05-05-2018, 09:33 AM | #61 | ||
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Codyboy's 79 Ford (Rent to Own) Ascender Quote:
Ernie | ||
05-05-2018, 08:13 PM | #62 |
Hot damn Ernie, that’s great, always glad to test! Ben, as Ernie said regarding skid plates and drive shaft angles. How’s about using stock skid, get transfer case where it needs to be and cut away excess skid plate below frame rails, fill in with delrin flat plate? |
05-06-2018, 09:21 AM | #63 |
I started testing yesterday with positive results! We will see how Nate's testing goes next week before we get to excited! Ernie |
05-06-2018, 12:47 PM | #64 |
Your testing looked great, I’m excited to test too, K10 is waiting! |
05-07-2018, 09:17 AM | #65 |
| Re: Codyboy's 79 Ford (Rent to Own) Ascender |
05-07-2018, 10:51 AM | #66 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
speaking of late nights... this rig have anything for night crawls? that's next for mine! |
05-07-2018, 11:07 AM | #67 |
05-07-2018, 11:23 AM | #68 |
It's here, that was fast! Last edited by Natedog; 05-07-2018 at 11:31 AM. |
05-07-2018, 02:05 PM | #69 |
05-07-2018, 05:25 PM | #70 | |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
Getting excited and going to Nate's tonight | |
05-08-2018, 10:31 AM | #71 |
sounds like a plan!!!
05-11-2018, 12:44 PM | #72 |
Big thanks to Ernie and Erik DLux for ideas and no fear in cutting stuff up and trying outside the box ideas! Thanks to Ernie for generously building and sending me a set of axles with rear panhard setup! In garage and driveway testing this seems to help reduce torque twist, I'll be doing more real world crawl testing. I've done several days of mocking up with different mounts, link lengths/placement, etc. This coupled with Rich's Shock Collar Mod, rear upper link mount changed, etc are all pieces that help improve the Ascender, I'll be running this at Proline By the Fire! BTW, yes I know theres' no screw in the axle link mount in the picture. Edit: Everything clears even with my lowered fuel cell/rx box. Last edited by Natedog; 05-11-2018 at 12:47 PM. |
05-11-2018, 04:54 PM | #73 | |
I wanna be Dave Join Date: Apr 2012 Location: Merrill, WI
Sent from my ZTE A2017U using Tapatalk | |
05-11-2018, 07:21 PM | #74 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
You have created some really cool parts Ernie. It's fun to see them on people's rigs. Thanks for sharing your work man! You are on a solid Ascender Bender!
05-11-2018, 09:46 PM | #75 | |||
A little update for you guys on my testing. First on asphalt, from a dead stop and bonsi starts the chassis wants to twist just a little but no tire lifting at all. Next the test board I built, on the obstacle side when the tires start spinning on to gain traction I can power out of it without the truck wanting to come over or roll. (The board will be fun to play on at the event). I can feel the over under gears in the transfer case really making a difference. When I flipped the board over to the smooth side I needed to increase the angle or the truck just walked right up the board. So when the tires did start searching for traction I could throttle up a little with very little twist. As I increased the angle of the board I could see the right front want to come up a little. If I really punched it the tire would come off the board. TT I don't think we have it to the point of it being a fix all for the ascender TT but it does help, and with a little help from everyone I think we will see more improvement with the TT. Quote:
Ernie Last edited by CODYBOY; 05-11-2018 at 09:49 PM. | |||
05-12-2018, 12:54 PM | #76 |
Agreed with what Ernie said, also appreciate everyone’s input! Mgputer, try it! In garage and driveway testing it seems to help. With longer link like Ernie sent, mine was binding a bit on left rear full compression (articulation ) about last 1/4" of shock travel. Compressing only left rear it binds slightly for last 1/4” of travel, seems like something with link geometry is out of parameter just slightly. This combined with Rich's shock collar mod, Vaterra stiff rear upper and lower springs, and maybe rulrs definitely improves the TT. Put them all together and it's getting where we want to be! I've played with the setup on my bench and yard for couple days with all kinds of links mounts etc. I had to buy new shock towers, swap out frame rail that I drilled and filled too much, but it’s getting all buttoned up soon! Edit: I like this setup! Last edited by Natedog; 05-12-2018 at 01:20 PM. |
05-12-2018, 03:45 PM | #77 | |
05-12-2018, 06:12 PM | #78 |
05-12-2018, 08:10 PM | #79 | |
good stuff!! | |
05-12-2018, 09:16 PM | #80 | |
Worked a little on the three link and mounted a 2D drive and co-piolet today, time is catching up with me in being ready for the Proline by the Fire event. Rock photos, Some flex and the panhard bar working. Just about ready for you guys to test at the event. Thanks for looking! Ernie I changed out the tires for you Paul!!! Also changed out the bumper for better approach. The other one looked cool but I wanted a little more function! Last edited by CODYBOY; 05-12-2018 at 09:26 PM. | |
Codyboy's 79 Ford (Rent to Own) Ascender - Similar Threads | ||||
80's Ford Ascender | smog | Vaterra Ascender | 205 | 12-23-2019 04:28 PM |
Codyboy's "bulldog bronco" ascender | CODYBOY | Vaterra Ascender | 280 | 06-04-2018 10:09 AM |
Ford Atlas Ascender | 2mtech | Vaterra Ascender | 11 | 12-04-2016 06:48 AM |
