02-18-2018, 07:49 AM | #1 |
Pebble Pounder Join Date: Nov 2010 Location: Alabaster
| Vaterra Ascender Battery Tray
This is my first Ascender and was wondering if any way to relocate battery or if a aftermarket battery tray exists.
02-18-2018, 07:56 AM | #2 |
Rock Crawler Join Date: Dec 2016 Location: Minnesota
| Re: Vaterra Ascender Battery Tray
There are a few ways: First and easiest is to remove the connecting point at the axle and mount the tray between the shock towers. You can lay a full-size (~5000 mah) battery across the back side of the shock towers but this would likely mean completely removing the stock tray and finding something to use as a bracket/plate for the battery to rest and mount to. Lastly, BPCustoms makes a relocation tray. This is the route I'm going with one of my K5's. I have it in my basement, just haven't gotten around to installing it. Both of mine currently still run the stock trays so I can't really help with pics. Sent from my SM-G930V using Tapatalk |
02-18-2018, 07:57 AM | #3 |
Here is the link to the BPCustoms tray: http://bpcustomchassis.com/webstore....egory=11952176 Sent from my SM-G930V using Tapatalk |
02-18-2018, 08:07 AM | #4 |
So does this kit also relocate the servo as well. Mine mounts side to side in frame rail. its the k10 version
02-18-2018, 08:24 AM | #5 |
On their website it says it can by used on the shortest WB but you would likely have to turn your servo. Since you bought the K10, I don't know that you got the pieces to rotate the servo. I've only bought the kit version so I'm not sure what spare parts are included in RTR's. That said, Horizon sells the parts and if you talk to the right guys on here, someone might have the parts laying around. Sent from my SM-G930V using Tapatalk |
02-18-2018, 09:49 AM | #6 | |
Quarry Creeper Join Date: Jun 2017 Location: Yavin 4
| Re: Vaterra Ascender Battery Tray Quote:
As mentioned above there are a couple companies that offer battery relocation. JC Autodesign BP Custom Chasiss (Ascender) BP Custom Chassis (Universal) Last edited by ScoJac; 02-18-2018 at 09:49 AM. Reason: spelling | |
02-18-2018, 11:41 AM | #7 |
Where can i find the wheel base chart at. This is my first ascender so i have no clue. Sent from my SM-G955U using Tapatalk |
02-18-2018, 11:46 AM | #8 |
So the k10 is a 290mm wheelbase from what vaterras website shows. So factory it runs the wheelbase number 2 Sent from my SM-G955U using Tapatalk |
02-18-2018, 11:48 AM | #9 |
Quick reference of links and frame positions HERE. And here is the Instruction Manual for the Blazer Kit which cover building all 4 wheelbases. |
02-18-2018, 11:52 AM | #10 |
| Re: Vaterra Ascender Battery Tray |
02-18-2018, 11:53 AM | #11 |
02-18-2018, 12:34 PM | #12 |
RCC Addict Join Date: Sep 2015 Location: Australia
I believe the only reason they use the sideways servo mount on the 2 shorter wheelbases is to clear the floating battery tray. If your not using that tray it won't matter how u mount the servo, if your modifying a Bronco, K10 or F100 you will also need to replace the steering link from servo to the hub with the longer link from the Blazer. |
02-18-2018, 04:21 PM | #13 |
Since you are running the K10, if you'd like you can sneak a peek at my Ascender modding thread where I installed the BPC Universal battery tray... I now have room to run the bigger motor can - I have a Holmes Hobbies 550 can in mine, really wakes it up! Ummm... Here's the specific thread for the battery tray: BPC Battery Relocation Tray - Ascender K10 - Stock WB(2) |
02-18-2018, 04:48 PM | #14 |
Here is what i did. Sent from my SM-G955U using Tapatalk |
02-18-2018, 06:27 PM | #15 | ||
| Re: Vaterra Ascender Battery Tray Welcome to RCC and congrats on your new Ascender! WB4 is to get the long 12.3" or so wheelbase used by many manufacturers and bodies available on the market, it also climbs very well and is maximum length per some crawling rules. Quote:
That works too, but if you mount it crossway on the chassis you'll get the weight down much lower and will crawl lots better. Also can use smaller battery and then get your existing mount down lower too. | ||
02-19-2018, 06:29 AM | #16 | |
Each of my built Ascenders are WB4 with Blazer shells and have the servo in different positions. Original is in the standard front-back and the 2nd is sideways for clearance purposes. No performance difference that I've been able to notice. Sent from my SM-G930V using Tapatalk | |
02-19-2018, 07:27 PM | #17 |
Okay have another question for you guys. Noticed today the approach angle for the front bumper was horrible. I see plenty of bumpers are made but wanted to ask which one yall have tried out for best results and for the rear. |
02-25-2018, 07:59 AM | #18 |
Rock Stacker Join Date: Jun 2017 Location: US
If you mount a full size battery perpendicular to the frame like with the BPC tray, won’t it cause interference with the tires when steering?
02-25-2018, 08:08 AM | #19 | |
Vaterra Ascender Battery Tray - Similar Threads | ||||
BPC Battery Relocation Tray - Ascender K10 - Stock WB(2) | durok | Vaterra Ascender | 7 | 10-31-2019 10:06 AM |
3D Printed Ascender K10 Battery Tray | robertjpjr | Vaterra Ascender | 0 | 01-26-2018 07:23 PM |
Ascender battery tray options. | Lmackattack | Vaterra Ascender | 7 | 02-05-2015 06:14 PM |
