02-07-2019, 06:25 PM | #761 |
I wanna be Dave Join Date: Apr 2012 Location: Merrill, WI
| Re: Ascender Builds
Made a little progress on the interior. It's starting to look like a scout. Sent from my Vivo XI+ using Tapatalk |
02-08-2019, 02:12 PM | #762 |
| Re: Ascender Builds
I just wasn't liking the wheel wells so I made some new ones. Sent from my Vivo XI+ using Tapatalk |
02-09-2019, 03:28 PM | #763 |
| Re: Ascender Builds
Got everything glued in except for the seats. I put a little paint on to see what I need to touch up. The black is very difficult to see. Sent from my Vivo XI+ using Tapatalk |
02-09-2019, 05:34 PM | #764 |
| Re: Ascender Builds
Sprayed the interior again. Noticed after it dried it was the wrong color. That looks better. Now I get to sand it down. Sent from my Vivo XI+ using Tapatalk |
02-10-2019, 11:49 AM | #765 |
| Re: Ascender Builds
I was looking at scouts and noticed most ran the bolt on black rubber strip on the box rails when the top was off. I'm going to try to mimick that look. Also planning on making a magnetic rear topper so I can run it with or without the top. Sent from my Vivo XI+ using Tapatalk |
02-10-2019, 04:08 PM | #766 |
| Re: Ascender Builds
Next up roll cage. I'm going to try to keep it as light as possible. Already getting heavy. I think I'm going to have to load up the axles with a little brass. Sent from my Vivo XI+ using Tapatalk Last edited by mgputer; 02-10-2019 at 06:42 PM. |
02-10-2019, 08:09 PM | #767 |
| Re: Ascender Builds
So I had a spare body piece. Trimmed it up and it gives me an idea. Not sure if I will but it's a possibility. Sent from my Vivo XI+ using Tapatalk |
02-11-2019, 08:27 AM | #768 |
| Re: Ascender Builds
Trimmed it up so it fits pretty good. I think I'm going to go with the roof. I'm going to leave the back open with the roll cage coming through the back. Sent from my Vivo XI+ using Tapatalk |
02-11-2019, 01:13 PM | #769 |
| Re: Ascender Builds
Started on the roll cage. Not sure what I am going to do for sure yet but this is my rear cross idea. Sent from my Vivo XI+ using Tapatalk |
02-11-2019, 01:19 PM | #770 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
| Re: Ascender Builds
Nice progress. What are you using for tubing?
02-11-2019, 01:21 PM | #771 |
| Re: Ascender Builds |
02-11-2019, 01:50 PM | #772 |
| Re: Ascender Builds
Getting there. 2 tubes done, 4 or 5 more to go. Sent from my Vivo XI+ using Tapatalk |
02-11-2019, 03:08 PM | #773 |
| Re: Ascender Builds
Not sure if I will but it would look pretty good with a spare tire. Sent from my Vivo XI+ using Tapatalk |
02-11-2019, 03:18 PM | #774 |
| Re: Ascender Builds
That is what I envisioned with the way you have angled the bars. I see a cross member that can act as a stabilizer and a spare mount. Looks great! |
02-11-2019, 04:33 PM | #775 |
RCC Addict Join Date: Sep 2015 Location: Australia
| Re: Ascender Builds
I tell you what, I really like the body just as it is, with the sanded back area's. I like it with the full roof too, just sand back the filler on the tailgate and call it done!!!
02-11-2019, 04:36 PM | #776 | |
| Re: Ascender Builds Quote:
Sent from my Vivo XI+ using Tapatalk | |
02-11-2019, 05:01 PM | #777 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
| Re: Ascender Builds
Yeah I like the work in progress look! "It runs, dont need to look Purdy" ;) 50 light dusting coats of matte clear. Go! |
02-12-2019, 07:14 AM | #778 |
| Re: Ascender Builds
i also have a bunch of scale parts and finish all of the parts under the hood like the master cylinder, heater box, etc. i also have a scale wire harness and plug wires i have been trying to print Sent from my TX92 using Tapatalk |
03-03-2019, 04:48 PM | #779 |
| Re: Ascender Builds
Well I missed the bronco so I dug it out and reworked the links to the vaterra links. I changed out the skid to a vaterra skid. Put in a 550 17t and it works great with the 14t pinion. Finally put in the beef tubes I've had laying around. With the SSD kuckles and the beef tubes she's a tank. I outboarded the shocks also. I did the front and rear. I'm also making a set of secondary spring adjuster. I took it out and was really impressed. I took a few good tumbles and lost my driver and cooler. I attached them with hot glue. When it's-5 like today, it doesn't flex so the parts rip off. Going to find a better way to attach the accessories. Sent from my Vivo XI+ using Tapatalk |
03-04-2019, 06:44 PM | #780 |
| Re: Ascender Builds
Painted the half door's with bedliner. Looks pretty good. These vaterra links made a big difference in handling. I had the axial kit ones on there and the plastic balls are aweful. Sent from my Vivo XI+ using Tapatalk |
Ascender Builds - Similar Threads | ||||
New build ascender | jmarsh1976 | Vaterra Ascender | 32 | 01-05-2016 01:14 PM |
Ascender build | Markeje | Vaterra Ascender | 13 | 09-24-2015 09:08 AM |
Ascender Build | seth556 | Vaterra Ascender | 12 | 01-05-2015 03:13 AM |
My Ascender Build | wax | Vaterra Ascender | 1 | 10-22-2014 05:38 PM |
