Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Ascender
Thread: Ascender Builds
Old 03-10-2018, 07:12 AM   #1
Default Ascender Builds
Just about done with my Aschammer. So while waiting for some parts I started on my Ascender. Not sure exactly the route I'm going yet but first I'm going to start some performance upgrades.
Sent from my ZTE A2017U using Tapatalk
mgputer is offline   Reply With Quote
Old 03-10-2018, 08:05 AM   #2
Default Re: Ascender Build
Whats an aschammer? I could wager a guess, but this is a family forum....
Alexander_0_1 is offline   Reply With Quote
Old 03-10-2018, 08:46 AM   #3
Got the interior installed and removed the window tint
An Aschammer is a Ascender chassis with twin hammer drive train. I built one before the Ascender was released with a scx10 chassis a few years ago. I have a build thread for it in the Twin Hammers section.
Old 03-10-2018, 08:52 AM   #4
Another pic
Old 03-10-2018, 09:52 AM   #5
Removed the spare tire mount
Old 03-10-2018, 07:12 PM   #6
So I changed my shock mount location on the axle but now the shocks bind. I guess I will have to get a better quality shock before I make this MOD.
Old 03-10-2018, 07:16 PM   #7
Natedog's Avatar
Shocks shouldn’t bind mounted like that, only outboard the rear, front limits flex too much. The floating spring separater sometimes rubs on shock threads, sand the inside of it smooth and bevel the edges will fix this.
Old 03-10-2018, 08:18 PM   #8
Yes that's why I changed it. The bind is inside the shock.
Made a kangaroo killer. Looks kinda neat.
Old 03-11-2018, 10:02 AM   #9
Changed my links. I lengthened the wb by about 1/4. Trying to get like 11.75. Just a hair short. Going to use different link ends and I think that will be just right.
Old 03-11-2018, 11:04 AM   #10
I really don't care for 3 link panhard setup. Besides a little bump stear which you get with this panhard setup anyway I may try 4 link and get rid of the pan hard just to see how it works. If it's awful I will just have to change the linkage so they are closer to the same length. I had a 4 link with CMS on an axial and it worked just fine. Honestly better as the pan hard pushes the suspension to the side slightly which causes binding when you lift the side the pan hard is connected to.
I also have a twin hammers sway bar set with 3 different weights of bar. Going to see if I can make it work.
Old 03-11-2018, 11:50 AM   #11
Whats moving around, the axle? I thought that was to be expected from a 3 link w/a track bar (panhard bar?)
When your suspension binds, how far are your shocks pushed left, or right while it’s bound up. When I put 5” shocks on ascender #1, I noticed I had to lengthen my pan hard bar, but I over did it, and started to notice a binding on the right side. After messing around a bit, I removed some of the spacers in my panhard bar, and now it doesn’t seem to bind up, or not as badly. My shocks almost completely compress without binding, almost, with in the last cm it looks like it’s binding.
I was just looking at your rear shocks, and the outboard set up, and I got to wondering if the shocks would still bind up if you switched to Traxxas hollow balls, they’d give the bottom eye of your shocks more range of movement since they have wider flanges on either side, unlike the ascender hollow balls.
Old 03-11-2018, 12:31 PM   #12
I was thinking about trying different balls also. I got to playing around with it and I think that's the issue. I modified the front by adding a spacer behind the shock on the top and that helped in the front. Due to the panhard it pushes the front over more than the other so the one side is OK but the other side causes the shock to bind really bad about half way through. Seems better. Not fixed but an improvement
Old 03-11-2018, 12:44 PM   #13
Um, try unbolting the track bar/panhard bar on one side, then centre the front axle under you ascender, then compress the suspension to about ride height on a level surface, check again for a centred axle, then take a measurement of the track bar/panhard bar, you might still need to adjust it...slightly.
My set up, I used savage x hollow balls with no flanges and that narrow nut that comes with the proline powerstroke hardware kit, then the link end, all still inside the link mount/bracket.
Old 03-11-2018, 03:15 PM   #14
My buddy came in to help me figure it out.
Old 03-11-2018, 04:43 PM   #15
My helpers decided that the stock servo isn't good enough so we replaced it.
Old 03-11-2018, 06:09 PM   #16
I tried it 4 link but the bump stear is intolerable. While I had it apart I noticed that the panhard is short. Lengthened it a little and that helped tremendously. I think reworking the stearing will help also.
Old 03-13-2018, 08:45 PM   #17
I put spacers between the shock and the shock tower and it made a big difference in the front suspension. I can bottom the front shocks now with out binding.
Old 03-15-2018, 09:02 PM   #18
Did a little painting.
Old 03-15-2018, 09:43 PM   #19
New driver
Old 03-16-2018, 06:35 PM   #20
Trimmed out the window. Looks good and gives me a place to blow out the interior with the air compressor to keep it clean.
Ascender Builds - Similar Threads
New build ascender jmarsh1976 Vaterra Ascender 32 01-05-2016 01:14 PM
Ascender build Markeje Vaterra Ascender 13 09-24-2015 09:08 AM
Ascender Build seth556 Vaterra Ascender 12 01-05-2015 03:13 AM
My Ascender Build wax Vaterra Ascender 1 10-22-2014 05:38 PM
