
RCC Addict Join Date: Nov 2010 Location: England
| Re: Ummm...
Dust!! I haven't been out much because of the constant rain and liquid mud. Made up some inner fenders from a food storage box, but not tested them yet.
04-12-2018, 03:33 AM | #158 |
| Re: Ummm...
I'm in South Central Texas, we are just starting the dry part of the year. Sure, we get rain - unpredictability is the name of the game around here - but MOST of the time, we have long stretches of hot weather that turns our trails to what we call "moon-dust". Mountain bikers (I guess I'm one of those, too...) love rain, because usually the trails are suddenly tacky the day after, aka "hero-dirt". Blink and you'll miss it! |
04-12-2018, 05:49 AM | #159 |
RCC Addict Join Date: Sep 2015 Location: Australia
| Re: Ummm...
Hi Durok, you have taken your RTR K10 and really made it your own! it looks super cool now, those tyres look good, everybody seems to be loving them. I think it will look even better the more beat up and dirty it becomes. WASH THE DIRT OFF MY CRAWLER? AINT NOBODY GOT TIME FOR THAT! |
04-12-2018, 06:38 AM | #160 |
| Re: Ummm...
Durok I ride a mountain bike as well, but the last 3 months have been so bad I have only ridden it twice. Just stuck to road riding or some easier trails. Should be out with the Ascender(s) tomorrow.
Ummm... - Similar Threads | ||||
ummm... | JasonInAugusta | Chit Chat | 15 | 07-10-2009 12:07 AM |
Ummm... | JasonInAugusta | Chit Chat | 13 | 08-10-2007 07:56 PM |
