05-10-2018, 02:11 PM | #61 | |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
| Re: 80's Ford Ascender Quote:
Is the hot glue yo are using flexible? I use hot glue in some of my diorama work for the slot car track, but it dries hard and I imagine wouldn’t work so well attached to the flexible bodies of RC. | |
05-10-2018, 02:14 PM | #62 | |
I wanna be Dave Join Date: Apr 2012 Location: Merrill, WI
Sent from my ZTE A2017U using Tapatalk | |
05-10-2018, 10:58 PM | #63 |
Looking forward to getting back behind the wheel of this rig! |
05-14-2018, 10:45 PM | #64 |
The RCAddicts fenders I have mounted on the Ascender wereactually made to fit the K5 body. Figuring this JConepts body was comparable in width I decided to give them a go. They fit great in width, but turned out to be a bit tall for the F150 body. Thought of cutting them, but decided to use a heat gun and just reshape them instead. The fenders also ended up interfering with my grill once I got it mounted in so I reshaped the fender some more. Now they look like ocean waves I am pleased with how it worked out though because I am not a fan of seeing electronics when I look in the wheel wells...and I have fender liners! Let there be light(s)! |
05-14-2018, 10:54 PM | #65 |
...and I decided to remove the stock sliders. They looked like crap sitting so far below the body. May remount some later and tuck them up to the cab as they should be |
05-15-2018, 05:15 AM | #66 |
It looks amazing! You definitely have some skills! What did you use for the rust? I have thought about trying a rusty rig. Sent from my ZTE A2017U using Tapatalk |
05-15-2018, 06:15 AM | #67 |
| Re: 80's Ford Ascender Thanks mg. I am pretty happy with how things have turned out so far. I use a product made by Sophisticated Finishes. It is a 2-part solution for creating rust effects. There is an iron solution and a rust developer.
05-15-2018, 09:42 AM | #68 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
Your truck is really starting to take shape, very nice build! I use the same product for my aging job. Ernie |
05-15-2018, 09:48 AM | #69 | |
05-15-2018, 09:51 AM | #70 | |
The SF is a nice product that seems to get more effective as one gets more practice with it. I have been really enjoying learning the art of ‘weathering ‘ lexan and styrene. May have to give some wheels a go. | |
05-15-2018, 09:54 AM | #71 | |
05-15-2018, 10:14 AM | #72 |
Excellent work painting that driver! |
05-15-2018, 10:17 AM | #73 |
| Re: 80's Ford Ascender That looks hot! Reminds me of old mud trucks running around back in high school, wheels n tires go together with it. Make some sliders, Codyboy, or Wertymade? Can use a lighter or heat gun and bend the stock sliders up temporarily like I did on my K10 before I got some from Ernie. |
05-15-2018, 10:37 AM | #74 | ||
Thanks Jato! Quote:
I was going crazy with the heat gun yesterday, but never though to bend the stock sliders. Food for thought... | ||
05-15-2018, 11:03 AM | #75 | |
Yes, nailed it! Here's what I did, really helps to have another person so that both pieces are heated at same time and then bent and held to cool. Starts at post #743. Natedog's Vaterra ASCENDER ~~~~~~~~~~~~~~~~~ In camp K10 slider mod with a couple lighters, because the bottom of this cab and bed are at least 1/2" higher than the Blazer. | |
05-15-2018, 12:51 PM | #76 | |
05-15-2018, 03:36 PM | #77 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
ohhhh man... i need to get with it! i need LIGHTS! yours is coming along awesome. keep it up! |
05-30-2018, 08:35 AM | #78 |
Took the Ascender into the back yard the other night to test the headlights out. They seem to cast a decent spread, but man is it ever hard to hit technical lines in the dark With the light out front of the rig I couldn't see my tires well enough to pick my lines accurately. Here is a short video of the test run my son and I quickly put together. Complete with intro... Last edited by smog; 05-30-2018 at 08:52 AM. |
05-30-2018, 08:58 AM | #79 | |
Your truck is looking good Bud, sounds like you need a headlamp. It would help you see the lines better. Ernie | |
05-30-2018, 09:29 AM | #80 | |
Sound advice. I have been saying to myself I need a good quality headlamp for awhile. This gives me another bump. I also need better foams for those tires. They are way too firm. | |
80's Ford Ascender - Similar Threads | ||||
Ford Atlas Ascender | 2mtech | Vaterra Ascender | 11 | 12-04-2016 06:48 AM |
80's Style FORD Crew Cab Step Side ***Pic Heavy*** | v84x4 | 1.9 Scale Rigs | 60 | 01-25-2015 09:46 PM |
80's to 90's Toyota 4x4 vs 80's to 90's Jeep Cherokee 4x4 - which one to buy????????? | entropy | Chit Chat | 12 | 06-24-2011 01:14 AM |
