05-30-2018, 09:37 AM | #81 | |
I wanna be Dave Join Date: Apr 2012 Location: Merrill, WI
| Re: 80's Ford Ascender Quote:
Sent from my ZTE A2017U using Tapatalk | |
05-30-2018, 09:54 AM | #82 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
| Re: 80's Ford Ascender What foams did you end up going with? I am going to pop into the LHS later and see what they have.
05-30-2018, 09:58 AM | #83 | |
05-30-2018, 02:40 PM | #84 | |
Headlamp is a must, sometimes can't see where your stepping even with rock lights. | |
05-30-2018, 03:08 PM | #85 |
| Re: 80's Ford Ascender I was at the hobby store earlier. They don't carry CI foams, but I was looking at some proline dual stage. I asked about them but was advised that they wouldn't soften up the tire. Ever try your Boggers without the foams? I am thinking I either need to trim them or remove them altogether
05-30-2018, 03:15 PM | #86 |
There's a rib that goes down the center on the inside. If you shave it off it helps to soften the tire a little bit. Dual stage is good because they don't over flex. Though on a bogger the soft single stage foam would probably be OK. Boggers are not awesome on the rocks. They are good multipurpose tires but if you don't have to have the bogger look you would be better off getting a different tire. I tried a set with out foams but they would leak down and I would have to remount them to get rid of the flat spot. Sent from my ZTE A2017U using Tapatalk |
05-30-2018, 03:43 PM | #87 | |
I am not on rock exclusively. My rigs see a mix of rock, dirt and wood. What I would really like is to see the tire flex more so that I get increased surface contact when I am crawling. Right now the Boggers are just too stiff. I am going to try trimming up the foams as you suggested and see if I can get some more flex out of them. I like that the Boggers match the era of the body, but at the end of the day the performance needs to be there. | |
05-30-2018, 05:01 PM | #88 | |||
05-30-2018, 05:07 PM | #89 |
| Re: 80's Ford Ascender |
05-31-2018, 06:07 PM | #90 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
Hey brother I just saw Ampro has the full 80s ford interior vid up on YouTube! Might fit? https://youtu.be/BUhLFZ0VIy4 78/79 bronco interior should be hitting right behind it! |
05-31-2018, 09:52 PM | #91 | |
06-12-2018, 02:24 PM | #92 |
The Novak Hammer ESC wasn't doing it for me. The drag brake on it is just too weak for any proper crawling. The rig was getting away from me on the weekend. So I figured it was time to run the HobbyWing 1080 that I picked up a few months back. It's been getting lots of props on the site lately so I need to see what the fuss is all about anyway. So back the the brushed system. Soldered up some bullet connectors and and a Dean's for the batt. Threw in a cheap 35T motor for now. It's an RC4WD. I don't compete so it serves my purpose....no edge needed. The settings seem decent out of the box. Will have to do some button pressing later to make sure the lipo cutoff is set. No puffing on these fiery batts allowed |
06-12-2018, 02:53 PM | #93 |
I haven't tried that one yet. I have been running the 1060 with out any complaints. I'm sure it's probably better but I have been using the same one forever in many different trucks. And for $20 if it fries oh well. Sent from my ZTE A2017U using Tapatalk |
06-12-2018, 03:09 PM | #94 | |
Is the 1060 ‘waterproof’? | |
06-12-2018, 03:14 PM | #95 | |
Sent from my ZTE A2017U using Tapatalk Last edited by mgputer; 06-12-2018 at 03:19 PM. | |
06-12-2018, 03:21 PM | #96 |
06-13-2018, 02:42 PM | #97 |
sounds like he drives the same way i do... ;) i was going to run a couple of 1060's in the drifters my son and i have on the back burner. two of these and two more radiolink rx could get them running for under $80. hmmm... |
06-13-2018, 03:06 PM | #98 |
| Re: 80's Ford Ascender its tempting right?! This HW runs nicely. At this point its hard for me to justify splashing out on another Tekin, as sweet as they are.
09-11-2018, 03:59 PM | #99 |
Well gotta say I am kinda happy that fall has hit. The frenetic pace of summer is fun, but it feels like an endless sprint sometimes with two pre-teen boys to entertain. Didn't get out with the crawlers nearly as much as I would have liked. My one son who I did get out a little more frequently much preferred abusing the moderately paced Bomber and the Wraith. Regardless, fun was had and some crappy tactic servos were shredded The Hobby Wing ESC has been golden in this Ascender. I couldn't ask more of it at this point. Its buttery smooth and brakes without fail on the steeps. I wasn't so thrilled with the stiffness of the Boggers however, so the other day I swapped them out for a set of Pit Bull's Mad Beasts. Oh man! I gotta say, I love these tires! Its too bad the foams they come with are so soft )-: My rig is not that heavy, but it was squishing the front tires right down flat. ultimately I lost the bead on one of my tires. I think I need a dual stage foam for these tires. Any recommendations are appreciated. I mounted the Mad Beasts up on a set of them sexy Hot Racing D-Hole Steelies The wheels have a less aggressive offset than the RC4WD steelies I was running which thankfully helped eliminate the annoying tire rubbing on the fender. the tire tucks beautifully now when stuffed in the well. They also look to have a relatively period correct aesthetic. A few pics of some backyard play ...and the cats that I now collectively refer to as the Ascenders. Here they are Assembling... Last edited by smog; 09-11-2018 at 04:08 PM. |
09-11-2018, 05:04 PM | #100 |
Truck looks great! The aging you did on there is great. Looks great outside. Sent from my ZTE A2017U using Tapatalk |
80's Ford Ascender - Similar Threads | ||||
Ford Atlas Ascender | 2mtech | Vaterra Ascender | 11 | 12-04-2016 06:48 AM |
80's Style FORD Crew Cab Step Side ***Pic Heavy*** | v84x4 | 1.9 Scale Rigs | 60 | 01-25-2015 09:46 PM |
80's to 90's Toyota 4x4 vs 80's to 90's Jeep Cherokee 4x4 - which one to buy????????? | entropy | Chit Chat | 12 | 06-24-2011 01:14 AM |
