03-04-2018, 10:42 AM | #1 |
Newbie Join Date: Dec 2017 Location: Lower 48
| ESC Jumper settings
I just got a new F100. On the ESC there are two sets of jumpers - one is for battery type, the other has a choice of CRAWL or F/Br. What is the F/Br? Thanks.
03-04-2018, 10:49 AM | #2 |
Newbie Join Date: Feb 2015 Location: unknown parts
| Re: ESC Jumper settings
I'm guessing here but, forward and brake? Just a hunch though. Don't have one so can't say for sure. Sent from my SM-G935W8 using Tapatalk |
03-04-2018, 11:57 AM | #3 |
Yes, that's exactly what the jumper changes - leave it in the crawler setting for best results! Or, better yet - spend about $42 on a programmable HobbyWing 1080 ESC... |
03-06-2018, 07:52 AM | #4 |
Rock Stacker Join Date: Jun 2017 Location: US
Is the stock esc a rebranded HW 1060?
03-06-2018, 02:43 PM | #5 |
RCC Addict Join Date: Sep 2015 Location: Australia
| Re: ESC Jumper settings |
03-06-2018, 04:59 PM | #6 |
| Re: ESC Jumper settings Seems very similar in looks and function, both mine work very well but the WP 1080 is way better. Agreed, but what programming do you mean? |
03-06-2018, 06:19 PM | #7 |
I’m thinking all the esc settings Natedog, that’s what I mean by programming. As far as I know there is no way to adjust the stock esc drag brake etc. |
03-06-2018, 06:32 PM | #8 |
Nice. I was thinking of getting the Blazer RTR and pulling the esc out for my CCO1. Then buying a HW 1080 for the Ascender.
03-13-2018, 09:07 AM | #9 | |
Quarry Creeper Join Date: Dec 2016 Location: Toronto
| Re: ESC Jumper settings Quote:
I am curious as to how you are able to "get in and change everything" ie: make changes to the Hobbywing 1060 esc, please elaborate? | |
03-13-2018, 12:04 PM | #10 |
Well I am assuming it is like all other hobbywing esc, you can change from lipo to NiMH, forward/brake, forward/reverse, low voltage cut off, drag brake %, punch, reverse max throttle blah blah. You can do it via the built in set button on the esc or via a programme card.
03-13-2018, 12:17 PM | #11 | |
I have yet to own or see a 1060 with a set button or that was compatible with the hobbywing Programming Card I use for my 1080. I would love to be able to make a few adjustments on my 1060 - and based on your statements I thought you might know something that myself or others do not about some sort of hack to make adjustments. | |
03-13-2018, 12:27 PM | #12 |
My bad! I have a 10bl60 sensored esc that has the set button.... So in that case the rtr esc must be just a rebadged HW 1060! |
03-13-2018, 04:52 PM | #13 | |
I can pick up a 1060 for as little as $22 CDN, where as a 1080 is around $50 CDN. I need at least 2 more crawler (dragbrake) escs at the moment and would go with more 1060s if they had a bit more adjustability - but will probably end up with a 1080 and whatever I can get cheapest to operate a scale winch. | |
ESC Jumper settings - Similar Threads | ||||
Need Tekin FX-R esc settings | Rsmith0399 | Electronics | 0 | 08-03-2015 08:14 PM |
Stock ESC settings | tcm glx | Axial Wraith | 5 | 02-09-2013 08:18 PM |
esc settings | conrodss | Electronics | 1 | 05-21-2010 06:29 PM |
What settings to use on the enroute ESC programmer ? | NullMind | Electronics | 7 | 07-10-2008 08:25 AM |
