12-31-2018, 06:27 PM | #221 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Codyboy's 79 Ford (Rent to Own) Ascender
It has been a while so thought I would post up some pics of druz's Ascender axles. I thought I would start building these again. Front axle weight. Total added weight. A set of these axles on my jeep build. Thanks for looking. Ernie Last edited by CODYBOY; 12-31-2018 at 06:43 PM. |
12-31-2018, 07:53 PM | #222 |
RCC Addict Join Date: Sep 2015 Location: Southern Maine
Those last ones pictures a wider width? That why the custom ground axle shafts at the differential side? If anyone is on the fence with this design, they’re great. Stout, and well made. Ernie is a great guy to deal with and talk to Ben |
12-31-2018, 08:25 PM | #223 | |
| Re: Codyboy's 79 Ford (Rent to Own) Ascender Quote:
Hey Ben, trust you guys had a great Christmas!!!! The axles are all the same width, if you look at the chubs relationship to the link mounts they are all within a MM or so, no more. The axle shafts are axial shafts that I turned down the tangs and brazed a SS sleeve to it and then filed it to fit the ascender diff. Hope that answers your question? Ernie | |
12-31-2018, 08:41 PM | #224 |
That’s right, forgot about the axial axle shafts. Been a while I guess. Christmas was very good thank you! Keep up the good work man! Ben |
12-31-2018, 08:55 PM | #225 |
Rock Stacker Join Date: Jan 2018 Location: East Snob
| Re: Codyboy's 79 Ford (Rent to Own) Ascender <----- trying to find the happy fat kid dancing gif..... |
01-01-2019, 09:56 AM | #226 |
| Re: Codyboy's 79 Ford (Rent to Own) Ascender I don't know if I mentioned, but the upper link mount holes are drilled out and tapped all the way into the brass. This feature really firms up the mount. And the 3mm screws heads are turned down so they seat into the link mount holes! I also clocked the chubs 2 degrees past stock for even better steering. Hope they fit your needs, and thanks for checking us out! Ernie |
01-01-2019, 10:12 AM | #227 | |
RCC Addict Join Date: Sep 2017 Location: The OC
| Re: Codyboy's 79 Ford (Rent to Own) Ascender Quote: Lead time? Comes with the weights? Or source them separately? EDIT: Also, you probly said so already, but why Axial axles? And do you happen to know if the stock Vaterra front axle is of a different metal compound than the claimed 4160 chromoly from Vanquish? I just replaced mine in my 'codybody alxe' with the VP ones. Last edited by Browneye; 01-01-2019 at 10:49 AM. | |
01-01-2019, 01:36 PM | #228 | |
Hey Chris, the chubs and knuckles are AR44 axle parts made by SSD. I started offering this option way back when the ascender first came out and they were having trouble with weak axles and availability. I started making them with SCX10 chubs and knuckles and when the AR44s came out I switched to them. The Axial shaft, chubs, and knuckles allow the ascender axles to achieve almost 65 degrees of steering. I include the knuckle weights. I don't know about the hardness of the axles sorry. If your looking for bullet proof axles I have built some with modified super axles from Erik at DLUX Fab. I'll find the link. Also look at the front axles I put in the truck in this build thread. Quality cost $$$ though. Link to the axle shafts https://dluxfab.ecwid.com/#!/FBA-Axl...tegory=6232189 Ernie Last edited by CODYBOY; 01-01-2019 at 01:42 PM. | |
01-02-2019, 10:05 AM | #229 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
NICE! a GCM SKELETON jerp with CODYBOY AXLES! its like the best of the best!!! super scale meets super capable... man i would LOVE to see that jeep in action. incredible work as always, Ernie! Merry Christmas and Happy new year from the Shinchu Family to you and Marcia. see you soon! |
01-02-2019, 10:41 AM | #230 | |
Ah, those are interesting. 70* of turn? Wow! At a hundred bucks a pair I can only imagine what a finished axle costs. BTW, how do these compare to what Vanquish is putting in their rig? | |
01-03-2019, 09:35 AM | #231 | ||
I will let you know how the VP axles compare, I'm pretty sure I can get that much out of them with a little work. I will post up when I start my VS4-10 build. I plan on doing a few things to make it a little different than the rest. Ernie | ||
01-03-2019, 09:50 AM | #232 |
*COUGH* PORTALS* COUGH COUGH REAR PANHARD COUGH sorry I've been a little under the weather ;) looking forward to that build! i might have a surprise up my sleeve for proline as well... just need the right thing to pop up in the classifieds ;) |
01-03-2019, 02:27 PM | #233 | |
What are you looking for Chris, I might have it? You can PM me if you want to keep what's under sleeves there for a while. Ernie | |
01-04-2019, 09:53 AM | #234 |
thanks Ernie but i doubt you have one of these... I've been watching the classifieds like a hawk and the closest thing i saw was a CMAX i missed by 3 hours. if it gets too close to deadline i might just buy some frame rails/axles and go full custom |
01-04-2019, 05:18 PM | #235 | |
Ok, give me a shout if you need a little help with anything. Ernie | |
01-04-2019, 06:11 PM | #236 |
I wanna be Dave Join Date: Apr 2012 Location: Merrill, WI
I could have what you need. What are you looking for? I'm guessing cmax with the coil spring front? I don't have that lol Sent from my Vivo XI+ using Tapatalk |
Codyboy's 79 Ford (Rent to Own) Ascender - Similar Threads | ||||
80's Ford Ascender | smog | Vaterra Ascender | 205 | 12-23-2019 04:28 PM |
Codyboy's "bulldog bronco" ascender | CODYBOY | Vaterra Ascender | 280 | 06-04-2018 10:09 AM |
Ford Atlas Ascender | 2mtech | Vaterra Ascender | 11 | 12-04-2016 06:48 AM |
